    You ever have a shape in your head...
    41 Posts 13 Posters 3.3k Views 13 Watching
    • soloS
      Q: You ever have a shape in your head....?
      A:
      http://1morefilmblog.com/wordpress/wp-content/uploads/2010/07/closeencounters1.jpg
      Looks better made of mashed potatoes.
      • bmikeB
        bmike
        this thread sucks without pics.
        can you post your model or a sketch or something so we can comment on it?
        oh wait, never mind.
        what about an MRI scan?
        πŸ˜‰
        yeah, i often have shape things stuck in my head, doodled on a napkin, or whatever.
        sometimes they are far better in my imagination.
        sometimes far nicer when i work them out in 3d.
          ? πŸ’š
          http://www.ladepeche.fr/content/photo/biz/2008/02/04/gilles-balmet-test-accrochage-ro_zoom.jpg
          http://www.identifont.com/samples/delve-fonts/BlotTest.gif
            Starling75
            .. keep it simple πŸ˜‰
            "Initially, no definite geometry for the shells had been established, but, as work progressed, the shells were developed according to a spherical geometry and we suddenly had a common denominator, the same spherical surface to deal with, with a similar curvature throughout.
            This was an elegant solution to a construction, which would otherwise have had to be done with a large amount of scaffolding and shuttering, both for the interior and exterior shape of the shells.
            Now the shells could be sub-divided into ribs, which again could be divided into smaller elements, which could be cast within formwork representing the largest rib entity. Thus it was possible to pre-cast the concrete-shells in smaller pieces and assemble these pieces on location. ..."
            Jorn Utzon
            ERROR: The request could not be satisfied
            (www.sydneyoperahouse.com)
            https://lh4.googleusercontent.com/-MWoj-Pfx3-8/T7vqLdLbCyI/AAAAAAAAE1U/Tj18-TamWgQ/s585/UTZON.jpg
            http://www.starlingarch.cz
            • jeff hammondJ
              yeah starling.. something more along those lines (not blobby etc)
              funny you posted that because my shape is spiral as well..
              actually 2 of them interacting.
              • gillesG
                gilles
                Tell us more, we want to know! πŸŽ‰
                • jeff hammondJ
                  I sort of just figured it out on the train..
                  the red line is a helix on its side.. the black is a line along the ground..
                  then theres a surface created between the two..
                  it gets a little more tech than that so it will be functional but I think this is the gist of it..
                  I'll try modeling it a little later..
                  http://db.tt/yLH2k6ZH
                  edit.. so maybe the Dropbox link doesn't embed.. try:
                    Here the image of the Jeff helix tricky project πŸ˜„
                    Without more info it's some difficult to see something πŸ˜„
                    Maybe a start ? πŸ˜„
                    http://www.monkeychoo.com/wp-content/uploads/2012/02/helice.jpg
                      Is the helix projecting itself on the ground and this is rotated?
                      Here's my 2 cents....
                      Jeff_Weird_Drawing.skp
                      It's like Being John Malkovich
                      • brookefoxB
                        brookefox
                        This was an elegant solution to a construction...
                        Jorn Utzon
                        That sounds really nice, but is fairly typical isn't it, as a goal and a practice? Consistent geometry, prefab. ... He's kind of over-blowing it a bit, but certainly a good sell and a wonderful image.
                        Nice link and read. Thanks.
                        ~ Brooke
                        • jeff hammondJ
                          [attachment=0:3ij5gepn]<!-- ia0 -->Jeff_Weird_Drawing.skp<!-- ia0 -->[/attachment:3ij5gepn]
                          screenshot or SU for iPhone please..
                          whichever is easiest πŸ˜‰
                            • GaieusG
                              I also often have similar shapes in my head, Rich, but my wife keeps slapping me at the back of my head when I do. πŸ˜’
                              • jeff hammondJ
                                @rich o brien said:
                                [attachment=0:buqmaum4]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:buqmaum4]
                                hmm.. maybe that's not it
                                actually. I think it is but your version has the projected helix rotated too much.
                                fwiw, the actual shape i need is to be cut out of the surface.. much in the same way the opera house was cut from a sphere.. I just have to figure out some logic behind the main shape so I can figure out how to build this..
                                fwiw2.. I haven't actually been commissioned to build this thing.. if I can make the model and it ends up being as cool as the original momentofinspiration, then I'm gonna try to sell it. πŸ’š
                                edit- fwiw3.. the red/black sketched image pilou posted is the top view.. looking at it with that in mind, you'll see the twist I'm (i think) going for..
                                  I rotated it 90 because your brainwaves don't stretch across the Atlantic... πŸ˜’
                                  • jeff hammondJ
                                    haha..
                                    don't get me wrong, your drawing helps me see more clearly what I'm after so thanks for posting it.
                                      Attempt #2
                                      rotation lessened
                                      • jeff hammondJ
                                        @rich o brien said:
                                        [attachment=0:2p45tc8v]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:2p45tc8v]
                                        Attempt #2
                                        rotation lessened
                                        heh.. I think that's almost it.. the helix should touch the ground though. (the two lowest points of the helix-- resulting in the two end profile lines being on a horizontal plane.
                                        I'm about 20 minutes away from a computer.. itching to try it myself now
                                          I've just patented the design so it'll cost you.
                                            • 1 / 3
