    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 622.4k Views 135 Watching
    • GaieusG
      One note however. If you use the divide function around a full 360 degrees and first you rotate the component by 360 degrees, you will end up with two, overlapping components in position 0 (or 360). This is not a serious issue as after the rotation and radial array, this firstly copied component will remain highlighted so just make sure that after the radial array, also press the Delete button.
        True, I used loose geometry in my test.
        • GaieusG
          Well, true, thatmerges with no trace left.
          • jgbJ
            jgb
            Start your array and type 360 for the degrees and hit enter rather than clicking to enter the degrees. Then do your multiplier.
            😍 That worked... Many thanks. πŸ‘ πŸ‘ πŸ‘
            TT & Gaieus, thanks as well. That duplicate copy over the original used to be a problem, till I started using a circle with the right # of segments to get around it.
            jgb
              Super cool never thought to bend a 2D image with the Fredo Scale! πŸ‘ 😎
                Roger
                [attachment=0:39d35j95]<!-- ia0 -->cool.jpg<!-- ia0 -->[/attachment:39d35j95]
                You bent over backward to discover that function. 🀣 (Does not translate easily to French)
                http://www.azcreative.com
                  I believe that I understand that you want to say πŸ˜„
                  Contortionist Zlata up the steps of the Cannes Film Festival! 😲
                  http://www.pourlefan.eu/photos/1568823771.jpeg
                    Roger
                    Boggles the imagination!
                      ArCAD-UK
                      @pbacot said:
                      I can make a new layer via the Entities window simply by assigning the selected entity by typing a new layer name.
                      Not on the PC you can't. πŸ˜•
                      • pbacotP
                        I can make a new layer via the Entities window simply by assigning the selected entity and typing a new layer name. Did it by mistake. πŸ˜„ Never knew.
                        I thought this thread was a sticky, until I went looking for it...
                        • Epix3DE
                          Epix3D
                          Just discovered the System settings> Open GL > Use hardware acceleration. Suddenly Sketchup looks sharp and smooth to work with. How can I have missed this before? 😳
                          • F
                            flyashy
                            I have found this thread to be the MOST instructional of them all! So thanks to http://sketchucation.com/forums/memberlist.php?mode=viewprofile&u=15244 for starting it!
                            I've done a lot of these and found some great tips in here.
                            I thought I'd add one of mine that may help someone.
                            Although with the save toolbars position, a lot of toolbar mayham has been solved, but I still get it sometimes when even restore toolbars won't work.
                            I'd accidentally discovered this trick a while back when somehow all my toolbars had decided to go vertical or something!:
                            So, if you get toolbar chaos, don't do anything to sketchup to restore position etc...just call up taskmanager-windows (or force quit-mac) and kill the sketchup process, immediately if you can. if the process is killed sketchup will revert back to the earlier 'saved toolbars' position and no more chaos.
                            Cheers!
                            • GaieusG
                              Flyashy, you linked a profile, not a post.
                              • cottyC
                                cotty
                                A simple one, but helpful...
                                (Model info -> components -> Show component axes)
                                my SketchUp gallery
                                  rv1974
                                  The Tips&Tricks thread would be a better place for this, but anyway,
                                  In case you produce a lot of vistas:
                                  1. Export your scenes with 'anti-aliasing off' and X2 demanded size 6000 pix wide instead of 3000 (well I'm sure you knew it already)
                                  2. Create Photoshop droplet (File-Automate-Create Droplet; google some tutorials in your internets) from your typical actions.
                                    For example: resize to 3000> add soft light layer> tweak it's transparency> shadows & highlights> smart sharpen> close file.
                                    Dudes, this is HUGE time saver. Actually there's no need to manually open Photoshop anymore
                                    Just drag & drop the folder with your pictures upon the droplet's exe icon and enjoy πŸ˜‰
                                  • pbacotP
                                    It "creeped -up" on me that my visual quality sucked (sketchy and disappearing lines) and I was told to look at this. It really cleared things up. At some point I had turned it off because of other graphic anomalies. So I think I will be going back and forth... πŸ˜•
                                      MikeFJaguar
                                      @rv1974 said:
                                      The 'Lock\unlock aspect ratio' at material edit drove me crazy for years.
                                      Clicking it wont change visually its state (stupid bug!). To see it changed one should move
                                      the cursor off the button.
                                      This one got me very frustrated, until I discovered it's just a slooow button!
                                      In Windows 7 at least, click the Lock/Unlock button and WAIT for a couple of seconds. Lo and behold the button icon changes!
                                      EDIT
                                      Hmm. I'm wrong, you're right! The cursor does need to be moved off the button. As you say, stupid bug. Perhaps I'm a stupid bug..r 😳
                                      • cottyC
                                        cotty
                                        You can toggle the "active cut" setting of a section plane with a double click...
                                        my SketchUp gallery
                                          d12dozr
                                          !!! πŸ‘ πŸŽ‰ πŸ˜„
                                          http://goo.gl/f7ooYh
                                          • panixiaP
                                            panixia
                                            just discovered a DOH feature of the selection tool..
                                            if you drag a selection rectangle from left to right it selects only the items completely wrapped in the rectangle, but if you drag the rectangle from right toward left,then also the items wich are only touched (but not fully wrapped) by the rectangle are selected.. never noticed it before.. 😲
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 34
                                            • 35
                                            • 23 / 35
