    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Strange Thing in drawing a circle
    19 Posts 6 Posters 941 Views 6 Watching
      Panga
      Just find a a strange thing trying to make a circle...All the evidences are above...
      First...
      I have this perfect square (verified) of 0,24 x 0,24 cm
      Then...
      Trying to draw a circle...
      And for the finish :
      Circle done, but the external lines moves...
      The externals lines of the square were modified after the circle is created...This is not happening when i scale the model x10 (square 2,4 x2,4 cm). Is this a bug or a limitation of SU ? Hope for the first one ๐Ÿ˜ž
      Any ideas ??
      My units settings just for info :
      Settings for units
        Sample model?
          Too small and you are around SketchUp's precision tolerance. Within a certain, very tiny distance those edges merge. Scale the whole square up and try that way.
            Panga
            Yep, you can find it here...
            sample_circle.skp
            but you can reproduce it easily, this was done in a clean file. For the info, this happen with a circle of 48 sides in my file...but do not happen with a circle of 40 sides, happens with a 80 sides circle....
              Panga
              Sorry SIR Pilou ๐Ÿ˜‰
              sample_circle_v6.skp
                the squaring of the circle! ๐Ÿ˜„
                and no saved in V6 format, I am disapointed! ๐Ÿ˜ฎ ๐Ÿ’š
                and curious I have not this problem with this measure and number of segments! ๐Ÿ˜ฎ
                square.skp
                  Panga
                  Thanks for the try Pilou, but the result change with the number of sides, and you square was in meter, my tests are in cm... Try with my file and with 48 sides in SU6 in order to see if it's related to SU version.
                    Trop tard j'ai dรฉjร  envoyรฉ mon essai ๐Ÿ˜„
                    Ah damned I took 44 segments ๐Ÿ˜ณ
                    but same resul with 48 ๐Ÿ˜„
                    Seems no problem ๐Ÿค“
                    But maybe I don't see what I must see ? ๐Ÿ˜’
                    sample_circle_v6_48.skp
                      previous test was in V7 ๐Ÿ’š
                      Now in true V6
                      Sorry I don't see nothing curious ๐Ÿ˜
                      sample_circle_truev6_48.skp
                        Right, by the looks of it you're getting some triangulation in the new face that's too extreme. You see how it snaps down to the neighbour vertex instead of the apex? The distance there is very very small - under the SU limit. I'm guessing it's the triangulation algorythm misses that last piece because the points, or distances at that point is considered equal within SU's accuracy.
                        It's somewhat odd that, at least on my machine, that the circle ends up exploded. And I'm getting some visual artifacts when trying to use tools afterwards. Until I pick a new style for the model that is...
                          Yes, it also explodes for me. And though when it's bigger, you can draw it normally, in this case drawing bigger and scaling down (the "usual" workaround) does not work either.
                          I do not get any special artefacts though. Can it be simply because of the miniature size?
                            Purge?
                              Ah ok I have reload your file
                              Same result than you
                              But Something I don't understand!
                              Why your file is so heavy for just 2 little rectangles + 2 circles !!!!!!! ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
                              2.48 megas ๐Ÿ˜ฎ
                              That must be less 50 KB!!! ๐Ÿ˜’
                                Panga
                                2.48 megas ๐Ÿ˜ฎ
                                I was asking myself the same thing...did a purge...and everything's fine...but I made another test : made a new file, draw four squares in it, and save it : 2,42Mo. In fact, my default template was not purged...shame on me !!
                                Edit : Find something, Since I installed the Ivy Plugin, every new file as already 6 components and 4 materials in it ! Without doing anything ! Is that normal ? Also found three components called light-point !
                                • TIGT Online
                                  The "Ivy" tool is known to do this. ๐Ÿ˜’
                                  It's annoying that it does it at startup - I think someone has made a modified version that only loads them if you use the tool - it's straightforward to fix, and since the original author seems to have lost interest it's not an issue...
                                  The "light's" look like they come form a rendering tool - what like that do you have loading ?
                                  ๐Ÿ˜•
                                  • Rich O BrienR Online
                                    [off:xx3sfx6y]
                                    I can't find that version?[/off:xx3sfx6y]
                                      LightUp does this as well. I have to keep it disabled until I want to use it otherwise it litters my component and material browser until I purge unused...
                                        Panga
                                        ๐Ÿ˜•
                                        I have to check it...I'm only using TheaRender but I reinstalled recently and think I did not reinstall the Thea plugin...maybe a file that remains in my plugins folder I saved before the reinstall...
                                        • TIGT Online
                                          The auto-loading of Ivy's components was discussed...
                                          I can't find the 'fix' either...
                                          Perhaps in the morning I'll remember what/where it was...
                                          It can't be that awkward to move the auto-loading for the 'startup' into the 'first-use' of the tool...
