    You ever have a shape in your head...
    41 Posts 13 Posters 3.3k Views 13 Watching
      d12dozr
      .. I think I'm going to try it with clay..
      That's actually a great idea. I just finished a project for a client who made a model out of clay for me to work from for the Sketchup model. He got the clay model as close as he could, then took Top, Side, Front, and Back photos. He took those photos into Photoshop, tweaked them til they were perfect, added dims and specs, and I used those as the blueprints for modeling.
      The final model was 3D printed, and the client was super happy how close it was to his concept. I bet that process halved the cost of the project for him, especially because there was hardly a straight line in the model so conventional plans were hard to make.
      ...a little different situation than yours, but hey, it might help.
      http://goo.gl/f7ooYh
        The only thing to think with this crazzy free Sculptris, is make all the symmetric before
        then no symmetric after! πŸ€“
        By Barry Croucher
        http://www.pixologic.com/sculptris/img/img01.jpg
        • jeff hammondJ
          im not sure sculptris and the like will help me in this situation..
          I guess the shape could be considered organic but not like a body..
          it has to have a consistent thickness and be measurable/build-able. (ie-- drawn in sketchup or rhino)
          clay should be able to help me out.. plus it seems like it might be fun to mess around with πŸ˜‰
          • brookefoxB
            brookefox
            Give us something more to work with,
            a snapshot of your mind-image,
            carefully cropped.
            ~ Brooke
              How about if you draw it in sketchUp so we can see it? Maybe someone will be able to help you draw it. πŸ˜„
                d12dozr
                Here's the clay my client used: Crayola Model Magic. It was nicer than modeling clay - lighter and cleaner. He says:
                I would stay away from the Model Magic Fusion. Some of the speckles are too big and nasty. Especially stay away from the Model Magic Fusion Black.
                • soloS
                  Q: You ever have a shape in your head....?
                  A:
                  http://1morefilmblog.com/wordpress/wp-content/uploads/2010/07/closeencounters1.jpg
                  Looks better made of mashed potatoes.
                  • bmikeB
                    bmike
                    this thread sucks without pics.
                    can you post your model or a sketch or something so we can comment on it?
                    oh wait, never mind.
                    what about an MRI scan?
                    πŸ˜‰
                    yeah, i often have shape things stuck in my head, doodled on a napkin, or whatever.
                    sometimes they are far better in my imagination.
                    sometimes far nicer when i work them out in 3d.
                      ? πŸ’š
                      http://www.ladepeche.fr/content/photo/biz/2008/02/04/gilles-balmet-test-accrochage-ro_zoom.jpg
                      http://www.identifont.com/samples/delve-fonts/BlotTest.gif
                        Starling75
                        .. keep it simple πŸ˜‰
                        "Initially, no definite geometry for the shells had been established, but, as work progressed, the shells were developed according to a spherical geometry and we suddenly had a common denominator, the same spherical surface to deal with, with a similar curvature throughout.
                        This was an elegant solution to a construction, which would otherwise have had to be done with a large amount of scaffolding and shuttering, both for the interior and exterior shape of the shells.
                        Now the shells could be sub-divided into ribs, which again could be divided into smaller elements, which could be cast within formwork representing the largest rib entity. Thus it was possible to pre-cast the concrete-shells in smaller pieces and assemble these pieces on location. ..."
                        Jorn Utzon
                        ERROR: The request could not be satisfied
                        (www.sydneyoperahouse.com)
                        https://lh4.googleusercontent.com/-MWoj-Pfx3-8/T7vqLdLbCyI/AAAAAAAAE1U/Tj18-TamWgQ/s585/UTZON.jpg
                        http://www.starlingarch.cz
                        • jeff hammondJ
                          yeah starling.. something more along those lines (not blobby etc)
                          funny you posted that because my shape is spiral as well..
                          actually 2 of them interacting.
                          • gillesG
                            gilles
                            Tell us more, we want to know! πŸŽ‰
                            • jeff hammondJ
                              I sort of just figured it out on the train..
                              the red line is a helix on its side.. the black is a line along the ground..
                              then theres a surface created between the two..
                              it gets a little more tech than that so it will be functional but I think this is the gist of it..
                              I'll try modeling it a little later..
                              http://db.tt/yLH2k6ZH
                              edit.. so maybe the Dropbox link doesn't embed.. try:
                                Here the image of the Jeff helix tricky project πŸ˜„
                                Without more info it's some difficult to see something πŸ˜„
                                Maybe a start ? πŸ˜„
                                http://www.monkeychoo.com/wp-content/uploads/2012/02/helice.jpg
                                  Is the helix projecting itself on the ground and this is rotated?
                                  Here's my 2 cents....
                                  Jeff_Weird_Drawing.skp
                                  It's like Being John Malkovich
                                  • brookefoxB
                                    brookefox
                                    This was an elegant solution to a construction...
                                    Jorn Utzon
                                    That sounds really nice, but is fairly typical isn't it, as a goal and a practice? Consistent geometry, prefab. ... He's kind of over-blowing it a bit, but certainly a good sell and a wonderful image.
                                    Nice link and read. Thanks.
                                    ~ Brooke
                                    • jeff hammondJ
                                      [attachment=0:3ij5gepn]<!-- ia0 -->Jeff_Weird_Drawing.skp<!-- ia0 -->[/attachment:3ij5gepn]
                                      screenshot or SU for iPhone please..
                                      whichever is easiest πŸ˜‰
                                        • GaieusG
                                          I also often have similar shapes in my head, Rich, but my wife keeps slapping me at the back of my head when I do. πŸ˜’
                                          • jeff hammondJ
                                            @rich o brien said:
                                            [attachment=0:buqmaum4]<!-- ia0 -->Jeffrey_Hammond.png<!-- ia0 -->[/attachment:buqmaum4]
                                            hmm.. maybe that's not it
                                            actually. I think it is but your version has the projected helix rotated too much.
                                            fwiw, the actual shape i need is to be cut out of the surface.. much in the same way the opera house was cut from a sphere.. I just have to figure out some logic behind the main shape so I can figure out how to build this..
                                            fwiw2.. I haven't actually been commissioned to build this thing.. if I can make the model and it ends up being as cool as the original momentofinspiration, then I'm gonna try to sell it. πŸ’š
                                            edit- fwiw3.. the red/black sketched image pilou posted is the top view.. looking at it with that in mind, you'll see the twist I'm (i think) going for..
                                            • 1 / 3
