    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
    • Didier BurD
      Didier Bur
      Hi Fredo,
      Thanks for all your huge work and for sharing it with the community.
      I'll just warn users of this library NOT to install it with a Ctrl-A and then drag-drop the files in their Plugins folder. Doing the extraction this way DOESN't create any folder structure and obiously generates errors when loading the library and plugin.
      The safer (and only) way is to select "Extract" in Winzip, point to the correct folder and tick "use folder structure" checkbox.
      Now back to removing my 148 wrongly located files ๐Ÿคฃ
      DB
        I've always done that - using Windows' native archive feature. Never had any problems.
        • fredo6F
          @didier bur said:
          Hi Fredo,
          Didier,
          Normally, what I say is:
          • Select all files (Ctrl A)
          • Extract to the destination folder (i.e. not 'drag and drop')
          • Answer Yes to overwrite files
          Drag and Drop requires, as you say, to make sure Winzip option to use folder structure is On.
          • Didier BurD
            Didier Bur
            Sorry Fredo, my mistake ๐Ÿ˜ณ
            DB
            • fredo6F
              NEW RELEASE: LibFredo6 v4.4m - 14 Apr 12
              LibFredo6 4.4 is a new release which essentially support the publishing of ThruPaint and ReverseOrientFaces as part of FredoTools
              This small update fixes some issues in ThruPaint and integrate the translation to Spanish (Defisto, Oxer) and Chinese (guanjin)
              • N
                nphong63
                thank you!
                • K
                  kespencer1
                  Hey y'all. I need some help. For whatever reason, LibFredo6 plugin is starting to crash Sketchup. (Yes I know it's this one because I systematically went through and tested sketchup with each plugin I have.)Anyone know a fix for it?
                  Now that I think about it, it MAY be something that it activates. All I really know is that if I delete it, Sketchup doesn't crash. But then I can't use curveloft and whatnot. ANY help is appreciated.
                    3deeidee
                    the round corner tool seems like something i would use a lot. Unfortunatly i cannot get it to work properly. I have downloaded the LibFredo6 and placed it in the plugin folder (that is the .rb and the folder) and i also downloaded the round corner tool and also placed it in the plugin folder (the .rb and the folder). As i understand correctly it should then work. But nothing happens when i open SU. I'm working on a mac with SU7 pro.
                    Ruud
                      Assuming the file/folders were extracted 'intact' and then put into the correct Plugins folder [Macintosh HD/...Lib/.../plugins] and not a spurious 'User' one... then a restart of Sketchup should auto-load the tool for you.
                      However, like many such tools this is an Extension and so it needs a one off activation, which is done through Preferences > Extensions.
                      Once it is activated its menu items and toolbar becomes available to you - if it hasn't auto-activated then the toolbar can be activated from the appropriate menu item too...
                        Are you sure it's installed properly - file and folder ?
                        Do you have the latest version ?
                        • fredo6F
                          NEW RELEASE: LibFredo6 v4.5a - 08 May 12
                          LibFredo6 4.5 is a update dedicated to
                          • Some evolutions in ThruPaint 1.2 (paint container and text, as well as bug fixing)
                          • New features for the Free Rotate tool of FredoScale (rotation with offset and inference on line)
                            jooooe
                            sorry! this is not suit for Mac?
                              What makes you think that? It works fine on my Mac as well as many others.
                              • I
                                ihanna
                                NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
                                Needed for for FreeScale 2.0c
                                see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                                Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
                                hello,
                                I just want to ask some help, I've already download those files twice but still not working, can you give me some advice? Thanks in advance.
                                You must be the change you wish to see in the world. โ€”Gandhi
                                  @ihanna said:
                                  hello,
                                  You have to meet us half way. Give us something to help you out. We can't see your computer from here and you've given us no clue as to what you've done short of downloading the files. ๐Ÿ˜’ Did you extract the zip file into Program Files/ Google/Google SketchUp 8/Plugins? Did you extract them correctly? Do you have admin rights to install files into the Plugins folder?
                                  Post a screen shot of your Plugins folder showing the files installed correctly and we'll go from there.
                                    These files don't do much on there own. ๐Ÿ˜•
                                    They are 'helpers' for many of Fredo's other tools, which don't work without the file and subfolder of files etc that form the 'Lib'... ๐Ÿ˜ฎ
                                    • G
                                      GooUser
                                      Thanks you very lot ! It's Great.
                                      • L
                                        Luaner
                                        Thanks again~โค
                                        • T
                                          the.pjt
                                          hi dear ferdo , I have a little question ...
                                          .. maybe it's a bad question and I know that it takes much time for you to write these features fur us ... thanks a lot for time you spend and offering your incredible codes freely to us ... thanks ferdo ..
                                          my question is
                                          how to disable time tracer and updater part due to have a faster startup and a lighter SU ?
                                          I'm a ruby newbie .. but you codes are too complex for me to trace .. ๐Ÿ˜„ .. I just wanna to know the .rb files that does these extra works ...
                                          I'm sorry for asking these .. I believe that these parts ( specially Updater module )are very useful for all users .. and thanks for codding these parts ferdo .. ๐Ÿ˜›
                                          thanks
                                          • fredo6F
                                            @the.pjt said:
                                            my question is
                                            You don't need to edit the ruby files.
                                            Normally, go to the CheckForUpdate dialog box and enter 999 (days) in the 'next check' field.
                                            PS: 'Check for update' does not go to the Internet when SU Starts. It just checks the date to see if it should display the reminder, so it is very fast. The fact is that that the reminder is based on a WebDialog and the first web dialogs are used, it takes a little bit long (SU may load extra stuff or perform some operations in the background).
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 112
                                            • 113
                                            • 20 / 113
