    Filling a Space with Components.
    21 Posts 6 Posters 2.5k Views 6 Watching
    • david_hD
      david_h
      Hey Hey! Thanks Rich. I'll check this out.
      D
      • F
        fransko
        look like this?
        Lotto machine.skp
        • david_hD
          david_h
          Not exactly . . .but thanks for the effort / response.
          I think my image above was misleading. What I need is to show this bin (Image A) filled with ping pong balls like image B. I am just not sure how to make this happen in a fairly natural random way. . .
          Image AImage B
            Did Sketchy Physics not work for this?
              A few years back I did something similar with spray cans dropping out of a box.
              It works fine if you use the earlier link as a base. I'd try again except I don't have it installed.
              • david_hD
                david_h
                I guess I didn't understand that the attached model was a SUPhys model. I guess I am going to have to learn it in order to do what I need to do.
                Thanks for the help.
                D
                  You can use that πŸ˜‰ (file linked)
                  Take any number of Spheres you want (groups or components) at any place above the SkateRamp πŸ˜‰
                  Launch Sketchyphysics
                  Make a Pause at any time you want
                  Open the Outliner
                  Select Spheres inside the Oultliner else the animation go to the start!!!
                  Copy / Past balls in your project πŸ˜‰
                  During the animation you can take and move any ball !
                  If you want another curvated form blocks : just make 2 separated blocks A & B! (groups or components)
                  StaticMesh / Convexhull
                  Have fun πŸ˜‰
                  PS And if you want more sophisticated balls with Number : use the very tricky
                  Relplace random Component by Sdmitch πŸ˜‰
                  balls.skp
                    I have replaced the file on the previous post πŸ˜‰
                    Groups are now components so you can remplace them at the end by anything you want πŸ˜„
                    Yes you must install SketchyPhysics else nothing will arrive πŸ˜‰
                    Even you don't know Sketchyphysics : You have no more to make
                    Just Press Start and Pause and re read the post above πŸ˜„
                    • david_hD
                      david_h
                      Merci Mon ami. Je vais le faire!
                      David
                      • david_hD
                        david_h
                        so I downloaded the latest and greatest of SP3 and on the start up I get this. . .
                        and when I press the Play button I get this. . .
                        any thoughts?
                          Ah damned 😲
                          I am affraid to say that I don't know why you have this sort of thing πŸ˜•
                          Try to install a previous versions of Su
                          That I shown was done with a recent version of Sketchyphysics on an old SU 7 version πŸ˜„
                          Another thing : seems Sketchyphics makes some interference with some other plugs
                          so disable it when you don't use!
                          I just change the name of its extension ".rb" as ".rbo" in the plugin folder πŸ€“
                          • david_hD
                            david_h
                            I was afraid of that. I've only got 1400 Plugins that could be the problem. Should be no problem going through all of them. πŸ˜’
                              Save somewhere the folder Plugins
                              Create a new folder Plugins
                              Install Sketchyphysics
                              run it
                              but from you error messages I doubt that will be sufficient πŸ˜‰
                              • david_hD
                                david_h
                                it usually never is-- πŸ’š
                                when it comes to me, but I will give it a try.
                                Thx,
                                d
                                • brookefoxB
                                  brookefox
                                  I'd give component spray a whirl. It is fast and polite. Try it with a simple 3d tick of the same cross dims as your balls, then redefine the component as you wish if it works out.
                                  ~ Brooke
