    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Hello,
      When I export my model with LumenRT, it fails because it finds a zero length vector !?!
      It seems Cleanup cannot find such problem.
      How to find it?
      Is it possible to improve cleanUp to take it in account?
      Alain
      Can you provide a sample model?
      This zero length vector - is that from an error you get? Can you post the whole error?
      It could be that it is a bug in LumenRT's exporter - and not a model problem.
        AlainBo
        I found the problem, not precisely but it was related to a scene and not to the model.
        I did't really understand what caused the bug but it's sure it's not a geometry issue.
        Thanks a lot.
        • T
          tspco
          What did I do wrong? I just downloaded and installed cleanup 3.1.9 and latest ttlib 2.6 I open the model and run the plugin, The screen goes gray, and a long gray box appears with no options to select from. The ttlib file goes into the compatibility files folder, I think that is the problem. I cannot move in back into the regular plugins folder
          SU make 2017, /Twilight Render Hobby
          Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
          • T
            tspco
            I read back a few pages and found the issue, I now have the tt simple installer, and all "appears" as it was.
              Ensure that you have 'full access rights' to the Plugins folder [select its icon Properties > Security ...].
              Also do the same for Components, Materials and Styles...
              This will stop 'Compatibility Files' issues - where Vista stops you moving files/folders into certain 'program' folders to protect you from yourself if you have limited access rights... With full-rights it should behave...
              • T
                tspco
                I apparently already set permissions for everyone but the creator owner will not change, I am sure it is a windows thing I really don't need to know.
                  Why mess with that just give yourself 'full-permissions'...
                  • genma saotomeG
                    genma saotome
                    Dunno if this has been mentioned before (40 pages is a lot to go thru) but the statistics presented afterwards are off. I'll run cleanup and be told it cleaned out quantities a, b, and c of types x, y, and z... do nothing, run cleanup again and be told it cleaned out quantities a, b, and c of types x, y, and z... and... rinse and repeat forever. Version 3.1.9.
                    I like the results... but I do wish it would tell the the straight story when it was done.
                      It's because SU some times doesn't heal broken edges after all - probably some accuracy issue. To rework it to be 100% accurate might slow it down significantly. I figured that the stats being in the ball park would be good enough.
                      • genma saotomeG
                        genma saotome
                        Edges... that was one... ok, I understand. One of the others I recall now was a count of deleted components. Would delete 13, then another 13, etc., etc.
                        In truth, the numbers are a nice thing but not essential. I figure if you're aware and later happen to notice something the two might click and something gets fixed. Otherwise, oh well.
                          ?!? Got a sample model for that?
                          • john2J
                            john2
                            how can i make cleanup not delete coplanar lines (like imported drawings from cad) which are locked?
                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                              I have that in the list of bugs: https://bitbucket.org/thomthom/cleanup/issue/2/locked-groups-components-are-cleaned-up
                              • john2J
                                john2
                                so when do we see this "don't delete the lockd objects version?" πŸ˜‰
                                • kingsiK
                                  kingsi
                                  Already said thanks for this plugin before, but felt had to say Tusen Takk!! when it just cleaned out 3million lines lol. Bloody genius
                                  Noobtastic
                                    πŸ‘ πŸ˜„
                                    • K
                                      kandehalux
                                      dang it....sorry for bothering, love your plugins!
                                      now a problem occured with the installation of cleanup:
                                      the TT_Lib2 is in the Plugins folder, the cleanup.rb is in the plugins folder.
                                      but when starting up sketchup i get this message:
                                      Error Loading File tt_cleanup.rb
                                      uninitialized constant TT::GUI
                                      in the forum i found suggestions with missing dlls on various windows, but no change. other plugins work fine.
                                      I'm on Win7 x64 using Sketchup 8.0.3117
                                      in addition i have to say,
                                      previously i resetted my pc and of course installed sketchup. before that, cleanup worked like a charme. i still have a backup of the old installation, so i tried using the older version of cleanup and ttlib, but i got the same message.
                                      any idea?
                                        Sounds like TT_LIb2 isn't installed correctly, there should be a TT_Lib2 folder with lots of .rb files in it.
                                        I made a small utility that makes it easier to install plugins correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
                                        I recommend you update to the latest Maintenance Release 3 - it includes several bugfixes etc.
                                        • K
                                          kandehalux
                                          alright, so i updated to the m3 release v8.0.14346 (didnt really notice that it was an actual update due to the version number). the plugins are installed correctly.
                                          in the meantime i found out, that it must have something to do with the template-loader of sketchup. because every plugin loads correctly, when i start directly with an skp-file (even with original template-skps). if i start sketchup without an skp, half of the plugins dont load.
                                            Try running Sketchup 'As Admin' and see if that works - sounds like your permissions are limited - show Bill Gates who's boss ! Windows can treat you like a moron! Of course I'm not suggesting that you are not a moron πŸ˜• πŸ˜‰ Fix your security settings - become an Admin at least...
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 48
                                            • 49
                                            • 30 / 49
