    Weird jaggy command trails
    19 Posts 7 Posters 704 Views 7 Watching
    • john2J Offline
      john2
      in the office i'm using windows xp sp3 fully updated. my mother board drivers are also updated, and sketchup found no problems in enabling open gl or fast feedback. enabling these two increases performance. for last 2 days i'm experiencing problems like this. all of a sudden, the pointer, the measuring tool, or any tools shows up trails. if i press ESC and retry the command, it works fine. what's wrong?
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        @john2 said:
        enabling open gl
        You mean Hardware Acceleration under Preferences?
        This looks like a graphic hardware or driver issue. What hardware do you have?
          Aerilius
          This looks like your hardware does not support"Fast Feedback". Try disabling it in Window → Preferences → OpenGL.
          Or update your graphcis driver and see if the upgrade improves fast feedback.
          • john2J Offline
            john2
            @thomthom said:
            @john2 said:
            enabling open gl
            yes, the hardware preferences in SU. my hardware specs are
            pentium d cpu, 2.8 GHz, MSI motherboard g4 mp26, 2gb ram.
            i downloaded the driver from the website. i have already specified earlier. all updates installed. even the printer driver is up to date. all the drivers downloaded a week ago from the manufacturer's website .the problem occurs after 3 hours or so. iv disabled open gl. lets see what happens.
              You omitted the graphic card.
              There could still be a graphic card / driver issue. It could be that even the latest drivers doesn't fix it. It could be that your graphic card doesn't support OpenGL that well.
              • john2J Offline
                john2
                no external graphic card. in the control panel it says intel graphic media accelerator. on old PCs Su showed warning about incompatibility. Su ain't showing that message if i enable or disable Graphic acceleration. 😕
                • BoxB Offline
                  Do you happen to have a wacom tablet, I've seen this problem with them and resetting the wacom preferences fixes it.
                    That would be your problem then. Integrated cards often have poor support. Older Intel cards are known to be troublesome.
                    I recommend you pick up an nVidia card. They have solid OpenGL support.
                    • john2J Offline
                      john2
                      I'LL have to ask my boss then 😆
                        Indeed - anyone working with CAD and 3d needs a separate dedicated graphic card.
                        • hellnbakH Offline
                          hellnbak
                          Whenever I encounter a problem like this I just do a Purge (the plugin) and it fixes it (even if a purge isn't needed). Don't know why, but it works for me. FWIW.
                          • john2J Offline
                            john2
                            you're saying using this plugin solves the problem?
                            http://forums.sketchucation.com/viewtopic.php?t=11758#p82552
                            • hellnbakH Offline
                              hellnbak
                              No, I'm saying that it works for me. Whenever my computer starts to lag a bit, whether it's because of a texture-heavy model or having shadows turned on while orbiting a lot, whenever I run Purge it does fix the problem for me. Not permanently, but long enuf for me to continue my work, and purging only takes a few seconds. I'm no computer geek or SU guru, and like I said I don't know why it works, just thought I'd pass along something that might help someone else out.
                                John2, purging unused stuff from your SketchUp models is a good idea no matter what but a plugin is not going to fix hardware that isn't up to the task. Reducing the work your GPU has to do by leaving textures turned off and by limiting the number of edges and faces it has to process will help but at some point you'll need it to be able to handle those things.
                                • hellnbakH Offline
                                  hellnbak
                                  No Dave, I'm not saying that purging is a replacement for ensuring that your hardware is up to the task. All I'm saying is that when I'm working on a model and the textures start disappearing when I move or orbit it, or movement gets sluggish, even if I have changed nothing in the model and have done nothing since the last purge but move the model around a lot, purging does alleviate the problem. Not permanently, but certainly long enuf for me to get on with my work.
                                  It works for me, and I just thought I would pass this along to possibly help John2 maybe get by until he does get his problem sorted out.
                                    I wasn't disagreeing with you, Steve. You are absolutely correct. 😉
                                    • hellnbakH Offline
                                      hellnbak
                                      Thanks. Now can somebody explain to me how purging can do this when you've done nothing to the model but move it around?
                                      • mitcorbM Offline
                                        mitcorb
                                        [off:3vk1y28v]According to my research, your machine is tripping. 💚[/off:3vk1y28v]
                                        • john2J Offline
                                          john2
                                          yeah that's happening to me too! 😉 ditto
