    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      NEW RELEASE: LibFredo6 v4.4j - 11 Apr 12
      LibFredo6 4.4 is a new release which essentially support the publishing of ThruPaint and ReverseOrientFaces as part of FredoTools
      I also updated the strategy for online documentation. All PDF will now be grouped in a single sub-directory DOCUMENTATION_Dir. The move of file is done automatically for existing plugins. This will allow to keep the documentation regardless of the version of plugins (as I do not update the doc for every release). Also, The Plugin zip files won't include these PDF files any longer (this will make them lighter). Users will have to download the doc from the forum and put it in DOCUMENTATION_Dir folder if they wish.
      • Didier BurD
        Didier Bur
        Hi Fredo,
        Thanks for all your huge work and for sharing it with the community.
        I'll just warn users of this library NOT to install it with a Ctrl-A and then drag-drop the files in their Plugins folder. Doing the extraction this way DOESN't create any folder structure and obiously generates errors when loading the library and plugin.
        The safer (and only) way is to select "Extract" in Winzip, point to the correct folder and tick "use folder structure" checkbox.
        Now back to removing my 148 wrongly located files ๐Ÿคฃ
        DB
          I've always done that - using Windows' native archive feature. Never had any problems.
          • fredo6F
            @didier bur said:
            Hi Fredo,
            Didier,
            Normally, what I say is:
            • Select all files (Ctrl A)
            • Extract to the destination folder (i.e. not 'drag and drop')
            • Answer Yes to overwrite files
            Drag and Drop requires, as you say, to make sure Winzip option to use folder structure is On.
            • Didier BurD
              Didier Bur
              Sorry Fredo, my mistake ๐Ÿ˜ณ
              DB
              • fredo6F
                NEW RELEASE: LibFredo6 v4.4m - 14 Apr 12
                This small update fixes some issues in ThruPaint and integrate the translation to Spanish (Defisto, Oxer) and Chinese (guanjin)
                • N
                  nphong63
                  thank you!
                  • K
                    kespencer1
                    Hey y'all. I need some help. For whatever reason, LibFredo6 plugin is starting to crash Sketchup. (Yes I know it's this one because I systematically went through and tested sketchup with each plugin I have.)Anyone know a fix for it?
                    Now that I think about it, it MAY be something that it activates. All I really know is that if I delete it, Sketchup doesn't crash. But then I can't use curveloft and whatnot. ANY help is appreciated.
                      3deeidee
                      the round corner tool seems like something i would use a lot. Unfortunatly i cannot get it to work properly. I have downloaded the LibFredo6 and placed it in the plugin folder (that is the .rb and the folder) and i also downloaded the round corner tool and also placed it in the plugin folder (the .rb and the folder). As i understand correctly it should then work. But nothing happens when i open SU. I'm working on a mac with SU7 pro.
                      Ruud
                        Assuming the file/folders were extracted 'intact' and then put into the correct Plugins folder [Macintosh HD/...Lib/.../plugins] and not a spurious 'User' one... then a restart of Sketchup should auto-load the tool for you.
                        However, like many such tools this is an Extension and so it needs a one off activation, which is done through Preferences > Extensions.
                        Once it is activated its menu items and toolbar becomes available to you - if it hasn't auto-activated then the toolbar can be activated from the appropriate menu item too...
                          Are you sure it's installed properly - file and folder ?
                          Do you have the latest version ?
                          • fredo6F
                            NEW RELEASE: LibFredo6 v4.5a - 08 May 12
                            LibFredo6 4.5 is a update dedicated to
                            • Some evolutions in ThruPaint 1.2 (paint container and text, as well as bug fixing)
                            • New features for the Free Rotate tool of FredoScale (rotation with offset and inference on line)
                              jooooe
                              sorry! this is not suit for Mac?
                                What makes you think that? It works fine on my Mac as well as many others.
                                • I
                                  ihanna
                                  NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
                                  Needed for for FreeScale 2.0c
                                  see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
                                  Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
                                  hello,
                                  I just want to ask some help, I've already download those files twice but still not working, can you give me some advice? Thanks in advance.
                                  You must be the change you wish to see in the world. โ€”Gandhi
                                    @ihanna said:
                                    hello,
                                    You have to meet us half way. Give us something to help you out. We can't see your computer from here and you've given us no clue as to what you've done short of downloading the files. ๐Ÿ˜’ Did you extract the zip file into Program Files/ Google/Google SketchUp 8/Plugins? Did you extract them correctly? Do you have admin rights to install files into the Plugins folder?
                                    Post a screen shot of your Plugins folder showing the files installed correctly and we'll go from there.
                                      These files don't do much on there own. ๐Ÿ˜•
                                      They are 'helpers' for many of Fredo's other tools, which don't work without the file and subfolder of files etc that form the 'Lib'... ๐Ÿ˜ฎ
                                      • G
                                        GooUser
                                        Thanks you very lot ! It's Great.
                                        • L
                                          Luaner
                                          Thanks again~โค
                                          • T
                                            the.pjt
                                            hi dear ferdo , I have a little question ...
                                            .. maybe it's a bad question and I know that it takes much time for you to write these features fur us ... thanks a lot for time you spend and offering your incredible codes freely to us ... thanks ferdo ..
                                            my question is
                                            how to disable time tracer and updater part due to have a faster startup and a lighter SU ?
                                            I'm a ruby newbie .. but you codes are too complex for me to trace .. ๐Ÿ˜„ .. I just wanna to know the .rb files that does these extra works ...
                                            I'm sorry for asking these .. I believe that these parts ( specially Updater module )are very useful for all users .. and thanks for codding these parts ferdo .. ๐Ÿ˜›
                                            thanks
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 115
                                            • 116
                                            • 19 / 116
