    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 265.7k Views 123 Watching
      I don't get it. What's to wait for in loading it? What exactly are you doing to install the plugin?
      Do you have administrative rights to the Plugins folder? Did you correctly extract the contents of the ZIP file? Did you extract the contents to the Plugins folder?
      Post a screen shot of your Plugins folder along with screen shots showing the contents of the folder called 'Oscar' and the one called 'Cursor & Icon'.
      Have you read the sticky post about installing plugins from ZIP files?
      • E Offline
        ElliottAero
        Is there a version for pro is that it?
          No. Why would you even need this plugin since you have the pro version of SketchUp? πŸ˜’ Instead of worrying about installing plugins, why don't you learn to use the native tools you've got, first?
            lubessy
            COULD someone PLEASE fix this BOOLEAN PLUGIN?!?!
            it's doesnt work AT ALL in sketchup 8 pro!!!
            please oscoolean!!! update it for everyone whose in need of this plugin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              Just use the native Solid Tools. πŸ˜’
                Jspro
                Yes I really had high hopes for this plugin. It seems to load alright but it only join two components together, but would not cut a hole or do any of the other functions. I have version 8 of sketchup hoping that there will be an update so that I can use this
                  Since other users have reported that the plugin works fine, perhaps your problem is due to incorrect installation? That's the usual cause of plugins not working. Would you like to continue to wait for the update you're hoping for or would you rather just get the existing version to work? If it is the latter, post screen shots of the Plugins folder and of the contents of the related folders so we can see how you've installed it.
                    Jspro
                    Dave thanks for all your help, the tool bars loaded correctly ,after i have intersected the to groups together ,the first command joins them together, but after that nothing seems to happen? here a pic of my plugin folder
                      Jspro
                      Dave heres the screen shot of the tool bar
                        Jspro
                        Hey Dave my agologizes i think ive figured it out it seems to work thanks John
                          dyl
                          I've extracted the files to the plugins folder but cant seem to find it anywhere in Sketchup. Any ideas? Have just updated to the latest free version of Sketchup 8.
                          Update, sorry just scrolled back through a few pages and found the solution. View/Toolbar and you can enable it there.
                            Jspro
                            Can you help me in trying to figure out why OSCoolean has stop working? When i have two objects that i have group togther and intersected them, the command doesnt respond? Here a copy of my sketchup plugin folder. Thanks John
                              Why don't you post the model that is giving the problems?
                                Jspro
                                This is just a simple model, that i used to see if it will work, do you think that the plugin round corners some how has affected it somehow?
                                  Jspro
                                  Dave have you had a chance to figure out what could be happening with my problem? thanks john
                                    You still haven't posted the model as I requested. You seem to be resisting being helped. I don't have more time to donate to this.
                                      Jspro
                                      The model is posted if you cant figure it out fine! just say so, dont have an attitude about it
                                        He meant the actual .skp file - not a screenshot.
                                          The model isn't posted. A screen shot is not the model. πŸ˜’ And I don't have an attitude about it.
                                            Jspro
                                            Well you know i did say i was new to these pugins, when were looking for help we are at a disadvantage. Not all of us are techno-wizs. Not trying to offend anyone but beng accused of resisting help seems like he is tired of doing this. I was just looking for help that is all.
                                            • 15
                                            • 16
                                            • 8 / 16
