    I need to build this.
    27 Posts 8 Posters 2.7k Views 8 Watching
      ShapeBender?
      • KrisidiousK
        Krisidious
        used that Rocksolver stones to build start a corner by hand. high poly and very time consuming.
        next going to try shapebender on the triangular shape drawn in 2D and then bent afterwards...
        By: Kristoff Rand
        • KrisidiousK
          Krisidious
          architecturally, what would you call this feature?
          By: Kristoff Rand
          • L
            lapx
            Chris,
            It's called random stacked stone. Looks like some kinda of false buttress.
            I don't think you need to go through that much effort with 3d. I would model the basic shape and texture it as you desire. Anything like this can be handle with a good "character refence guide" indicating color,pattern, texture and dimension you require. I good mason should be able to build this with a little art direction in the field. ofcurse the traditional cross section showing construction elements is necessary.
            • KrisidiousK
              Krisidious
              Lapx,
              That's probably the closest thing I've heard to describe it. however what I'm looking for is more natural and random than ordered like buttresses. I know my shape shown in the screenies is rather perfect, but the randomness is what I'm after, I was using that buttress shape as a guide.
              I call it a spilling stone corner or a spread stone corner. but searches give me no examples. this is one I happened across on the net and it's close to what I want except it's too narrow through it's length. I would like it to be wider and seem to come up from the ground instead of down into it.
              here's one of our sketches.
              imagine this wrapping a corner and coming up higher.
              [xxl-img:23d2t063]http://1.bp.blogspot.com/-rZ--zwlBk3A/T72Zb1hwU8I/AAAAAAAAB-o/UnPpkFqbmsM/s1600/Retaining+wall+falling+WM.jpg[/xxl-img:23d2t063]
              By: Kristoff Rand
              • bazB
                baz
                Here we call it a 'Dry stone wall'. Dry because no grout or cement is used.
                Check this google images page for plenty of examples. Or Google 'dry stone wall'
                https://www.google.com.au/search?q=dry+stone+wall&hl=en&client=firefox-a&hs=rHV&rls=org.mozilla:en-US:official&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=v1EbULm-HezxmAWL-YHYBA&ved=0CF8QsAQ&biw=1624&bih=845
                • KrisidiousK
                  Krisidious
                  Baz we're more speaking of the wall itself and how it flares out, instead of the form of pattern.
                  By: Kristoff Rand
                  • KrisidiousK
                    Krisidious
                    Here's a rather quick Artisan attempt.
                    By: Kristoff Rand
                    • KrisidiousK
                      Krisidious
                      results for use if anyone wants.
                      stone corner 6.skp
                      By: Kristoff Rand
                      • bazB
                        baz
                        looking good πŸ‘
                        • Paul RussamP
                          Paul Russam
                          That works, that works very well πŸ‘
                          Sometimes its hard to accept that something is good enough when your trying to achieve a specific look/goal.
                          Kris.....
                          That is good enough
                          unless that is ..... πŸ’­
                          No, no no stop it, its good enough, on to the next thing... ➑
                          In any case can always go back to later if it's truly bugging you.. πŸ˜‰
                          Paul Russam
                          English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                            Do you have the proxy Kris?
                            • iichiversiiI
                              iichiversii
                              That looks well, I wouldn't of came up with that technic but I'll be using this technic for a future project on the cards πŸ‘
                              Bring on the Rain...
                              • KrisidiousK
                                Krisidious
                                No Rich I don't I just went through and saved it, didn't save the original like I should have.
                                By: Kristoff Rand
                                • KrisidiousK
                                  Krisidious
                                  It's totally under my skin Paul... But yeah I think it's probably good enough. probably... I want 3D Hatching damnit!
                                  By: Kristoff Rand
                                    That's a shame as it has real potential with some tweaks
                                    stone corner 6.skp
                                      MrMikeEsq
                                      That with a bump map would look quality!
