    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      jdcamc
      Well, I thought I did. Let me try it again just to make sure.
      Thanks.
        jdcamc
        yippee!! grass and everything - now I guess I'l have to start mowing....
        • N
          negiaf
          thanks alot
          its amazing
            asmendong
            IVE DOWNLOADED THE MAKE FUR, BUT NO .EXE FILE, ONLY FUR_EN, NOT AND INSTALLER, ONLY IMAGES. ANY HELP PLSSS??
              Arman
              Follow the installation instructions on the download page.
              There is no 'exe' file or an 'installer' etc. πŸ˜•
              Various files/subfolder in the downloaded 'archive' file will need extracting into the Sketchup Plugins folder... Before you restart Sketchup to get the expected menus/toolbars/etc...
              It sounds like you are a complete installation newbie ??? πŸ˜’
              There are many posts explaining how to do this in some detail... do a search on the SCF forums...
              Please [re]read these and the tools download page guidance notes - if you still can't install it come back to us...
              PS: Please don't post using ALL CAPS - it looks like you are shouting at us, it is also harder to read... AND it is generally regarded as bad manners on almost all forums... 😞
              • P
                pogogt
                THHAAAAAAAAAAAANNNNKKKKK YOU!!!! this will be very helpfull with my models : )
                  Arrakis10
                  hello this plug in is marvellous.
                  Just a silly question.
                  I finally manage to create some grass but it makes me a white model. I dont manage to change the color. It seems to be not a component (herb) so i have to change the color of every single blade of grass?
                  • eidam655E
                    eidam655
                    does subdividing the face into smaller regions help?
                    I'm using SketchUp 2017, V-Ray 3.4
                    • T
                      tak2hata
                      Hi,eudam655.
                      The face Your saying is blade of grass?
                      Subdivide of blade setting is "DIVIDE".
                      The blade will be generated more divides when you set it Large number.
                      Thanks.
                      by TAK2HATA
                      • F
                        FGomes
                        No. dividing the area does not help. The problem still occurs.
                        This is very strange... for example, I made a flat rectangle, anda making fur preview, half the side as more "fur" than the other... I tried dividing the area in smaller areas but the problem persists...
                        • F
                          FGomes
                          First of all, I would like to confratulate on this excelente plugin.
                          Im having a little problem with this plugin... When I make "grass", the plugin does not cover all the face.
                          Could any one help please?
                          Thanks a lot
                          • eidam655E
                            eidam655
                            you're wrong, dividing the are will help, you just have so many particles there that it hits some kind of ceiling.
                            either that or the 30000 maximum per face is too little. how big is the face?
                            • F
                              FGomes
                              I tried dividing and its the same thing. See the examples and I increased the number to 900000 and it distributes less...
                              • eidam655E
                                eidam655
                                i get it.
                                at your settings, i have to keep the face's area under 64m2 (that is 8x8m) so that the grass is created on the whole face. i don't know whence comes this limitation.
                                • eidam655E
                                  eidam655
                                  but then again, it only seems to be a preview issue, the grass generates without problems on bigger faces.
                                  • F
                                    FGomes
                                    @eidam655 said:
                                    i get it.
                                    I didnt understand what you meon with this...
                                    And its not an preview issue. The fur is only made on that places!
                                    I really would like to make this correctly... does any one knows how to make this?
                                    • eidam655E
                                      eidam655
                                      @jdcamc said:
                                      Help! I'm doing something wrong. Here is my setup:
                                      [attachment=1:j50esvjc]<!-- ia1 -->Screen Shot 2012-01-24 at 7.03.24 AM copy.png<!-- ia1 -->[/attachment:j50esvjc]
                                      and my render:
                                      [attachment=0:j50esvjc]<!-- ia0 -->Screen Shot 2012-01-24 at 7.06.18 AM copy.png<!-- ia0 -->[/attachment:j50esvjc]
                                      As you can see, the grass is just little green dots and the rendering shows nothing at all. What am I doing wrong? ❓
                                      FGomes, read this post again πŸ˜„ there's a preview button (the green dots you are getting), and Make Fur button (which will then generate the fur geometry).
                                      • F
                                        FGomes
                                        @eidam655 said:
                                        [attachment=3:2nbvqzbl]<!-- ia3 -->Screen Shot 2012-01-24 at 7.03.24 AM copy.png<!-- ia3 -->[/attachment:2nbvqzbl]
                                        and my render:
                                        [attachment=2:2nbvqzbl]<!-- ia2 -->Screen Shot 2012-01-24 at 7.06.18 AM copy.png<!-- ia2 -->[/attachment:2nbvqzbl]
                                        ok ... half the problem solved. Actually appeared in the preview only half the area covered, but after making the fur, the distribution was throughout the area.
                                        However, the distribution was not homogeneous. There are areas with more grass than others.
                                        This is strange... everyone does fantastic grass with theis plugin... I only encounter problems! ❓
                                        Preview
                                        make fur - strange distribution
                                        • IneshtineI
                                          Ineshtine
                                          I have the same issue with the green dots and the distribution. You're not the only one.
                                          What? you haven't tried Raylectron yet?
                                          • T
                                            tak2hata
                                            Hi,Ineshtine and FGomes.
                                            The previewing with too many green dots will be very slowly manipulation.
                                            So It is limited.
                                            And Making fur will makes sketchup model larger.
                                            So "MaxNumber(/Face) " limits density each faces.
                                            Setting "MaxNumber(/Face) " to large will make density same to each faces.
                                            But be carefully.It will make file to very large.
                                            Thanks.
                                            by TAK2HATA
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 32
                                            • 33
                                            • 23 / 33
