    I need to build this.
    27 Posts 8 Posters 2.3k Views 8 Watching
    • KrisidiousK
      Krisidious
      architecturally, what would you call this feature?
      By: Kristoff Rand
      • L
        lapx
        Chris,
        It's called random stacked stone. Looks like some kinda of false buttress.
        I don't think you need to go through that much effort with 3d. I would model the basic shape and texture it as you desire. Anything like this can be handle with a good "character refence guide" indicating color,pattern, texture and dimension you require. I good mason should be able to build this with a little art direction in the field. ofcurse the traditional cross section showing construction elements is necessary.
        • KrisidiousK
          Krisidious
          Lapx,
          That's probably the closest thing I've heard to describe it. however what I'm looking for is more natural and random than ordered like buttresses. I know my shape shown in the screenies is rather perfect, but the randomness is what I'm after, I was using that buttress shape as a guide.
          I call it a spilling stone corner or a spread stone corner. but searches give me no examples. this is one I happened across on the net and it's close to what I want except it's too narrow through it's length. I would like it to be wider and seem to come up from the ground instead of down into it.
          here's one of our sketches.
          imagine this wrapping a corner and coming up higher.
          [xxl-img:23d2t063]http://1.bp.blogspot.com/-rZ--zwlBk3A/T72Zb1hwU8I/AAAAAAAAB-o/UnPpkFqbmsM/s1600/Retaining+wall+falling+WM.jpg[/xxl-img:23d2t063]
          By: Kristoff Rand
          • bazB
            baz
            Here we call it a 'Dry stone wall'. Dry because no grout or cement is used.
            Check this google images page for plenty of examples. Or Google 'dry stone wall'
            https://www.google.com.au/search?q=dry+stone+wall&hl=en&client=firefox-a&hs=rHV&rls=org.mozilla:en-US:official&prmd=imvns&tbm=isch&tbo=u&source=univ&sa=X&ei=v1EbULm-HezxmAWL-YHYBA&ved=0CF8QsAQ&biw=1624&bih=845
            • KrisidiousK
              Krisidious
              Baz we're more speaking of the wall itself and how it flares out, instead of the form of pattern.
              By: Kristoff Rand
              • KrisidiousK
                Krisidious
                Here's a rather quick Artisan attempt.
                By: Kristoff Rand
                • KrisidiousK
                  Krisidious
                  results for use if anyone wants.
                  stone corner 6.skp
                  By: Kristoff Rand
                  • bazB
                    baz
                    looking good πŸ‘
                    • Paul RussamP
                      Paul Russam
                      That works, that works very well πŸ‘
                      Sometimes its hard to accept that something is good enough when your trying to achieve a specific look/goal.
                      Kris.....
                      That is good enough
                      unless that is ..... πŸ’­
                      No, no no stop it, its good enough, on to the next thing... ➑
                      In any case can always go back to later if it's truly bugging you.. πŸ˜‰
                      Paul Russam
                      English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                        Do you have the proxy Kris?
                        • iichiversiiI
                          iichiversii
                          That looks well, I wouldn't of came up with that technic but I'll be using this technic for a future project on the cards πŸ‘
                          Bring on the Rain...
                          • KrisidiousK
                            Krisidious
                            No Rich I don't I just went through and saved it, didn't save the original like I should have.
                            By: Kristoff Rand
                            • KrisidiousK
                              Krisidious
                              It's totally under my skin Paul... But yeah I think it's probably good enough. probably... I want 3D Hatching damnit!
                              By: Kristoff Rand
                                That's a shame as it has real potential with some tweaks
                                stone corner 6.skp
                                  MrMikeEsq
                                  That with a bump map would look quality!
                                  • 2 / 2
