    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 59.5k Views 12 Watching
      Aerilius
      I forgot to mention: the transparent png option has only been added to SketchUp 8.
      I'm working on a new version!
        glro
        @glro said:
        @aerilius said:
        @driven said:
        @glro said:
        is it possible to create a shortcut to a file using ruby?
        That might be a the easiest solution! I'll try it!
        i added some code to yours at the end of "self.save_as(filepath)" method
        > filepath2 = (filepath.split("/")[0..-2]).join("/")
        > nom_model = m.title
        > # name of the text file to put the shortcut in
        > nom_bat = filepath2 + "/" + nom_model + ".bat"
        > #open this file
        > aFile = File.new(nom_bat,"w")
        > pathmodel = m.path
        > #write the file shortcut
        > aFile.puts("call "+pathmodel)
        > aFile.puts("end")
        > aFile.close
        a black cmd window is opened... must be closed manually, unless you embed the .bat file in a .js file...
        it is basic but it works...
        Doesn't work if there is a white space in the file address
        additional code is needed
        nom_bat2 = nom_bat.to_s
        if nom_bat2.count(nom_bat2, " ") != 0
        UI.messagebox("no white space in the file address")
        fail
          Aerilius
          I updated the plugin. I think it will now fit all your needs because you can now make your own buttons 😉
          @glro, can you test if the shortcuts work as expected?
            glro
            i tested, but there might be a problem
            no box is opened on my scree when i check "ae snapshot" in the menu
            it might come from the html file
            in the pop up windows you show in the first message of this thread, i read "create a shortcut"
            but when i click on the html file in "ae_snapshot" folder, i don't see the same things
            html settings differences
              Aerilius
              I first thought it might have to do with upgrading the settings (because the previous version is much different). But I just tested it from 0.1.1 to 0.3.0 and it works for me.
              You mean the settings dialog does not appear when you click the gear icon on the toolbar (there is no ae snapshot menu). Can you open the Ruby Console, click the gear button and give me the error messages if there are any.
              Then copy&paste " AE::Snapshot.options={}" into the console and press the gear button again. Does it then work?
                glro
                yes, the setting dialog does not appear;
                the gear icon does'nt appear either...
                just a small reactangle where i cannot click ...
                how do you explain the differences between the setting dialog window i get when i double click directly on the file "settings_dialog.htm" and the one you pasted in you message?
                my guess is that it is linked to the problem
                snapshot icon
                • srxS Offline
                  srx
                  Very useful! Thank you very much.
                  www.saurus.rs
                    Aerilius
                    @glro: Does " Sketchup.write_default("Plugins_ae", "Snapshot", "{}")" on the Ruby Console and restarting help?
                    (There are no relevant differences in the htm file.)
                    (By the way, you don't need quote the message, I know it's on the same page one above 😉 )
                      glro
                      OK
                      yes it helps
                      when i close and open sketchup again, the icon and snapshot settings windows appear on the screen
                      but i cannot save the parameters (clicking on "OK" doesnt change anything)
                      i notice the lines you added to create a file shortcut; since this is the only option i am interested in, i'll try to add them to the previous version, that worked perfectly on my computer
                      thank you
                        Aerilius
                        @glro said:
                        yes it helps
                        That is good!
                        Toolbar changes can only take effect after restarting SketchUp. (Maybe that's not so obviously written.)
                          glro
                          when i launch sketchup again, i get "wrong number of arguments (0 for 1)"
                          The plugin does take a shot when i click on the button
                          but i cannot get the snapshot settings windows on the screen anymore
                          it may be because of my computer, if i am the only one to have this problem...
                            Aerilius
                            I am very sure it's not your computer. I couldn't find anything on my own.
                            This error was on the Ruby Console? Can you tell me what was before or after that? There should be a line number and a line number is very much helpful!
                              glro
                              no, nothing in the ruby console
                              it is an error message when sketchup loads all the plugins
                              no numbers
                              erreur chargement
                                Aerilius
                                Ok, SketchUp does not tell us much about load errors. In such a case we need to reload the plugin manually in the Ruby Console to see more details. Can you do:
                                load "ae_Snapshot/Snapshot.rb"
                                  glro
                                  Here is what i get when i type 'load "ae_Snapshot/Snapshot.rb" 'in the ruby console
                                  Error: #<ArgumentError: C:/Archivos de programa/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:309:in `initialize': wrong number of arguments (0 for 1)>
                                    Aerilius
                                    Thanks!!!
                                    I found and fixed the issues!
                                      glro
                                      sorry to write that i still have an error message
                                      string to integer error
                                        Aerilius
                                        I'm not sure if I found it (line 187?). Can you post the error with line number that the Ruby Console gives?
                                          glro
                                          Here is the error message:
                                          "Error: #<TypeError: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319:in []': can't convert String into Integer> C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:319 C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Snapshot/Snapshot.rb:318:in each'
                                          (eval):155:in `load'
                                          (eval):155"
                                          line 319
                                            Aerilius
                                            (I won't be back until tomorrow.)
                                            I just made a quick change, can you test it?
                                            Put it in .../Plugins/ae_Snapshot/Snapshot.rb
                                            • 2 / 4
