๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Vray load error
renderpluginsextensions
12 Posts 8 Posters 23.6k Views
    adeeb88
    Dear all,
    I got this message when i open my vray for sketchup
    Load Errors
    Error Loading file vfs.rb
    undifined method 'file_loaded?' for main ๐Ÿ˜ฎbject
    Please help
    ADEEB
    • R Online
      Did you try contacting Chaos Group customer support?
        andybot
        Did you use the installer? You could try uninstalling and then reinstalling
          adeeb88
          i already contact chaos group technical team and still waiting for the reply i. i already reinstall for couple of time and the error still come out. Is there any solution?thanks
            It's due to a silly but - they forgot to add require 'sketchup.rb'. Add that to the top of the vfs.rb file.
            Few people experience this because most people who use V-Ray for SketchUp uses other plugins as well. I assume you have no other plugins installed.
              adeeb88
              Thanks its work!! ๐Ÿ‘ .. but now i have another problem.. when i click render nothing happen.. even i just create simple box and i hit render nothing happen.
                Open the Ruby Console (Window > Ruby Console) and see if you are getting any errors.
                  karismah
                  soo, I am having same problem. I hit render and nothing apears. The ruby console generates this problem :
                  Done processing compdefs - Elapsed time: 21.6650002002716
                  Scene processed in 30.3639998435974 seconds
                  undefined method entities' for #<Sketchup::ComponentInstance:0x31b1f338> + C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:475:in light_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:687:in instance_node_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:685:in each'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:685:in instance_node_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:606:in node_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1816:in write_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1815:in each'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1815:in write_to_xml'C:\ProgramData/ASGVIS/VfS/Ruby/VfSExport.rb:1937:in render'C:\ProgramData/ASGVIS/VfS/Ruby/R2PToolbar.rb:32
                  Is there any chance I solve it out? I have reached the point I'm not able to do anything else for the project, which is almost ready. File is 63MB quite big, but not huge yet.
                  Anyone? ๐Ÿ˜„
                    You want to contact support for that.
                      mbrackett
                      I have run into the same exact error. I do not know what you mean by adding "require sketchup infront of the rb file"
                      very confused! any suggestions would help
                      thanks!
                        rspierenburg
                        If you edit the VFS.RB file with a text editor and put: require 'sketchup.rb' on the first line.
                          rishikaoza
                          Hi.
                          Im facing an issue with my Vray renderer.
                          It keeps showing me this message that i have attached as a scheenshot.
                          Opened Ruby Console in the Windows menu and it showed me the following message :
                          C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/live_scene/live_scene:267:in launch_render' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/commands:52:in block in module:GUI'
                          C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/commands:13:in call' C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/gui/commands:13:in block in generate_command'
                          SketchUp:1:in `call'
                          However, I'm unable to understand what is wrong.
                          Kindly advice ๐Ÿ˜„
