    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      It's because SU some times doesn't heal broken edges after all - probably some accuracy issue. To rework it to be 100% accurate might slow it down significantly. I figured that the stats being in the ball park would be good enough.
      • genma saotomeG
        genma saotome
        Edges... that was one... ok, I understand. One of the others I recall now was a count of deleted components. Would delete 13, then another 13, etc., etc.
        In truth, the numbers are a nice thing but not essential. I figure if you're aware and later happen to notice something the two might click and something gets fixed. Otherwise, oh well.
          ?!? Got a sample model for that?
          • john2J
            john2
            how can i make cleanup not delete coplanar lines (like imported drawings from cad) which are locked?
            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
              I have that in the list of bugs: https://bitbucket.org/thomthom/cleanup/issue/2/locked-groups-components-are-cleaned-up
              • john2J
                john2
                so when do we see this "don't delete the lockd objects version?" πŸ˜‰
                • kingsiK
                  kingsi
                  Already said thanks for this plugin before, but felt had to say Tusen Takk!! when it just cleaned out 3million lines lol. Bloody genius
                  Noobtastic
                    πŸ‘ πŸ˜„
                    • K
                      kandehalux
                      dang it....sorry for bothering, love your plugins!
                      now a problem occured with the installation of cleanup:
                      the TT_Lib2 is in the Plugins folder, the cleanup.rb is in the plugins folder.
                      but when starting up sketchup i get this message:
                      Error Loading File tt_cleanup.rb
                      uninitialized constant TT::GUI
                      in the forum i found suggestions with missing dlls on various windows, but no change. other plugins work fine.
                      I'm on Win7 x64 using Sketchup 8.0.3117
                      in addition i have to say,
                      previously i resetted my pc and of course installed sketchup. before that, cleanup worked like a charme. i still have a backup of the old installation, so i tried using the older version of cleanup and ttlib, but i got the same message.
                      any idea?
                        Sounds like TT_LIb2 isn't installed correctly, there should be a TT_Lib2 folder with lots of .rb files in it.
                        I made a small utility that makes it easier to install plugins correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
                        I recommend you update to the latest Maintenance Release 3 - it includes several bugfixes etc.
                        • K
                          kandehalux
                          alright, so i updated to the m3 release v8.0.14346 (didnt really notice that it was an actual update due to the version number). the plugins are installed correctly.
                          in the meantime i found out, that it must have something to do with the template-loader of sketchup. because every plugin loads correctly, when i start directly with an skp-file (even with original template-skps). if i start sketchup without an skp, half of the plugins dont load.
                            Try running Sketchup 'As Admin' and see if that works - sounds like your permissions are limited - show Bill Gates who's boss ! Windows can treat you like a moron! Of course I'm not suggesting that you are not a moron πŸ˜• πŸ˜‰ Fix your security settings - become an Admin at least...
                            • K
                              kandehalux
                              ...yea, and since windows 7 like a real super moron. being admin and thinking being admin are different chapters in the holy book of "How to suprise with even more stupid ideas of programming".
                              Unfortunately it didn't help...does the same when i start sketchup as admin...maybe i have to install as admin....gosh...i am the admin! but it doesnt matter, can live with that!
                              thanks!
                                mac1
                                1. "previously i reset my pc and of course installed sketchup.' This appears to be the failure point?
                                  Have you tried removing the clean-up plugin and see if rest load?
                                  Can you regress to a restore point before 1 above?
                                  Have you tried making a new template and reloading?
                                  If you use the native plugins installed with SU8 M3 does loading work ok?
                                  Just some wild TS thoughts:)
                                  angeliapayne
                                  no such file to load -- TT_Lib2/core.rb
                                  I have downloaded the latest version of SU (8.0.14346) and I have also downloaded and use your Plugin Installer and I still get the error. Any thoughts?
                                  I've also tried running as Admin and no diff.
                                  Thanks for keeping this post aliver - super excited about the potential of this script!
                                    Looks like you didn't get the required TT_Lib2 file. Go back to the first post and read the section called Requirements. Download and install the TT-lib2 file.
                                    • I
                                      ivreich
                                      Purge Unused > Purge Unused Layers / Purge Unused Materials / Purge Unused Styles
                                      Hi Thom Thom
                                      Is it possible to have the "purge unused" function separated into purge unused layers, purge unused materials and purge unused styles?
                                      This would be useful for maintaining the structure of material palettes/ layer templates in models that require separate management of these hierarchies.
                                      Cheers
                                      Joel
                                        I already wrote that years ago... http://forums.sketchucation.com/viewtopic.php?p=82559#p82559
                                        • panixiaP
                                          panixia
                                          oh my god how can i miss this one till now!!! 😲
                                          cleanin'up the ultra-crappy archicad model of the boss and it works like magic!
                                          thank youu!!!
                                          • john2J
                                            john2
                                            when are we gonna have a feature that ignores locked groups e.g. autocad imported drawings? πŸ˜„
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 48
                                            • 49
                                            • 31 / 49
