    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
    • F Offline
      FGomes
      @eidam655 said:
      @jdcamc said:
      Help! I'm doing something wrong. Here is my setup:
      [attachment=3:2nbvqzbl]<!-- ia3 -->Screen Shot 2012-01-24 at 7.03.24 AM copy.png<!-- ia3 -->[/attachment:2nbvqzbl]
      and my render:
      [attachment=2:2nbvqzbl]<!-- ia2 -->Screen Shot 2012-01-24 at 7.06.18 AM copy.png<!-- ia2 -->[/attachment:2nbvqzbl]
      As you can see, the grass is just little green dots and the rendering shows nothing at all. What am I doing wrong? ❓
      FGomes, read this post again πŸ˜„ there's a preview button (the green dots you are getting), and Make Fur button (which will then generate the fur geometry).
      ok ... half the problem solved. Actually appeared in the preview only half the area covered, but after making the fur, the distribution was throughout the area.
      However, the distribution was not homogeneous. There are areas with more grass than others.
      This is strange... everyone does fantastic grass with theis plugin... I only encounter problems! ❓
      Preview
      make fur - strange distribution
      • IneshtineI Offline
        Ineshtine
        I have the same issue with the green dots and the distribution. You're not the only one.
        What? you haven't tried Raylectron yet?
          tak2hata
          Hi,Ineshtine and FGomes.
          The previewing with too many green dots will be very slowly manipulation.
          So It is limited.
          And Making fur will makes sketchup model larger.
          So "MaxNumber(/Face) " limits density each faces.
          Setting "MaxNumber(/Face) " to large will make density same to each faces.
          But be carefully.It will make file to very large.
          Thanks.
          by TAK2HATA
            Ineshtine
            Yes, indeed. But this is not the problem. The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur.
            I have a suggestion. Can you implement clipping for the crowd? If we use a wide object instead of a tall object (like people), they go over the face edges. It would be nice if they clip, or moves inside so they don't go over the edges.
            BTW, Thanks for this fantastic plugin, I love it.
              Snowy
              Thanks a lot! can't wait to try this.
                djdamian
                How can i get it?
                πŸ’­
                • TIGT Online
                  @djdamian said:
                  How can i get it?
                  πŸ’­
                  Assuming you want the 'plugin'... please look at the very first post in this thread.
                  There is a download link to get the archived files, and a detailed instruction on how to install it.
                  More recent posts include several enhancements to the toolset - read those and download their files once you are up and running...
                  • LanaL Offline
                    Lana
                    Very, very thanks.
                      dairybrylle
                      Hey! I am so thankful for this plugin, just tried it earlier and I am very pleased for its result! thank you so much!! πŸ˜„)
                        cas_123
                        Hi, how can I download this plugin? Probably my browser blocks this.
                        • TIGT Online
                          Disable 'AdBlock' add-ons etc for SCF - just as you agreed in the membership ToS - then attachments should become available to you after a 'refresh'...
                            cas_123
                            Thank you, I downloaded it via IE. I put this unwrapped folder 'fur_en15a' in folder 'Plugins' in SketchUp files but it doesn't work. What should I do?
                              Ineshtine
                              You must unzip it to that folder.
                                cas_123
                                I did but it doesn't work πŸ˜•
                                  Ineshtine
                                  Make sure that the fur_en folder and the fur_en.rb file is in your ..*Sketchup\Plugins* folder and re-start Sketchup if it was already opened.
                                  if that doesn't work still, then let me ask.. what doesn't work? The fur plugin? or it's not in your Plugin menu? Give me some clues.
                                    cas_123
                                    Thank you very much, the problem was that I had it all in fur_en15a folder (not.zip), instead of having it autonomously in Plugins folder, now it works, thanks a lot and sorry for keeping on at you.
                                    • Z Offline
                                      Zacchia
                                      Thanks for this very helpful plugin! I will use it for carpets.
                                      Is it possilbe to delete a preset I saved ? How?
                                        slapfoot
                                        Anyone have a solution to this problem? I've encountered the same issue. Even just drawing a simple rectangle and generating the grass - the fur is concentrated in these triangle shapes.
                                          slapfoot
                                          "The real problem is, the grass generation is not evenly distributed (sometimes). There is more grass on some areas (looks like big triangles). It does this with the green dots, and also when making the fur."
                                          Any solution to this issue yet? I'm experiencing the same problem (using SK8 if that helps). Even when generating fur on a simple rectangular face - the fur distributes unevenly into these weird triangles. So i'll be left with fur concentrated triangles and then more sparse regions. Any help would be most appreciated!
                                          • slapfoot
                                            tak2hata
                                            • slapfoot
                                            Hi,slapfoot.
                                            The generating method was not improved.
                                            Please set the large value to "MaxNumber(/Face) :".
                                            But too many furs will make the model file size too large.
                                            Please notice about this.
                                            by TAK2HATA
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 32
                                            • 33
                                            • 24 / 33
