    [Poll] What do you think of the new SketchUp logo designs ?
    32 Posts 20 Posters 6.2k Views 20 Watching
    • W
      wyatt
      To me, the new logo indicates a shift to the more engineering mindset of Trimble. There are a lot of trained architects on the SketchUp team and the original vision of SU was likely as an architectural visualization tool. The latest icons with the house seemed to reflect those roots (and the largest user base? - not sure about that one). As we all know, SketchUp is used for a lot more than building architecture. In that sense, the new logo may be more applicable to the wider SU audience. That being said, I had to really hunt for the new icon on my taskbar this morning. 😕
      Edit: I do really like the visually consistent icons for Layout and Style Builder.
      • Phil MeadowsP
        Phil Meadows
        I wonder if the team who developed this logo knew that Microsoft was going to change theirs. The two are very similar.
        The mark itself is successful; it shows an object, in perspective—the default view for SketchUp—and it has clearly been push-pulled, another SketchUp original. The color doesn't even matter to me. It can be any color and still be a successful mark. To the R-G colorblind out there it's probably brown.
        • N
          ninopiamonte
          I thinks, it's like they give low opportunity to Sketchup as the famous and easy 3d modeling software, unlike C4D & Max's logo. 😕
          • emerald15E
            emerald15
            On a positive note. When searching through windows explorer, the 2D & 3D logo versions signifying Layout & SketchUp files respectively are a lot easier to identify than the old logos, which were a little difficult to tell apart if you using small icons.
            • E
              etobic
              yes we all did notice right ?
              http://content.screencast.com/users/Etobic/folders/Jing/media/0a5eacd1-4d97-4b7c-966f-cccd7e84c3d6/Did you notice.png
              • Mike LuceyM
                Mike Lucey
                Has anyone played around with the actual logo model? See attached file. It looks to me the the plan view does not correspond to the 3d view!
                I take the point regarding a logo's requirement to 'look good' when zoomed out but we are now entering the age of retina display! So does this principle still apply?
                Co-incidentally I tried out the 15" MBP Retina today in my local Apple store. It was hard to drag myself away and found my right hand reaching for the wallet in my back pocket but I resisted as I want to wait a few months to check out the 13.3" MBP Retina which is rumored to appear shortly.
                My point being that things will look just as good, if not better on the 13.3" than my current 17" MBP.
                So, my question is, should the 3D logo be a little more defined with line edges? We are going to be looking at this logo for some time to come 😄
                Exploring Logo.skp
                • GaieusG
                    @gaieus said:
                    Yesterday I was playing around with a Cover Photo for Vertex Tools' G+ page:
                    G+ Cover Photo
                    I was just throwing some vertices randomly around - but I now realize I was building the Trimble logo!
                    Vertex Trimble
                    • pbacotP
                      It's inevitable, TT.
                      http://3.bp.blogspot.com/-bDN7R5ObQWg/T6VKYrSf7qI/AAAAAAAAB00/aRI9oQ9xKZU/s1600/close%2Bencounters%2Bof%2Bthe%2Bthird%2Bkind.jpg
                      (actually that was my thought on the logo too. I dig your cubes.)
                      • genki.ttG
                        genki.tt
                        I think it has wall width and parapet .. ?
                        SketchUp_NewLogo.skp
                        • Mike LuceyM
                          Mike Lucey
                          Hi Takahiro, I initially thought it would turn out like your model (which I like) but I don't think it is like this. Have you studied the line projections in my model?
                          • aarondietzenA
                            aarondietzen
                            I was looking at your image, Mike, and I THINK that it is extruded "squares" with a heavy, 2D outline:
                            I drew an "extruded" square with red sides and white tops.
                            Then I used photoshop to trace around the outside with a thick outline, and changed all red to the same hue...
                            "Imagination is more important than knowledge..."
                            - Albert Einstein
                            • genki.ttG
                              genki.tt
                              How about this model ?-? 3 logo scene with same model, different style setting.
                              NewLogo.skp
                              • aarondietzenA
                                aarondietzen
                                I think that is close, but based on mike breakdown, I don't think it can be models purely in 3d.
                                - Albert Einstein
                                • cheddaC
                                  chedda
                                  I think the previous logo was a little toy like. A change of image is good i think.
                                  Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                    They did make tweaks in post. 😉
                                    • sfto1S
                                      sfto1
                                      When I use small icons in my explorer folders, it is hard to distinguish between SU and LO. It did inspire me to create an avatar though. 😄
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Who cut the cheese ?
                                        I'm not here much anymore.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          **Hey, we passed the 100 vote mark! 😍
                                          **Don't forget to vote in this poll also:
                                          ➡ [Poll] What do you think of the new SketchUp logo color ?****
                                          • EdsonE
                                            Edson
                                            it is natural for people to feel uneasy about any innovation. we get attached to things which are familiar to us. I confess feeling that way when I first saw the new sketchup icon but it slowly grew on me and now I quite like it.
                                            to be perfectly honest I always felt the sketchup icon to be a bit silly, with its pencil and little house. so much so that I changed it for the one you see below.
                                            however, I do not think the Layout icon is as successful as Sketchup's. I find it too flat in a literal as well as figurative way.
                                            http://www.mahfuz.arq.br
