    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      tak2hata
      @eidam655 said:
      does subdividing the face into smaller regions help?
      Hi,eudam655.
      The face Your saying is blade of grass?
      Subdivide of blade setting is "DIVIDE".
      The blade will be generated more divides when you set it Large number.
      Thanks.
      by TAK2HATA
      • F Offline
        FGomes
        No. dividing the area does not help. The problem still occurs.
        This is very strange... for example, I made a flat rectangle, anda making fur preview, half the side as more "fur" than the other... I tried dividing the area in smaller areas but the problem persists...
        • F Offline
          FGomes
          First of all, I would like to confratulate on this excelente plugin.
          Im having a little problem with this plugin... When I make "grass", the plugin does not cover all the face.
          Could any one help please?
          Thanks a lot
          • eidam655E Offline
            eidam655
            you're wrong, dividing the are will help, you just have so many particles there that it hits some kind of ceiling.
            either that or the 30000 maximum per face is too little. how big is the face?
            I'm using SketchUp 2017, V-Ray 3.4
            • F Offline
              FGomes
              I tried dividing and its the same thing. See the examples and I increased the number to 900000 and it distributes less...
              • eidam655E Offline
                eidam655
                i get it.
                at your settings, i have to keep the face's area under 64m2 (that is 8x8m) so that the grass is created on the whole face. i don't know whence comes this limitation.
                • eidam655E Offline
                  eidam655
                  but then again, it only seems to be a preview issue, the grass generates without problems on bigger faces.
                  • F Offline
                    FGomes
                    @eidam655 said:
                    i get it.
                    I didnt understand what you meon with this...
                    And its not an preview issue. The fur is only made on that places!
                    I really would like to make this correctly... does any one knows how to make this?
                    • eidam655E Offline
                      eidam655
                      @jdcamc said:
                      Help! I'm doing something wrong. Here is my setup:
                      [attachment=1:j50esvjc]<!-- ia1 -->Screen Shot 2012-01-24 at 7.03.24 AM copy.png<!-- ia1 -->[/attachment:j50esvjc]
                      and my render:
                      [attachment=0:j50esvjc]<!-- ia0 -->Screen Shot 2012-01-24 at 7.06.18 AM copy.png<!-- ia0 -->[/attachment:j50esvjc]
                      As you can see, the grass is just little green dots and the rendering shows nothing at all. What am I doing wrong? ❓
                      FGomes, read this post again πŸ˜„ there's a preview button (the green dots you are getting), and Make Fur button (which will then generate the fur geometry).
                      • F Offline
                        FGomes
                        @eidam655 said:
                        [attachment=3:2nbvqzbl]<!-- ia3 -->Screen Shot 2012-01-24 at 7.03.24 AM copy.png<!-- ia3 -->[/attachment:2nbvqzbl]
                        and my render:
                        [attachment=2:2nbvqzbl]<!-- ia2 -->Screen Shot 2012-01-24 at 7.06.18 AM copy.png<!-- ia2 -->[/attachment:2nbvqzbl]
                        ok ... half the problem solved. Actually appeared in the preview only half the area covered, but after making the fur, the distribution was throughout the area.
                        However, the distribution was not homogeneous. There are areas with more grass than others.
                        This is strange... everyone does fantastic grass with theis plugin... I only encounter problems! ❓
                        Preview
                        make fur - strange distribution
                        • IneshtineI Offline
                          Ineshtine
                          I have the same issue with the green dots and the distribution. You're not the only one.
                          What? you haven't tried Raylectron yet?
                            tak2hata
                            Hi,Ineshtine and FGomes.
                            The previewing with too many green dots will be very slowly manipulation.
                            So It is limited.
                            And Making fur will makes sketchup model larger.
                            So "MaxNumber(/Face) " limits density each faces.
                            Setting "MaxNumber(/Face) " to large will make density same to each faces.
                            But be carefully.It will make file to very large.
                            Thanks.
                            by TAK2HATA
                              Ineshtine
                              Yes, indeed. But this is not the problem. The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur.
                              I have a suggestion. Can you implement clipping for the crowd? If we use a wide object instead of a tall object (like people), they go over the face edges. It would be nice if they clip, or moves inside so they don't go over the edges.
                              BTW, Thanks for this fantastic plugin, I love it.
                                Snowy
                                Thanks a lot! can't wait to try this.
                                  djdamian
                                  How can i get it?
                                  πŸ’­
                                    @djdamian said:
                                    How can i get it?
                                    πŸ’­
                                    Assuming you want the 'plugin'... please look at the very first post in this thread.
                                    There is a download link to get the archived files, and a detailed instruction on how to install it.
                                    More recent posts include several enhancements to the toolset - read those and download their files once you are up and running...
                                    • LanaL Offline
                                      Lana
                                      Very, very thanks.
                                        dairybrylle
                                        Hey! I am so thankful for this plugin, just tried it earlier and I am very pleased for its result! thank you so much!! πŸ˜„)
                                          cas_123
                                          Hi, how can I download this plugin? Probably my browser blocks this.
                                            Disable 'AdBlock' add-ons etc for SCF - just as you agreed in the membership ToS - then attachments should become available to you after a 'refresh'...
                                            • 32
                                            • 33
                                            • 4 / 33
