    Poor performance on new computer
    11 Posts 6 Posters 1.2k Views 6 Watching
      manamana
      Hi all,
      I recently upgraded my main home computer From a Q9550/6GB RAM / GT240 GDD5 to a Xeon 1275V2 (basically a 3770)/ 16GB / GT640 GDDR5 machine. But the new computer has worse performance, only in sketchup viewports, than the old one. Everything else is way faster, including viewports in other 3D applications (rhino). With a model that I could rotate around/ display smoothly with the GT240, I'm seeing heavy stuttering (2-5 FPS). I actually see much better performance if I disable hardware acceleration.
      • I've updated to the latest nVidia drivers
      • I've made sure I have the latest sketchup
      • I've tried disabling fast feedback
      • I've set AA to 0x, 2x and 4x in sketchup with no noticeable difference in performance
      • I've tried forcing low quality rendering in the driver panel
      Using the GPU observer gadget, I've confirmed that the GT640 GPU is not being constrained by load, VRAM, or temperature. That leaves driver settings, windows settings, and sketchup settings, of which I can see nothing out of the ordinary.
      Help?
        Charlie__V
        @manamana said:
        Hi all,
        Help?
        If my memory serves....there may be a tick box in the Nvidia control panel that allows "the application" to decide settings (SU).
        If so......give that a try.
        Charlie
          manamana
          Yeah, tried that, as well as forcing it to lower quality across the board in the nVidia panel.
          Some new findings:
          If I start sketchup after a reboot, it works fine.
          The second I start firefox, the lag sets in, and remains even after firefox is closed.
          So.... Are there any resources that firefox uses that sketchup uses as well?
          • N Offline
            numerobis
            Is gpu acceleration enabled for firefox?
            If yes, maybe try to disable it.
              Switch OFF Firefox's Options > Advanced > 'Use hardware acceleration when available' - it causes all sorts of issues with FF if enabled anyway !
                manamana
                And that fixes it.
                Thanks all.
                  manamana
                  Errr. it's back again, even after a fresh reboot.
                  I'm thinking it might be plugin related. With the new computer, I sought out updates and new plugins to try. If I delete my plugins folder and repair the sketchup install, it seems to be fine. Copy all the plugins back in and it's acting up again.
                  guess I have to install one at a time and see where it is.
                    mac1
                    Install 1/2 , if no problem you know it is in other 1/2, divide the 1/2 by 1/2 again keep repeating. Can take just a few tries to find trouble maker. BTW that is called a maximum entropy search. 🀣
                      If you have any of the new beta BIM tools loading try disabling them...
                      Otherwise, as recommended then doing it 'by halves' is the quick way to zoom in on the culprit[s]...
                      • jgbJ Offline
                        jgb
                        Binary search actually. πŸ€“
                        jgb
                          mac1
                          Its part of information theroy. Have you ever heard of Shannons. Becuase of coding and the confusion of symbols vs bits the community stated to note a different. You don't known what the probability of occurrence is but information on a particular guess is related to 1/p which means an occurrence happening that has low probability carries much more information than one with high probability and if you know that that one can structure the guess to max the information aka entropry and minimize the number of guesses one has to make. Therefore max entropy guess in general , binary search for a specific cases. Actually you are not correct. Only in the case all the probabilities are equal and is the reason I always use the general case.
