    [Plugin] Honeycomber
    91 Posts 21 Posters 65.2k Views 21 Watching
    • I
      ideas_arte
      @tig said:
      It is for v8-Pro only.
      😳 "Free" users will have any chance of using this excellent tool?
      Best regards!
        v8-Pro only because it uses several API techniques only accessible to Pro - sorry...
          Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=395061#p395061
          The speed has been improved by ~4x.
          The 'shell' version still takes ~4x longer than an un-shelled version because of the many extra steps required - but while ~15 minutes is worse that ~4minutes, it is better than ~60 minutes !!
          Some minor glitches have also been fixed with 3-sided setting out centrally.
          • I
            ideas_arte
            @tig said:
            sorry...
            I understand. 😒 Thank you for all the good work. My best wishes for you
            • guanjinG
              guanjin
              Thank of TIG: Speed ​​is the key, to test the new file。
                dtolios
                Amazing work, great potential for this tool...
                Unfortunately is too slow for some of the complex shapes I had in mind, but I have trust that it will get better overtime (and yeah, my mobile i7 is not the fastest processor anyways...)
                • charly2008C
                  charly2008
                  TIG, you have once again created a surprising and promising tool. Thank you.
                    SUFractal
                    I'm curious as to how long it took you to create this?
                      I reproduced it [badly!]
                      • EscapeArtistE
                        EscapeArtist
                        Just tried the updated version. Very nice, considerably faster!
                        • T
                          thraxx2
                          Hi everyone, i just need a little help here, trying to model up something which I can't. So here it goes:
                          1. I used honeyecomber to get the normal triangle tessellation. (first image)
                          2. I want to bend it and shape it like this! (second image)
                          I have been trying lots of ways i can think of but to no avail. thanks guys!
                          Gerald.
                          • JBJDesignsJ
                            JBJDesigns
                            Hi TIG!
                            What an awesome tool! Unfortunately, I'm stuck with SketchUp8 (free). Is there anyway to make this tool work in the free version. If not, I understand.
                            Thanks for replying!
                            Jo 😄
                            ...you send them to school, you give them books, and they eat the pages...
                            • cottyC
                              cotty
                              The plugin uses solid functions, which are only available in the PRO version. So I think there will be no (simple and practicable) way for him to change this...
                              my SketchUp gallery
                              • OxerO
                                Oxer
                                Hi TIG,
                                After much time with the problem on Mac, I can say you the plugin works fine!!
                                Thanks for the update. 👍
                                  Skutvik
                                  Hi TIG,
                                  is there any way not pro users can get this pluggin?
                                    slave
                                    any updates to get this plugin to work with SU2017?
                                    Regards
                                    Slave
                                      Version 2017 has wrecked many plugins, it handles group referencing / exploding etc differently !
                                      Bad news here with the 'shell' option...
                                      I'll have a look at recoding parts of it, when I can - it should be fixable, but I am busy...
                                        Here's version 2.0
                                        http://sketchucation.com/forums/viewtopic.php?p=395061#p395061
                                        Please [re]read the notes which have changed slightly...
                                        It should now work with all versions of SketchUp >=v8 - please remember this is a PRO only tool !
                                        It is also 'signed' for full compatibility with the newer versions of SketchUp under all of their loading policies...
                                        Then get/install the latest RBZ from the PluginStore using the 'download' link button...https://sketchucation.com/pluginstore?pln=TIG_HoneycomberOr use the ExtensionStore³ dialog to auto-install it for you...
                                        • H
                                          harlour
                                          Hello TIG,
                                          Trying to use the plugin in SKP2018/mac. Placing the least possible parameters but the plugin doesn't work. I stays frozen in TIG::Honecomber:Parameters and I get the wheel of death like forever...
                                          Any idea?
                                            I just tested it in SU2019 and it works as expected. Perhaps if you share your model we can give you some help to tell you what the problem is. You could also try it with a very simple shape and see if you get a different result.
