    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.1k Views 135 Watching
      And it's the same with the rotation Tool πŸ˜‰
      But seems also that is the first thing that we learn when we start SU! πŸ˜‰
      Don't use multiple copy in SU is very mysterious πŸ˜„
      • majidM Offline
        majid
        @gaieus said:
        @charly2008 said:
        did not know that you can also use the tool to make multiple copies of objects.
        Ah yes, with the Move tool it's called a "Linear array" - but you can also do similar "Radial array" with the Rotate tool
        amazin part is that you can type:
        X5
        5X
        5
        0r 5
        and they reffer to same result!!!! ( array )
        • jgbJ Offline
          jgb
          I've used that a lot, BUT, I can't seem to radial array within a 360 circle. πŸ˜•
          As I reach 359.999 it jumps to zero degrees, and "/x" returns nothing.
          I know I'm missing something here. ❓
          I usually solve it by first making a circle with the number of segments I want, then radially array the object to a vertex, and multiply (total number wanted less 1), then delete the circle.
          jgb
          • boofredlayB Offline
            boofredlay
            Start your array and type 360 for the degrees and hit enter rather than clicking to enter the degrees. Then do your multiplier.
              1. Copy rotate to any random angle
              2. Adjust angle with VCB to 360
              3. Use VCB to divide the full rotation by number of elements ( / 7 )
              Or, if you know the angle between each element, just rotate by the first segment.
              1. Copy Rotate 45 degrees
              2. *7
                One note however. If you use the divide function around a full 360 degrees and first you rotate the component by 360 degrees, you will end up with two, overlapping components in position 0 (or 360). This is not a serious issue as after the rotation and radial array, this firstly copied component will remain highlighted so just make sure that after the radial array, also press the Delete button.
                  True, I used loose geometry in my test.
                    Well, true, thatmerges with no trace left.
                    • jgbJ Offline
                      jgb
                      😍 That worked... Many thanks. πŸ‘ πŸ‘ πŸ‘
                      TT & Gaieus, thanks as well. That duplicate copy over the original used to be a problem, till I started using a circle with the right # of segments to get around it.
                      jgb
                        Super cool never thought to bend a 2D image with the Fredo Scale! πŸ‘ 😎
                          Roger
                          [attachment=0:39d35j95]<!-- ia0 -->cool.jpg<!-- ia0 -->[/attachment:39d35j95]
                          You bent over backward to discover that function. 🀣 (Does not translate easily to French)
                          http://www.azcreative.com
                            I believe that I understand that you want to say πŸ˜„
                            Contortionist Zlata up the steps of the Cannes Film Festival! 😲
                            http://www.pourlefan.eu/photos/1568823771.jpeg
                              Roger
                              Boggles the imagination!
                                ArCAD-UK
                                @pbacot said:
                                I can make a new layer via the Entities window simply by assigning the selected entity by typing a new layer name.
                                Not on the PC you can't. πŸ˜•
                                • pbacotP Offline
                                  I can make a new layer via the Entities window simply by assigning the selected entity and typing a new layer name. Did it by mistake. πŸ˜„ Never knew.
                                  I thought this thread was a sticky, until I went looking for it...
                                  • Epix3DE Offline
                                    Epix3D
                                    Just discovered the System settings> Open GL > Use hardware acceleration. Suddenly Sketchup looks sharp and smooth to work with. How can I have missed this before? 😳
                                    • F Offline
                                      flyashy
                                      I have found this thread to be the MOST instructional of them all! So thanks to http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=15244 for starting it!
                                      I've done a lot of these and found some great tips in here.
                                      I thought I'd add one of mine that may help someone.
                                      Although with the save toolbars position, a lot of toolbar mayham has been solved, but I still get it sometimes when even restore toolbars won't work.
                                      I'd accidentally discovered this trick a while back when somehow all my toolbars had decided to go vertical or something!:
                                      So, if you get toolbar chaos, don't do anything to sketchup to restore position etc...just call up taskmanager-windows (or force quit-mac) and kill the sketchup process, immediately if you can. if the process is killed sketchup will revert back to the earlier 'saved toolbars' position and no more chaos.
                                      Cheers!
                                        Flyashy, you linked a profile, not a post.
                                        • cottyC Offline
                                          cotty
                                          A simple one, but helpful...
                                          (Model info -> components -> Show component axes)
                                          my SketchUp gallery
                                            rv1974
                                            The Tips&Tricks thread would be a better place for this, but anyway,
                                            In case you produce a lot of vistas:
                                            1. Export your scenes with 'anti-aliasing off' and X2 demanded size 6000 pix wide instead of 3000 (well I'm sure you knew it already)
                                            2. Create Photoshop droplet (File-Automate-Create Droplet; google some tutorials in your internets) from your typical actions.
                                              For example: resize to 3000> add soft light layer> tweak it's transparency> shadows & highlights> smart sharpen> close file.
                                              Dudes, this is HUGE time saver. Actually there's no need to manually open Photoshop anymore
                                              Just drag & drop the folder with your pictures upon the droplet's exe icon and enjoy πŸ˜‰
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 34
                                            • 35
                                            • 23 / 35
