    Is there a script for clapboards?
    16 Posts 7 Posters 777 Views 7 Watching
    • V Offline
      valerostudio
      Looking to see if there is a script that will automatically model clapboards. 1001 bit tools has something very close that makes louvers but it lacks the options in order to make clapboards. Anyone know of a script free or pay that will allow you to select a series of faces and it will model claps taking into a account openings, etc. ?
        I don't know but I would imagine Profile Builder would allow you to do that.
        • pbacotP Offline
          PB wouldn't account for openings or rather you'd have to work around every opening yourself.
          Dave--your signature-- are you competing with Boo for the worst groaners? actually it's not a pun but REALLY! πŸ˜’
            I didn't know Boo had a groaner for a signature. I didn't think anyone ever read my signature anyway. Is it really that bad? πŸ˜„
            • V Offline
              valerostudio
              Profile builder is great but it doesn't quite automate what I need. 1001 bit tools has a really cool louver feature that could accomplish this but the parameters aren't there to allow for claps.
              • pbacotP Offline
                [off:3beb1z7j]Boo is just the pun "king", Nah it's good...[/off:3beb1z7j]
                  So now you've got me wondering about the possibility of a script that would be a modification of Follow Me that could detect a gap and jump it with the extrusion. Or suppose an opening such as a door or window was read by the script as a box that would be used as a "cutter" for the extrusion. That cutter could then cut through just part of the extrusion as might happen at the top and bottom of the window opening. I could imagine other applications for a plugin of this sort.
                  Peter, I agree with you that Boo is the "pun king". πŸ˜„
                  • V Offline
                    valerostudio
                    I wish I was as smart as you guys and could right scripts. If you know someone on the forums that could help put somethign like this together, I am sure it would be a huge hit. I am just sick of how flat jpeg textures render and I really dont like to use displacement for this type of application.
                      I wish I was smart enough to write scripts, too. Maybe TIG or ThomThom or someone will see this and take up the challenge.
                      • pbacotP Offline
                        TIG's Extrude edges by vector to faces will stop at intermediate obstructions (in this case the necessary trim around openings) but it won't start again. How does it tell when it should fill an area or not (such as the recessed spaces inside an opening)? Has to be based on the face defining the wall.
                          You are - but do you have the time?
                          Rich would skin me alive if I picked up a new project before I completed Bezier Surface. πŸ˜’ Speaking of which - I better write some code before he breaks my knees.
                            Thank you, Thomas. Yes, you're probably right about me not having the time to learn to do it. Maybe one day.
                              tim
                              I don't know how you can look at yourself in the mirror, Dave.
                              But on topic, a script or dynamic component etc that could do space filling physical patterns would be very useful. Roof tiles/shingles, metal roof panels, board and batten siding, bricks, anything repetitive. The ideal would obviously 'just work' when the face changed size or shape, just as pattern filling does now.
                              I can sort of see vague hints of the technique floating in the aether but I don't have anything like the available time to even try a simple example. And a really clever one is certainly beyond me right now.
                              • V Offline
                                valerostudio
                                1001 bit tools has a couple of tools that are so close (Horizontal Groove Lines and Louver tools) but it needs a little tweaking to be used for claps.
                                • Rich O BrienR Online
                                  noted
                                    raineysky
                                    Yes, I can see where such a script would definitely be a hit. Just got the older version of Housebuilder working (with no beeping?). Such a plugin would compliment it tremendously.
                                    Paul
