    Mac or pc
    20 Posts 12 Posters 1.9k Views 12 Watching
      deanlegg
      Hi all
      My dell has broken down again, its only a year old
      Can any point me in the direction of some posts for and against macs
      I tried search but couldn't find any
      I see the mac pro runs an ATI card which I thought was a no no
      Also to get the same spec as my pc it would cost $3499!! with no monitors. I already have 2 x 27" screens
      All comments welcome
      Thanks Dean
      • soloS Offline
        This is gonna turn into a Mac vs PC thread.
        My suggestion, stay away from Dell or HP for that matter, stick with Asus.
        Or, get a machine built to spec.
          I see alot of mentions for Asus of late. I've never even seen one over here.
          Are they really that good? Their site isn't very user friendly.
          Funny you say stay away from Dell and HP, my desktop and laptop respectively.
          • EscapeArtistE Offline
            EscapeArtist
            What do you want to use it for outside of SU? If gaming, consider a PC. PCs are much easier to upgrade and add or remove components from with competitive pricing. If you want a good work computer, then get a Mac. They have good stability and usability, but you're generally going to be locked in to the hardware and Mac software (even though you can run Windows on a Mac, but for that matter you can create a mac clone and run OSX on a PC too).
            Whatever works for you. I'm not a fanboy of either of them, they both have their place. My house has i-devices and PCs both. I just prefer the PC for the aforementioned reasons; I can multi-boot linux flavors and windows versions and replace any component as necessary for an upgrade within the limitations of the motherboard. You can make it as powerful or as efficient as you like. With a self-built PC, the upgrade costs decrease after the first build. The LCD monitor, CD/DVD, HDD drives and case can almost always be cannibalized for the next system. Often the sound card (if not built-in) and power supply can be as well (if a high quality one was purchased initially). That leaves only the CPU, motherboard, GPU and memory for each upgrade. A considerable savings. My last build for internal components was less than $1000 for an i7, 24 GB mem, 1TB HDD and a GTX570. The rest of the parts were salvage.
            If I had to buy a pre-built system, I have also heard that ASUS is OK, and my folks have an HP that works very well. You'll likely need to go through and uninstall any pre-installed trial or other software by the manufacturer, there's usually plenty of it and it has nothing to do with making your computer work.
            JMO.
            • jeff hammondJ Offline
              they're switching back to nvidia again.. hang on a couple of weeks if you decide on a mac..
                for once I'm really interested to see what they do with the Macbook Pro. Recent exposure to Macs has perked my interested but always it's a price problem. Very hard to stomach paying out all that cash knowing I can get way more grunt in a PC.
                  latest rumors (well, in this case, suspected controlled leaks via apple themselves which they do from time to time)
                  β€’ a Retina 15.4-inch display at 2880x1800 resolution for a density of 220 pixels per inch
                  β€’ adoption of macbook air form factor :
                  "This will include new, ultra-thin unibody enclosures that jettison yesteryear technologies like optical disk drives and traditional hard drives in favor of models with lightweight chassis that employ flash-memory based solid-state drives, instant-on capabilities, extended battery life, and rely on digital distribution for software and media. "
                  β€’ Nvidia GeForce GT 650M
                  β€’ base cpu -- Intel Ivy Bridge Core i7-3820QM quad-core processor running at 2.7 GHz (with an upgrade option)
                  β€’ USB 3.0 (along with thunderbolt)
                  expected to be announced at WWDC june11-15
                  • E Offline
                    Ecuadorian
                    Buy a Mac. This way you won't be able to compete with me (I use some Windows-only software) unless you install Bootcamp + Windows 7.
                    -Miguel Lescano
                      That is the eternal problem between these 2 monsters πŸ’š
                      [flash=560,315:1e1l0vyy]http://www.youtube.com/v/uLbJ8YPHwXM[/flash:1e1l0vyy]
                      • fuzzionF Offline
                        fuzzion
                        PC for desktop, Mac and Asus with extended warranty for Laptop.
                        Most software is designed around Windows. You can boot windows on a Mac, so the issue is preference and cost.
                        "Only the dead have seen the end of war" - Plato
                        • bmikeB Offline
                          bmike
                          having just moved from a dell 'mobile' workstation (17"m6400) to a 17" macbook pro, i can't say that i'm missing anything. i do have bootcamp loaded with parallels for some topo software and accounting software that i didn't want to have to shutdown and reboot for. and i can always direct boot into win7 if i need to do anything more than check plans in auto cad (don't want to drop the $$ for a new mac license... and the don't swap licenses for you)
                          i don't 'game'.
                          i sketchup / layout and (less and less) autocad.
                          photo process, organize, write, blog, etc.
                          web, movies, music, etc.
                          i've dipped a toe into rendering, but if that was a huge part of my workflow i'd probably set up a cheap PC box to crunch the numbers, and keep the mac laptop as my main design tool.
                          for me, as i work mobile a lot, i lost 6-8 pounds out of my kit from the old machine and power 'brick' just moving to the new machine, and was able to stick with a 17", as i'm often on the road and wanted the screen real estate (almost went 15, and would likely do that if / when they go retina).
                          and i'm hooked on the magic trackpad, gestures, and overall stability and speed (i'm sure one can achieve this with a win machine, but after ... 12 years i'm glad to be back on a nice piece of hardware and software)
                          if you want a mac, hold off on until they make some announcements. you might see some cool new stuff, or you might see prices drop on existing stock.
                          but, if you game, render, have tons of software PC only, well, then you are probably looking PC.
                            deanlegg
                            You guys have confirmed my thoughts and I think I will stick with pc
                            Basically I only use it for SU and downloading
                            I never meant to start a war πŸ‘Š just wanted people's thoughts
                            Solo ( and others) what spec do you run on your machine?
                            Cheers all
                            • Paul RussamP Offline
                              Paul Russam
                              I have PC's at work and Mac's at home, I love my iMac, my MacBook Pro, my iPhone and my iPad but I HATE SKETCHUP ON THE MAC πŸ‘Ώ
                              For 90% of the apps that run on both PC's and Mac's I think the Mac versions are 'nicer' to use but SU is in the remaining 10% (Welllll in there). I've got Parallels VM with Win7 installed just to use SU at home.
                              Unless you really really want a Mac I'd stick with a Win7 PC........
                              and a good virus checker πŸ˜„
                              Paul Russam
                              English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                tim
                                Well, yes and no. You'd be amazed how much software is written by people that know how to do a good job on both. And, for a $50 or so purchase of Parallels or VMWare you can run Windows (and linuxes, whatever) at the same time as OS X. It's not at all difficult to run TurboCAD under Windows at the same time as SU under OS X and gimp under Ubuntu. For work I've occasionally had three or four versions of Windows running at the same time to compare some app's behaviour. Mostly it reminds me why I dislike OS X less than I dislike Windows but that's neither here nor there right now.
                                  tim
                                  What problems do you have to make you so annoyed with it? Since I use SU on an iMac I'd be interested to know what you think I'm suffering from...
                                  • fuzzionF Offline
                                    fuzzion
                                    Cheers all
                                    27 inch led screen
                                    4ghz oc i7 intel
                                    460gtx sli
                                    6gb triple channel ram
                                    256gb intel ssd
                                    razor mouse
                                    • Mike LuceyM Offline
                                      Mike Lucey
                                      On balance Josh, for what you intend to use the computer for, I think you are probably making the right choice.
                                      I use a MBP 17" and it suits my needs. However I also think SU somehow is more ...... Mmmmm ..... what's the word I'm looking for?
                                      Got it! More 'businesslike' on a PC.
                                      Here is a fairly well balanced Pro / Con review, okay the Mac wins, but only just πŸ˜‰
                                      Mac vs PC - Pros & Cons Comparison Review
                                      digitalphotographywriter.com
                                      (www.digitalphotographywriter.com)
                                      BTW, we like the occasional War around here πŸ‘
                                      • soloS Offline
                                        Mike, read some of the comments and you will see that this is not an "unbiased" review, especially when it comes to hardware. I'm not buying this as credible.
                                        • bmikeB Offline
                                          bmike
                                          Find me a tech writer who is unbiased and I'll ...
                                            Mike Lucey
                                            I stand corrected πŸ˜„
