    1.5k Posts 471 Posters 3.3m Views 470 Watching
      Megan, do you have administrator privileges under your own log in to add files to the Plugins folder? Did you install the other plugins while logged in under your user name and Round Corner while logged in as Administrator? What happens if, while logged in as you, you reinstall Round corner?
        resall
        I'm trying to install the round corner plugin but it just wont work.
        I've installed LibFredo6 4.6 in the plugins folder, then Round Corner 2.3
        I even tried unistalling everything (including sketchup and all of its folders) and installing again, and nothing...
        Then I tried deleting the date that came on the name of the folders available for download at the begining of this post and again, nothing...
        I'm using Mac OS X 10.6.8 and Sketchup 8 (free version).
        Can someone please help me.
        Thanx
        footprint
          You haven't actually installed them. 😲
          The two subfolders [called 'LibFredo...' and 'RoundCorner...'] that you show are what the extraction of the zipped archive produces - the package - if you will.
          Inside those folders are the files and subfolders containing other files that auto-load and make the tool available to you when you restart Sketchup.
          So these need to be in the 'plugins' folder - not left inside the package that they came in.
          So move these two folders onto your Desktop... then move their contents back into the 'plugins' folder.
          Ensure that all files in the subfolders stay inside those subfolders, when they are moved - it is another frequent error - to move the items out of subfolders - which will surely break everything - because the .rb 'loaders' files expect to find these files in the subfolders, which are supplied with the tool, and also sometimes extra 'support' files in additional 'libraries' - like in the case of this tool !
            resall
            SOOO SIMPLE! Thanks!
              art4smart
              Thank YOUUUU
              • F Offline
                figgo
                Finally got the plugin installed. Now it crashes when I try to use it. First plugin I've got so nothing's conflicting. I'm using vista.
                  It's probably not installed correctly. Post a screen shot of your Plugins directory.
                  • F Offline
                    figgo
                    Ok here it is:
                    http://img3.imageshack.us/img3/710/pluginscreen.png
                    Before I installed this plugin though, Sketchup crashes for me a lot anyway. I have to save every minute or so.
                      Figgo
                      Don't double post, have patience as a new member...
                      Also learn to attach an image rather than link off to some 3rd party site.
                      Your installation looks OK.
                      How does this 'crash' manifest itself.
                      If you have the Ruby Console open are there any error messages etc...
                      You are not helping us to help you a lot... πŸ˜•
                      • F Offline
                        figgo
                        I didnt double post due to impatience...I didnt know it needed to be approved. And I'm not only new to this forum, I don't use forums period. Just came to ask a question.
                        Ok nitpicking aside, I can make Sketchup crash myself by clicking and dragging all the way outside of the white area. Everything closes, even Ruby console, and it says there was an error.
                          If Sketchup is processing a lot of geometry then it can 'white-out'.
                          This is temporary and it should complete eventually.
                          Without an example of what you are trying to do it's hard for us to say whether this is the case or there's another issue - e.g. very small facets failing to form properly [try scaling up x10, round-edges then scale back down...]
                          The disppearance of the Ruby Console is also common during a white-out... but does Sketchup close-down and a Bugsplat! screen appear ? Or is this 'error' displayed in the Console eventually ? [You are still giving us scant details - the more info you give the more likely we to be able to help solve this].
                          Many people use this tool without issues, so there's something adrift with either your setup, initial geometry or settings etc...
                          Have patience... πŸ˜‰
                          • fredo6F Offline
                            @figgo,
                            Can you check if you have Matchbox, Sunposition or Podium installed. These plugins are known to conflict with RoundCorner, as indicated in the main post.
                            Otherwise, as TIG recommended, it would be helpful to have an idea of the model you experiment on.
                              Jspro
                              Resolved
                                Jspro
                                Yes I am a new user to sketch up plugins. I have a loaded Round Corner and it seems to have loaded alright. But when I draw a rectangle it seems to distort as you can see by the picture I have attached. Can you help me find out why it is doing this. Thank you John
                                  It looks to me as if you've got a radius setting for the round corners that is larger than your box. I'll bet it would help if you read the instructions. Go back to the first post in the thread and download the documentation.
                                  By the way, why do you have duplicate toolbars displayed. do you need both of those? You could rearrange your toolbars and get some additional drawing space, too.
                                    Tools > Fredo Collection > Round Corner > Documentation > Quick Card
                                      Also: how big is that cube? (I mean in centemetres/inches)? SU has issues with tiny geometry.
                                        Jspro
                                        Yes is there a way in the settings to show the referencing lines in the corners, bevels, as in your video rather showing an object that has been smooth.I like the appearance w/the lines. Thank you John
                                          It's in the documentation. πŸ˜’
                                            John,
                                            You really would benefit from taking time to read the documentation. It's 9 pages which would take you at most 20 minutes.
                                            • 73
                                            • 74
                                            • 7 / 74
