    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 296.4k Views 135 Watching
    • ToboboT Offline
      Tobobo
      Using the Entity Ifon box you can increase the length of a line
      In what side? Good or false? πŸ˜„
      The changes its length in the same direction it has been drawn. it has to be unattached at one end, and that is the end the lengthens or shortens.
      Toby
      Philippians 4:13
        Jim
        Has any one here also thought of compiling/organizing this thread into a more readable format? Wiki? Print?
        • pyrolunaP Offline
          pyroluna
          well... there's a sketchup-wiki in Dutch... so... yay! for Dutch people
            Jim
            Today I learned you can use the arrow keys to precisely move the selection in Paint.NET. (Holding Ctrl moves it by 10 pixels.)
              I just realised it the other day myself, too. πŸ˜„
              • david_hD Offline
                david_h
                I've been taken to task just now on this one. . . I asked for a plugin to toggle the Construction lines on and off. . .turns out it's in the view menu. . .
                WHICH I NEVER USE BY THE WAY!!!!
                Hide Construction lines
                This is so humiliating. . .. 😳 πŸ’š
                I'm okay now. . .
                  Jim
                  I just learned that Edit > Delete Guides is context-sensitive - it deletes guides all guides starting from the current editing context and deeper, but not from "higher" level contexts. I had always thought it always deleted all guides, everywhere.
                    I had that same realization a couple of weeks ago. πŸ˜„
                      @rv1974 said:
                      If Thom is already here..
                      Only last week I discovered know that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                      Great tool!
                      Ah, yea it's not that obvious - I had further plans for the UI. (also for CleanUp), but they've been down-prioritized.
                      btw, no need to doubleclick - single click is enough.
                        rv1974
                        Only last week I discovered that double clicking on blue balloons (edge tools-inspect gaps) actually close the gaps.
                        Great tool!
                          Doh. 😲
                          What???!!! πŸŽ‰
                            Being able to select only a few edges from a face and offset them instead of the whole face.
                            Yes but edges must be selected without discontinuity! 😳 😳 😳
                            • boofredlayB Offline
                              boofredlay
                              Something I just learned a couple days ago while studying the Google Earth Modeling videos.
                              D'oh, never knew that you could make a unique texture from a portion of another!
                              [flash=853,505:84crs2i3]http://www.youtube.com/v/18r2sCMUSBU&fs=1[/flash:84crs2i3]
                              • DanielD Offline
                                Daniel
                                I've always known about hiding geometry by holding the shift key with the eraser, but last week I just noticed the "hidden" check box on the entity info window. 😳
                                My avatar is an anachronism.
                                • Bob JamesB Offline
                                  Bob James
                                  Never paid any attention to this thread until today 😳
                                  @tig said:
                                  .....select all faces with the same material as the one highlighted... then RickW pointed out that it is already a standard built-in tool under Select... 😳
                                  OMG 😲 I soooo needed this yesterday πŸ‘Š
                                  This thread is one of the greatest tutorials ever made!
                                  Now to Page 1 and read (and write down) all of the golden nuggets in this thread.
                                    Jim
                                    Yeah, this thread would make a great mini-pub for SCF. I'd probably even buy a tree-ware version as I can't retain online info as well as I can with a good sit with a book.
                                      Seems only from the V7 and + πŸ˜‰
                                        Bob James
                                        SU Duh.pdfCompilation of DUHs
                                        This is an unedited regurgitation of all of the DUH items. Some are repeated.
                                          Cool idea! 😎
                                          I will translate it when I arrive at this page! πŸ˜„ (in fact a sort of speedy copy / past because ...
                                          I am now at the page 7 on French Section ! πŸ’š
                                          • dereiD Offline
                                            derei
                                            What the... 😲?
                                            6.I could change the radius of a circle that's been extruded - maybe using Scale Tool πŸ˜•
                                            19. finding that by holding the spacebar down you can control the zoom in so you don't zip past the
                                            object your zooming to
                                            - really ? It doesn't seem to happen anything different when I zoom and keep spacebar pressed.
                                            ...and the list can continue.
                                            Maybe those should be verified, or given more detailed explanations. After all, its purpose is to teach the noobs, not to confuse them more πŸ’š
                                            EDIT:
                                            22. Also, any selection that only contains a single entity (not only a line) cannot be made a
                                            component (or group) this way. If you select a sphere (with a bounding box), there's a single
                                            "surface" selected only and you right click to turn it into a group/component in vain.
                                            - try pressing G or use the Make Component icon ... πŸ˜‰ maybe is not in vain
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 34
                                            • 35
                                            • 14 / 35
