    1.5k Posts 478 Posters 4.3m Views 478 Watching
      resall
      SOOO SIMPLE! Thanks!
        art4smart
        Thank YOUUUU
        • F
          figgo
          Finally got the plugin installed. Now it crashes when I try to use it. First plugin I've got so nothing's conflicting. I'm using vista.
            It's probably not installed correctly. Post a screen shot of your Plugins directory.
            • F
              figgo
              Ok here it is:
              http://img3.imageshack.us/img3/710/pluginscreen.png
              Before I installed this plugin though, Sketchup crashes for me a lot anyway. I have to save every minute or so.
                Figgo
                Don't double post, have patience as a new member...
                Also learn to attach an image rather than link off to some 3rd party site.
                Your installation looks OK.
                How does this 'crash' manifest itself.
                If you have the Ruby Console open are there any error messages etc...
                You are not helping us to help you a lot... πŸ˜•
                • F
                  figgo
                  I didnt double post due to impatience...I didnt know it needed to be approved. And I'm not only new to this forum, I don't use forums period. Just came to ask a question.
                  Ok nitpicking aside, I can make Sketchup crash myself by clicking and dragging all the way outside of the white area. Everything closes, even Ruby console, and it says there was an error.
                    If Sketchup is processing a lot of geometry then it can 'white-out'.
                    This is temporary and it should complete eventually.
                    Without an example of what you are trying to do it's hard for us to say whether this is the case or there's another issue - e.g. very small facets failing to form properly [try scaling up x10, round-edges then scale back down...]
                    The disppearance of the Ruby Console is also common during a white-out... but does Sketchup close-down and a Bugsplat! screen appear ? Or is this 'error' displayed in the Console eventually ? [You are still giving us scant details - the more info you give the more likely we to be able to help solve this].
                    Many people use this tool without issues, so there's something adrift with either your setup, initial geometry or settings etc...
                    Have patience... πŸ˜‰
                    • fredo6F
                      @figgo,
                      Can you check if you have Matchbox, Sunposition or Podium installed. These plugins are known to conflict with RoundCorner, as indicated in the main post.
                      Otherwise, as TIG recommended, it would be helpful to have an idea of the model you experiment on.
                        Jspro
                        Resolved
                          Jspro
                          Yes I am a new user to sketch up plugins. I have a loaded Round Corner and it seems to have loaded alright. But when I draw a rectangle it seems to distort as you can see by the picture I have attached. Can you help me find out why it is doing this. Thank you John
                            It looks to me as if you've got a radius setting for the round corners that is larger than your box. I'll bet it would help if you read the instructions. Go back to the first post in the thread and download the documentation.
                            By the way, why do you have duplicate toolbars displayed. do you need both of those? You could rearrange your toolbars and get some additional drawing space, too.
                              Tools > Fredo Collection > Round Corner > Documentation > Quick Card
                              • GaieusG
                                Also: how big is that cube? (I mean in centemetres/inches)? SU has issues with tiny geometry.
                                  Jspro
                                  Yes is there a way in the settings to show the referencing lines in the corners, bevels, as in your video rather showing an object that has been smooth.I like the appearance w/the lines. Thank you John
                                    It's in the documentation. πŸ˜’
                                      John,
                                      You really would benefit from taking time to read the documentation. It's 9 pages which would take you at most 20 minutes.
                                      • V
                                        vacstudio
                                        Thanks Fredo06 - your plugin helped a newbie today!! πŸ‘
                                          snlow5115
                                          I'm new in here, and i trying to install the plugins in my mountain lion, but i just can't find the folder?
                                          can some advise....
                                            The usual place is MacIntosh HD/Library/Application Support/Google SketchUp 8/SketchUp/Plugins.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 74
                                            • 75
                                            • 29 / 75
