    1.3k Posts 299 Posters 2.5m Views 297 Watching
    • brookefoxB Offline
      brookefox
      I guess there is no way as even if the two arcs are perpendicular to each other it treats them as one.
      ~ Brooke
        brookefox
        I got the profiles distinguished as you said, but have had no success with the sweep, no matter the settings. But it is a complex tool and I do not have a solid grasp of the variables, to say the least. Merci, Fredo.
        ~ Brooke
          brookefox
          It depends on the edge selection you choose (follow or curve) and also you need to click in the empty space to force the separation of the 2 contours since they are contiguous.
          OK, I thought I had tried that. I will now for sure. Thank you. For me a work around is to make it in two moves with 'skinning'. Pic shows the desired and thusly achieved results.
          ~ Brooke
            brookefox
            Cross post from elsewhere to here, where it may be of some use...model here with Fredo's Curviloft tools and TIG's Extrusion Tools.
            ~ Brooke
              artcrazy1313
              Hi Guys
              I am new in this scetchup world and I need some help.
              I am trying to download .rb in my scetchup8. I do everything it was asked and put in scetchup plugin foldr but for some reason nothing comes out.. Please have someone help me out.
              I am also tring to download this .rb for round corners , but cand find a link for download.
                @artcrazy1313 said:
                Hi Guys
                The download link is almost always on the first post in any tools thread [it also has '[Plugin]' at the start of the thread's title]. The Plugins Idex red-button takes you to a page that in turn links off to all plugins available here, and a few elsewhere too...
                Be sure to read the tool's download page - sometimes you need to get and install a help file or a library of helpers [like this tool] that are kept in their own subfolder.
                Be sure to follow the tool's instructions for download, extraction and placement in the Plugins folder.
                If the tool comes in a zip file ensure that the 'loose' files go into the Plugins folder and that any helper files zipped inside a subfolder are put into Plugins still INSIDE that subfolder - never move files around as the tool will break.
                You are on a MAC so ensure you are using the right root-level 'HD' library Plugins folder and NOT a 'user' one...
                There are several helpful threads about installing scripts/plugins - do a forum Search.
                Thomthom has also made a 'Simple Installer' tool [>=v8M2 only] that will automatically install scripts and extract/install from archives of scripts - look for that in the Plugins Index...
                Note that some tools [like this one] are Extensions that need activating [one-time-only] from the Window > Preferences dialog, then the tool's Toolbar probably needs activating from the View...menu item...
                Note also how each tool is activated/used...
                Many new tools do appear in the Plugins-menu... BUT many do not - for example the menu items for this very tool are found in Tools > Fredo Collection > CurviLoft submenu !!!
                • bazB Offline
                  baz
                  Off topic.
                  Tig, you are so patient and helpful. I saw this post and my first thought was has he tried 'search', has he looked at the 'how to download plugins' tut, has he made any effort at all? Or is he a first poster who needs some direction about how to help him/her self
                  I guess what I'm trying to say is that you and others on this forum contribute so much, I worry that you get overloaded with things that don't really help to progress SU.
                  Your call though, I'm inclined to 'tough love' myself.
                    artcrazy1313
                    @tig said:
                    @artcrazy1313 said:
                    Hi Guys
                    First of all I want to thank you for your detail info and your time... As much as I appreciate your help , this is to me a Chinese πŸ˜„
                    I was wondering if we could connect and I gave you permission to enter in my computer and show me how to install this things. I really need your plug ins. They re great. I am willing to pay for your time... thank you..
                      artcrazy1313
                      Fredo this is what I do using scetchup.. very simple cuts ,then it goues to cnc machine ,then hand carving and hand silvering. Your plugins will help me to get curve surfaces..
                        leroy_elroy
                        Hi all,
                        another noob having problems installing to sketchup 8 here. But I have done my research before posting... I have extraced the files and moved them into the plugin folder as described, but upon starting SU the error windows keep coming up.
                        I tried extracting them with winrar, explorer and 7-zip, even tried installing the plugin-finding plugin as suggested in earlier posts, but to no avail.
                        and yes, the latest libfredo plugin is loaded and running fine. I have tried this process at two computers to the same result. Ideas?
                        Also just wanted to say well done for taking a frustratingly basic modelling platform and taking it up to the next level. As somebody who learnt Rhino before SU I've had moments of agony, but this is bringing it up to speed.. Assuming I can get it to work.. I wonder how long before we see the equivelant of Grasshopper and Kangaroo for Rhino.... πŸ˜„
                        • bazB Offline
                          baz
                          Capture.PNGI think you have the files in the wrong place. On my puter the files you show are in Plugins/CURVILOFT_Dir_12
                          You seem to have lost the parent folder.
                            You missed the footprint description:
                            You extracted the content of the CURVILOFT_Dir_12 folder directly into your plugins folder instead of preserving it.
                            I made a small utility plugin to help the installation process: http://forums.sketchucation.com/viewtopic.php?t=42315
                              leroy_elroy
                              derp.
                              I stand corrected, thanks for the help!
                                keith siu
                                HI, I am new. After installation, can't find Curviloft at Tool or plugin. What can I do?
                                  You haven't given us anything to help you with. The first thing is go back and read the first post thoroughly and make sure you did everything right. Did you install the plugin correctly? Does it have the footprint as shown in the first post? Did you install the current version of Libfredo6? Did you look under View>Toolbars for the Curviloft toolbar? Do you find Fredo6 Collection in the Tools menu?
                                  • jgbJ Offline
                                    jgb
                                    Strange one here. It's a simple surface to form, I've done way more complex ones.
                                    When I select all, and hit "Skin" the selects go white and nothing happens. 😲
                                    It does skin manually by joining the vertexes into triangles.
                                    I have redrawn every line, there are no gaps, no fragments, nothing I can see.
                                    If I join any 2 vertices, either side will skin. Remove the join and no skin. πŸ˜•
                                    What's wrong ❓ ❓
                                    BTW, at first I thought it may be an interference with the SimFonIA plugin I just loaded.
                                    But Curviloft worked OK on other more complex surfaces in the same drawing that this shape originated in.
                                    What's wrong here???
                                    jgb
                                      You need to add some 'breakers' to allow Curviloft to read your mind.
                                        Ah damned someone send a similar trick in the same time! πŸ˜„
                                        Just divide this segment and all will works fine! πŸ˜‰
                                        But that is not very normal πŸ˜„
                                        PS If you can save your file in v6, this will be very fine for nostalgic people who don't use V7, v8 β˜€
                                        (i must use some usb keys between computers 😳
                                          [off:3b3ctz5x]We should take up a collection for our poor friend, Pilou. He needs to move into the current century with his computer. I'll donate a graphics card. Does anyone have a spare motherboard? Memory? Hard drive? Etc. πŸ˜„[/off:3b3ctz5x]
                                          • jgbJ Offline
                                            jgb
                                            If you mean those 4 lines at the vertexes, I just tried that, and Pilou's segment break, and still, no skinning. Don't understand why they did not work for me.
                                            In that same model, I just did 3 more similar shapes and the same thing happened. But when I joined any 2 vertexes in those constructs, (as well as the original problem), they skinned normally. So I joined 2 vertices at 1 end to form a triangle, and the rest of the construct skinned when selected.
                                            That made me think Curviloft can't handle 2 or more acute angles. Yep!!!
                                            I moved 1 end vertex in at varying angles.
                                            As soon as the angle was 90 deg or more the construct skinned.
                                            Something for Fredo to look into.
                                            Making 1 angle non-acute
                                            jgb
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 65
                                            • 66
                                            • 33 / 66
