    You ever have a shape in your head...
    41 Posts 13 Posters 3.3k Views 13 Watching
    • jeff hammondJ
      yeah starling.. something more along those lines (not blobby etc)
      funny you posted that because my shape is spiral as well..
      actually 2 of them interacting.
      • gillesG
        gilles
        Tell us more, we want to know! πŸŽ‰
        • jeff hammondJ
          I sort of just figured it out on the train..
          the red line is a helix on its side.. the black is a line along the ground..
          then theres a surface created between the two..
          it gets a little more tech than that so it will be functional but I think this is the gist of it..
          I'll try modeling it a little later..
          http://db.tt/yLH2k6ZH
          edit.. so maybe the Dropbox link doesn't embed.. try:
            Here the image of the Jeff helix tricky project πŸ˜„
            Without more info it's some difficult to see something πŸ˜„
            Maybe a start ? πŸ˜„
            http://www.monkeychoo.com/wp-content/uploads/2012/02/helice.jpg
              Is the helix projecting itself on the ground and this is rotated?
              Here's my 2 cents....
              Jeff_Weird_Drawing.skp
              It's like Being John Malkovich
              • brookefoxB
                brookefox
                @starling75 said:
                .. keep it simple πŸ˜‰
                "Initially, no definite geometry for the shells had been established, but, as work progressed, the shells were developed according to a spherical geometry and we suddenly had a common denominator, the same spherical surface to deal with, with a similar curvature throughout.
                This was an elegant solution to a construction...
                Jorn Utzon
                https://lh4.googleusercontent.com/-MWoj-Pfx3-8/T7vqLdLbCyI/AAAAAAAAE1U/Tj18-TamWgQ/s585/UTZON.jpg
                That sounds really nice, but is fairly typical isn't it, as a goal and a practice? Consistent geometry, prefab. ... He's kind of over-blowing it a bit, but certainly a good sell and a wonderful image.
                Nice link and read. Thanks.
                ~ Brooke
                • jeff hammondJ
                  [attachment=0:3ij5gepn]<!-- ia0 -->Jeff_Weird_Drawing.skp<!-- ia0 -->[/attachment:3ij5gepn]
                  screenshot or SU for iPhone please..
                  whichever is easiest πŸ˜‰
                    • GaieusG
                      I also often have similar shapes in my head, Rich, but my wife keeps slapping me at the back of my head when I do. πŸ˜’
                      • jeff hammondJ
                        @rich o brien said:
                        [attachment=0:buqmaum4]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:buqmaum4]
                        hmm.. maybe that's not it
                        actually. I think it is but your version has the projected helix rotated too much.
                        fwiw, the actual shape i need is to be cut out of the surface.. much in the same way the opera house was cut from a sphere.. I just have to figure out some logic behind the main shape so I can figure out how to build this..
                        fwiw2.. I haven't actually been commissioned to build this thing.. if I can make the model and it ends up being as cool as the original momentofinspiration, then I'm gonna try to sell it. πŸ’š
                        edit- fwiw3.. the red/black sketched image pilou posted is the top view.. looking at it with that in mind, you'll see the twist I'm (i think) going for..
                          I rotated it 90 because your brainwaves don't stretch across the Atlantic... πŸ˜’
                          • jeff hammondJ
                            haha..
                            don't get me wrong, your drawing helps me see more clearly what I'm after so thanks for posting it.
                              Attempt #2
                              rotation lessened
                              • jeff hammondJ
                                @rich o brien said:
                                [attachment=0:2p45tc8v]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:2p45tc8v]
                                Attempt #2
                                rotation lessened
                                heh.. I think that's almost it.. the helix should touch the ground though. (the two lowest points of the helix-- resulting in the two end profile lines being on a horizontal plane.
                                I'm about 20 minutes away from a computer.. itching to try it myself now
                                  I've just patented the design so it'll cost you.
                                    • jeff hammondJ
                                      ha.. wouldn't be the first time that's happened πŸ˜’
                                      πŸ˜‰
                                      so i drew the thing as in the sketch and it's not quite right yet.. (and #$%#@ing SU crashed prior to me saving the rough go)… but definitely getting closer.. still thinking about using clay..
                                      gonna try the crayola stuff marcus is talking about.. thanks for the info on that stuff d12dozr!
                                        i wouldn't do a 'dug' on you. I'm a bketterman than that.
                                        • mitcorbM
                                          mitcorb
                                          who is bketterman?
                                            @mitcorb said:
                                            who is bketterman?
                                            @Tim
                                            spellcheck acting up
                                            • 2 / 3
