    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Vray load error
    renderpluginsextensions
    12 Posts 8 Posters 23.9k Views 8 Watching
      adeeb88
      Dear all,
      I got this message when i open my vray for sketchup
      Load Errors
      Error Loading file vfs.rb
      undifined method 'file_loaded?' for main ๐Ÿ˜ฎbject
      Please help
      ADEEB
      • Rich O BrienR Online
        Did you try contacting Chaos Group customer support?
        • andybotA Offline
          andybot
          Did you use the installer? You could try uninstalling and then reinstalling
            adeeb88
            i already contact chaos group technical team and still waiting for the reply i. i already reinstall for couple of time and the error still come out. Is there any solution?thanks
              It's due to a silly but - they forgot to add require 'sketchup.rb'. Add that to the top of the vfs.rb file.
              Few people experience this because most people who use V-Ray for SketchUp uses other plugins as well. I assume you have no other plugins installed.
                adeeb88
                Thanks its work!! ๐Ÿ‘ .. but now i have another problem.. when i click render nothing happen.. even i just create simple box and i hit render nothing happen.
                  Open the Ruby Console (Window > Ruby Console) and see if you are getting any errors.
                    karismah
                    soo, I am having same problem. I hit render and nothing apears. The ruby console generates this problem :
                    Done processing compdefs - Elapsed time: 21.6650002002716
                    Scene processed in 30.3639998435974 seconds
                    undefined method entities' for #<Sketchup::ComponentInstance:0x31b1f338> + C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:475:in light_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:687:in instance_node_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:685:in each'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:685:in instance_node_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:606:in node_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1816:in write_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1815:in each'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1815:in write_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1937:in render'C:\ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:32
                    Is there any chance I solve it out? I have reached the point I'm not able to do anything else for the project, which is almost ready. File is 63MB quite big, but not huge yet.
                    Anyone? ๐Ÿ˜„
                      You want to contact support for that.
                        mbrackett
                        I have run into the same exact error. I do not know what you mean by adding "require sketchup infront of the rb file"
                        very confused! any suggestions would help
                        thanks!
                          rspierenburg
                          If you edit the VFS.RB file with a text editor and put: require 'sketchup.rb' on the first line.
                            rishikaoza
                            Hi.
                            Im facing an issue with my Vray renderer.
                            It keeps showing me this message that i have attached as a scheenshot.
                            Opened Ruby Console in the Windows menu and it showed me the following message :
                            C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/live_scene/live_scene:267:in launch_render' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/commands:52:in block in module:GUI'
                            C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/commands:13:in call' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/commands:13:in block in generate_command'
                            SketchUp:1:in `call'
                            However, I'm unable to understand what is wrong.
                            Kindly advice ๐Ÿ˜„
