    You ever have a shape in your head...
    41 Posts 13 Posters 2.3k Views 13 Watching
      ? πŸ’š
      http://www.ladepeche.fr/content/photo/biz/2008/02/04/gilles-balmet-test-accrochage-ro_zoom.jpg
      http://www.identifont.com/samples/delve-fonts/BlotTest.gif
        Starling75
        .. keep it simple πŸ˜‰
        "Initially, no definite geometry for the shells had been established, but, as work progressed, the shells were developed according to a spherical geometry and we suddenly had a common denominator, the same spherical surface to deal with, with a similar curvature throughout.
        This was an elegant solution to a construction, which would otherwise have had to be done with a large amount of scaffolding and shuttering, both for the interior and exterior shape of the shells.
        Now the shells could be sub-divided into ribs, which again could be divided into smaller elements, which could be cast within formwork representing the largest rib entity. Thus it was possible to pre-cast the concrete-shells in smaller pieces and assemble these pieces on location. ..."
        Jorn Utzon
        Page not found
        Sydney Opera House (www.sydneyoperahouse.com)
        https://lh4.googleusercontent.com/-MWoj-Pfx3-8/T7vqLdLbCyI/AAAAAAAAE1U/Tj18-TamWgQ/s585/UTZON.jpg
        http://www.starlingarch.cz
        • jeff hammondJ Offline
          yeah starling.. something more along those lines (not blobby etc)
          funny you posted that because my shape is spiral as well..
          actually 2 of them interacting.
          • gillesG Offline
            gilles
            Tell us more, we want to know! πŸŽ‰
              I sort of just figured it out on the train..
              the red line is a helix on its side.. the black is a line along the ground..
              then theres a surface created between the two..
              it gets a little more tech than that so it will be functional but I think this is the gist of it..
              I'll try modeling it a little later..
              http://db.tt/yLH2k6ZH
              edit.. so maybe the Dropbox link doesn't embed.. try:
                Here the image of the Jeff helix tricky project πŸ˜„
                Without more info it's some difficult to see something πŸ˜„
                Maybe a start ? πŸ˜„
                http://www.monkeychoo.com/wp-content/uploads/2012/02/helice.jpg
                  Is the helix projecting itself on the ground and this is rotated?
                  Here's my 2 cents....
                  Jeff_Weird_Drawing.skp
                  It's like Being John Malkovich
                  • brookefoxB Offline
                    brookefox
                    This was an elegant solution to a construction...
                    Jorn Utzon
                    That sounds really nice, but is fairly typical isn't it, as a goal and a practice? Consistent geometry, prefab. ... He's kind of over-blowing it a bit, but certainly a good sell and a wonderful image.
                    Nice link and read. Thanks.
                    ~ Brooke
                      [attachment=0:3ij5gepn]<!-- ia0 -->Jeff_Weird_Drawing.skp<!-- ia0 -->[/attachment:3ij5gepn]
                      screenshot or SU for iPhone please..
                      whichever is easiest πŸ˜‰
                          I also often have similar shapes in my head, Rich, but my wife keeps slapping me at the back of my head when I do. πŸ˜’
                            @rich o brien said:
                            [attachment=0:buqmaum4]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:buqmaum4]
                            hmm.. maybe that's not it
                            actually. I think it is but your version has the projected helix rotated too much.
                            fwiw, the actual shape i need is to be cut out of the surface.. much in the same way the opera house was cut from a sphere.. I just have to figure out some logic behind the main shape so I can figure out how to build this..
                            fwiw2.. I haven't actually been commissioned to build this thing.. if I can make the model and it ends up being as cool as the original momentofinspiration, then I'm gonna try to sell it. πŸ’š
                            edit- fwiw3.. the red/black sketched image pilou posted is the top view.. looking at it with that in mind, you'll see the twist I'm (i think) going for..
                              I rotated it 90 because your brainwaves don't stretch across the Atlantic... πŸ˜’
                                haha..
                                don't get me wrong, your drawing helps me see more clearly what I'm after so thanks for posting it.
                                  Attempt #2
                                  rotation lessened
                                    @rich o brien said:
                                    [attachment=0:2p45tc8v]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:2p45tc8v]
                                    Attempt #2
                                    rotation lessened
                                    heh.. I think that's almost it.. the helix should touch the ground though. (the two lowest points of the helix-- resulting in the two end profile lines being on a horizontal plane.
                                    I'm about 20 minutes away from a computer.. itching to try it myself now
                                      I've just patented the design so it'll cost you.
                                          ha.. wouldn't be the first time that's happened πŸ˜’
                                          πŸ˜‰
                                          so i drew the thing as in the sketch and it's not quite right yet.. (and #$%#@ing SU crashed prior to me saving the rough go)… but definitely getting closer.. still thinking about using clay..
                                          gonna try the crayola stuff marcus is talking about.. thanks for the info on that stuff d12dozr!
                                            i wouldn't do a 'dug' on you. I'm a bketterman than that.
                                            • 1 / 3
