    [Solved]Shadows acting funky
    38 Posts 9 Posters 1.8k Views 9 Watching
    • hellnbakH Offline
      hellnbak
      For some reason large parts of this model (hood, fenders, door, seat backs, etc) are not casting shadows. Everything is set to cast and receive shadows. It doesn't happen in monochrome mode. Any ideas/suggestions?
      • mitcorbM Offline
        mitcorb
        I will throw this out, but you don't have to count on it. What if your color/texture has a degree of transparency not accounted for?
        • hellnbakH Offline
          hellnbak
          Nope, 100% opacity
          • hellnbakH Offline
            hellnbak
            Just so you know that it isn't the most likely problem, I have checked each component involved.
              What are you seeing when you export as a 2D graphic?
              • hellnbakH Offline
                hellnbak
                Gotta head into Holland now, will check when I get back
                • ToboboT Offline
                  Tobobo
                  Could the inside face be transparent?
                  Maybe you accidentally painted the component with the transparent texture?
                  Toby
                  Philippians 4:13
                  • hellnbakH Offline
                    hellnbak
                    Ok, here's what I've found out so far --
                    It looks exactly the same when exported as a 2D graphic.
                    As far as the colors being transparent or whatever, here's what happened when I experimented with the door outer shell
                    The next three photos are just to show the colors involved
                    When I paint the bottom half of the door black, the shadows are correct for that section....
                    BUT, when the light comes from the other direction (with the bottom half still painted black), the shadow is still missing
                    I'm really tired right now and probably not thinking real straight, and I have little doubt that it will turn out to be something really simple that I've overlooked, but I don't know what else to look for.
                    • hellnbakH Offline
                      hellnbak
                      Here's the SKP of the door shell if anybody thinks that would help.
                      Ford Shadow Problem.skp
                      • mitcorbM Offline
                        mitcorb
                        Is this from that batch of new colors you loaded? Maybe not
                        • hellnbakH Offline
                          hellnbak
                          No, these were from quite a while back, long before I added any colors to the Materials folder.
                          • W Offline
                            wyatt
                            I don't know why this works, but if you change all the green materials to 99% opacity, the shadows appear. I also replaced your materials with new ones and the shadows also appeared. There must be something wrong with the way those materials were created/edited, but I don't know what that might have been.
                            • hellnbakH Offline
                              hellnbak
                              Well, I can live with 99% opacity. As far as where the colors came from, it's been quite a while but I think I might have sampled them from a photo of an actual 56 Ford Sunliner with the color combination I wanted. But I don't see how that would have any bearing on the strange behavior.
                              Yep, found where I sampled the photos. Also sampled for the interior colors, guess that might explain the problems with the seats.
                              Very strange.
                                Charlie__V
                                Hell,
                                If you "paint with default"......ford-fairlane-victoria-1956.jpg......will be the default.
                                I cannot explain why........though the model default is not "ford-fairlane-victoria-1956.jpg"
                                Charlie
                                Ford shadow.....Paint with default
                                • hellnbakH Offline
                                  hellnbak
                                  Hell,
                                  Charlie
                                  I'm not really sure what you're saying here. I just sampled the colors I needed using the "Match Color On Screen" eyedropper.
                                  • ToboboT Offline
                                    Tobobo
                                    Strangely when I open the skip the shadows work fine.
                                    Maybe I'm missing something
                                    Toby
                                    Philippians 4:13
                                      That's going to hurt performance. Transparency adds overhead to processing of the model in the viewport.
                                        Have you tried without Hardware Acceleration? In case this is a graphic card / driver issue.
                                        What card and driver version do you have?
                                          Ah! I know what this is!
                                          I actually wrote about this some time ago: http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/
                                          (Scroll down to Bug with Materials and Color Alpha Channel and see example and description of bug.)
                                          To fix all materials in your model, enter this one-liner in your Ruby Console:
                                          Sketchup.active_model.start_operation('Fix Materials',true);Sketchup.active_model.materials.each { |m| c=m.color.to_a; c[3]=255; m.color=*c; };Sketchup.active_model.commit_operation
                                            Very nice model by the way! 👍 👍
