    I need to build this.
    27 Posts 8 Posters 2.3k Views 8 Watching
    • bazB
      baz
      I like that mesh from the bitmap. But yes, too much detail. There are a couple of things that come to mind to make it more manageable... poly reduce and/or selectively make planar the tops in artisan?
      But I think designing a specific bitmap,(as you say) would give the most natural result. Then you could isolate individual 'stones', de-poly them, (is that a word? it is now:) and component them.
      In my attempt, most of the entities are copied, scaled and rotated from perhaps 3 or 4 base entities.The smaller stones are literally quick fill ins and need no detail.
      Go for it Kristoff, model one good patch of stones and you are good to go for many projects.
      (You will share, won't you?:)
      Baz.
      PS: you can have my skp. for what it's worth if ya want.
      • KrisidiousK
        Krisidious
        Here is my attempt at free hand. it turns out well and is fairly low poly. but not in the shape I need.
        By: Kristoff Rand
          ShapeBender?
          • KrisidiousK
            Krisidious
            used that Rocksolver stones to build start a corner by hand. high poly and very time consuming.
            next going to try shapebender on the triangular shape drawn in 2D and then bent afterwards...
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              architecturally, what would you call this feature?
              By: Kristoff Rand
              • L
                lapx
                Chris,
                It's called random stacked stone. Looks like some kinda of false buttress.
                I don't think you need to go through that much effort with 3d. I would model the basic shape and texture it as you desire. Anything like this can be handle with a good "character refence guide" indicating color,pattern, texture and dimension you require. I good mason should be able to build this with a little art direction in the field. ofcurse the traditional cross section showing construction elements is necessary.
                • KrisidiousK
                  Krisidious
                  Lapx,
                  That's probably the closest thing I've heard to describe it. however what I'm looking for is more natural and random than ordered like buttresses. I know my shape shown in the screenies is rather perfect, but the randomness is what I'm after, I was using that buttress shape as a guide.
                  I call it a spilling stone corner or a spread stone corner. but searches give me no examples. this is one I happened across on the net and it's close to what I want except it's too narrow through it's length. I would like it to be wider and seem to come up from the ground instead of down into it.
                  here's one of our sketches.
                  imagine this wrapping a corner and coming up higher.
                  [xxl-img:23d2t063]http://1.bp.blogspot.com/-rZ--zwlBk3A/T72Zb1hwU8I/AAAAAAAAB-o/UnPpkFqbmsM/s1600/Retaining+wall+falling+WM.jpg[/xxl-img:23d2t063]
                  By: Kristoff Rand
                  • bazB
                    baz
                    Here we call it a 'Dry stone wall'. Dry because no grout or cement is used.
                    Check this google images page for plenty of examples. Or Google 'dry stone wall'
                    https://www.google.com.au/search?q=dry+stone+wall&hl=en&client=firefox-a&hs=rHV&rls=org.mozilla:en-US:official&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=v1EbULm-HezxmAWL-YHYBA&ved=0CF8QsAQ&biw=1624&bih=845
                    • KrisidiousK
                      Krisidious
                      Baz we're more speaking of the wall itself and how it flares out, instead of the form of pattern.
                      By: Kristoff Rand
                      • KrisidiousK
                        Krisidious
                        Here's a rather quick Artisan attempt.
                        By: Kristoff Rand
                        • KrisidiousK
                          Krisidious
                          results for use if anyone wants.
                          stone corner 6.skp
                          By: Kristoff Rand
                          • bazB
                            baz
                            looking good πŸ‘
                            • Paul RussamP
                              Paul Russam
                              That works, that works very well πŸ‘
                              Sometimes its hard to accept that something is good enough when your trying to achieve a specific look/goal.
                              Kris.....
                              That is good enough
                              unless that is ..... πŸ’­
                              No, no no stop it, its good enough, on to the next thing... ➑
                              In any case can always go back to later if it's truly bugging you.. πŸ˜‰
                              Paul Russam
                              English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                Do you have the proxy Kris?
                                • iichiversiiI
                                  iichiversii
                                  That looks well, I wouldn't of came up with that technic but I'll be using this technic for a future project on the cards πŸ‘
                                  Bring on the Rain...
                                  • KrisidiousK
                                    Krisidious
                                    No Rich I don't I just went through and saved it, didn't save the original like I should have.
                                    By: Kristoff Rand
                                    • KrisidiousK
                                      Krisidious
                                      It's totally under my skin Paul... But yeah I think it's probably good enough. probably... I want 3D Hatching damnit!
                                      By: Kristoff Rand
                                        That's a shame as it has real potential with some tweaks
                                        stone corner 6.skp
                                          MrMikeEsq
                                          That with a bump map would look quality!
