    [Plugin] Honeycomber
    91 Posts 21 Posters 65.2k Views 21 Watching
    • guanjinG
      guanjin
      @tig said:
      Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=395061#p395061
      The speed has been improved by ~4x.
      The 'shell' version still takes ~4x longer than an un-shelled version because of the many extra steps required - but while ~15 minutes is worse that ~4minutes, it is better than ~60 minutes !!
      Some minor glitches have also been fixed with 3-sided setting out centrally.
      Thank of TIG: Speed ​​is the key, to test the new file。
        dtolios
        Amazing work, great potential for this tool...
        Unfortunately is too slow for some of the complex shapes I had in mind, but I have trust that it will get better overtime (and yeah, my mobile i7 is not the fastest processor anyways...)
        • charly2008C
          charly2008
          TIG, you have once again created a surprising and promising tool. Thank you.
            SUFractal
            I'm curious as to how long it took you to create this?
              I reproduced it [badly!]
              • EscapeArtistE
                EscapeArtist
                Just tried the updated version. Very nice, considerably faster!
                • T
                  thraxx2
                  Hi everyone, i just need a little help here, trying to model up something which I can't. So here it goes:
                  1. I used honeyecomber to get the normal triangle tessellation. (first image)
                  2. I want to bend it and shape it like this! (second image)
                  I have been trying lots of ways i can think of but to no avail. thanks guys!
                  Gerald.
                  • JBJDesignsJ
                    JBJDesigns
                    Hi TIG!
                    What an awesome tool! Unfortunately, I'm stuck with SketchUp8 (free). Is there anyway to make this tool work in the free version. If not, I understand.
                    Thanks for replying!
                    Jo 😄
                    ...you send them to school, you give them books, and they eat the pages...
                    • cottyC
                      cotty
                      The plugin uses solid functions, which are only available in the PRO version. So I think there will be no (simple and practicable) way for him to change this...
                      my SketchUp gallery
                      • OxerO
                        Oxer
                        Hi TIG,
                        After much time with the problem on Mac, I can say you the plugin works fine!!
                        Thanks for the update. 👍
                          Skutvik
                          Hi TIG,
                          is there any way not pro users can get this pluggin?
                            slave
                            any updates to get this plugin to work with SU2017?
                            Regards
                            Slave
                              Version 2017 has wrecked many plugins, it handles group referencing / exploding etc differently !
                              Bad news here with the 'shell' option...
                              I'll have a look at recoding parts of it, when I can - it should be fixable, but I am busy...
                                Here's version 2.0
                                http://sketchucation.com/forums/viewtopic.php?p=395061#p395061
                                Please [re]read the notes which have changed slightly...
                                It should now work with all versions of SketchUp >=v8 - please remember this is a PRO only tool !
                                It is also 'signed' for full compatibility with the newer versions of SketchUp under all of their loading policies...
                                Then get/install the latest RBZ from the PluginStore using the 'download' link button...https://sketchucation.com/pluginstore?pln=TIG_HoneycomberOr use the ExtensionStore³ dialog to auto-install it for you...
                                • H
                                  harlour
                                  Hello TIG,
                                  Trying to use the plugin in SKP2018/mac. Placing the least possible parameters but the plugin doesn't work. I stays frozen in TIG::Honecomber:Parameters and I get the wheel of death like forever...
                                  Any idea?
                                    I just tested it in SU2019 and it works as expected. Perhaps if you share your model we can give you some help to tell you what the problem is. You could also try it with a very simple shape and see if you get a different result.
                                    • 5 / 5
