[Plugin Library] LibFredo6 - v14.5a - 23 May 24
@kespencer1 said:
Hey y'all. I need some help. For whatever reason, LibFredo6 plugin is starting to crash Sketchup. (Yes I know it's this one because I systematically went through and tested sketchup with each plugin I have.)Anyone know a fix for it?
Now that I think about it, it MAY be something that it activates. All I really know is that if I delete it, Sketchup doesn't crash. But then I can't use curveloft and whatnot. ANY help is appreciated.
Are you sure it's installed properly - file and folder ?
Do you have the latest version ? -
NEW RELEASE: LibFredo6 v4.5a - 08 May 12
LibFredo6 4.5 is a update dedicated to
- Some evolutions in ThruPaint 1.2 (paint container and text, as well as bug fixing)
- New features for the Free Rotate tool of FredoScale (rotation with offset and inference on line)
sorry! this is not suit for Mac?
What makes you think that? It works fine on my Mac as well as many others.
NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
Needed for for FreeScale 2.0c
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
hello,
I just want to ask some help, I've already download those files twice but still not working, can you give me some advice? Thanks in advance.
You must be the change you wish to see in the world. —Gandhi
@ihanna said:
hello,
You have to meet us half way. Give us something to help you out. We can't see your computer from here and you've given us no clue as to what you've done short of downloading the files. Did you extract the zip file into Program Files/ Google/Google SketchUp 8/Plugins? Did you extract them correctly? Do you have admin rights to install files into the Plugins folder?
Post a screen shot of your Plugins folder showing the files installed correctly and we'll go from there.
These files don't do much on there own.
They are 'helpers' for many of Fredo's other tools, which don't work without the file and subfolder of files etc that form the 'Lib'... -
Thanks you very lot ! It's Great.
Thanks again~
hi dear ferdo , I have a little question ...
.. maybe it's a bad question and I know that it takes much time for you to write these features fur us ... thanks a lot for time you spend and offering your incredible codes freely to us ... thanks ferdo ..
my question is
how to disable time tracer and updater part due to have a faster startup and a lighter SU ?
I'm a ruby newbie .. but you codes are too complex for me to trace .. .. I just wanna to know the .rb files that does these extra works ...I'm sorry for asking these .. I believe that these parts ( specially Updater module )are very useful for all users .. and thanks for codding these parts ferdo ..
thanks
@the.pjt said:
my question is
I'm a ruby newbie .. but you codes are too complex for me to trace .. .. I just wanna to know the .rb files that does these extra works ...You don't need to edit the ruby files.
Normally, go to the CheckForUpdate dialog box and enter 999 (days) in the 'next check' field.Fredo
PS: 'Check for update' does not go to the Internet when SU Starts. It just checks the date to see if it should display the reminder, so it is very fast. The fact is that that the reminder is based on a WebDialog and the first web dialogs are used, it takes a little bit long (SU may load extra stuff or perform some operations in the background).
thanks feredo ... I hade done that ( 999 ) several days ago .. but I alwase see the ruby image (update check ) at start up .. how about time tracer tool ?
thanks for answer and support ferdo
hi Fredo, Thanks for this work you've done
I have unzipped it to my plugins folder on C:/Program Files(x86)/google/Google Sketchup 8/plugins but for some reasons I just cant find it in the menus! I have also put LibFredo6.rb in the plugins. am I missing something?
kindest regards
Disco
Can't seem to get the toolbar up. I've followed some of the posts and checked its in the right directory, and also ticked the box in Sketchup.
Any help would be appreciated
A.Noob lol
Which toolbar can't you get to display?
The fredo sub menu under window. I've PM'd Fredo who has been kind enough to reply but so far I've not got to the bottom of it. I do have podium installed and fredo suggest it could be a clash with that?
Thanks for the reply Dave
Ah. I see. You said you couldn't get a toolbar to show which is confusing since it isn't a toolbar but a menu entry. So did you try disabling Podium and did that fix it?
NEW RELEASE: LibFredo6 v4.6c - 11 Jul 12
LibFredo6 4.6 is a new release which essentially support the publishing of Curvizard
» [ Post in Spanish ]
#---------------------------------------------------------------------------------En este Post., Se Publicaran Las [ Traducciones al Español ] + Actualizaciones (Para los Plugins de la Fredo6Collection):
Estas Traducciones han Sido Revisadas Línea por Línea., y se han Actualizado durante Meses., para que sean lo Mas Perfectas Posibles., Además., estas Traducciones son Armoniosas entre si, y las Frases son mas Fáciles de Entender y mas Simples (En base a Muchos Días de Investigación y Experimentación)., es decir., Usan el Mismo estilo., para que los “Fredo6 Collection Plugins” sean Mas Fáciles de Entender y mas Amigables entre Si... ႿÐ!
๏̯͡๏ [ … ] Nota: Yo También Ajunto un Plugin., que enlaza este Post desde “SketchUp”: Para Buscar Actualizaciones de las Traducciones (Rápidamente)... ႿÐ!
Defisto [Dice]:
Con este Plugin se Mostrara la Siguiente Opción: Menú Ventana -> + Fredo6Collection (Es-Translations) -> Descargar Traducciones [ Español ]
Por cierto: Si deseas Debatir el Tema de las Traducciones Visita el Siguiente Enlace a un Tema en el Foro en Español:
http://forums.sketchucation.com/viewtopic.php?f=52&t=36889
PS: Ogvua... ႿÐ!
» [ Post in English ]
#---------------------------------------------------------------------------------In this Post is Published the [ Spanish Translation ] + Its [ Updates ] (for the Fredo6 Collection Plugins)
These translations have been checked line by line., and have been updated by months., to be as perfect as possible., also., these translations are harmonious with each other, and phrases are easier to understand and more simple (in Based on many days of Investigation and experimentation)., ie., wear the same style., for that the “Fredo6 Collection Plugins” are more easier to understand and more Match with each other... ႿÐ!
๏̯͡๏ [ … ] Note: I also Adjunct a plugin that links this Post from “SketchUp”: To Check for Updates of Translations (Quickly)... ႿÐ!
Defisto [Says]:
With this Plugin is will Display the Next Option: Window Menu -> + Fredo6Collection (Es-Translations) -> Download Translations [ Spanish ]
By the way: If you want to discuss the topic of translations visit the following link to a topic at the Forum in Spanish:
PS: Ogvua... ႿÐ!
Last Update 2011/04/23 (Version 1.1d = 100% Translate)
Last Update 2011/05/22 (Version 1.0a = 100% Translate)
Last Update 2011/05/23 (Version 0.3.2 = 100% Translate)
Last Update 2011/05/23 (Version 1.0 = 100% Translate)
Last Update 2011/05/23 (Version 1.4f = 100% Translate) - Translation Alternative !!
Last Update 2011/06/24 (Version 2.3a = 100% Translate)
Last Update 2011/07/24 (Version 2.2a = 100% Translate)
Last Update 2011/08/24 (Version 3.0a = 100% Translate)
Last Update 2011/09/06 (Version 1.8a = 100% Translate)
Last Update 2012/03/21 (Version 1.2a = 100% Translate)
Last Update 2012/03/21 (Version 1.2c = 100% Translate)
Last Update 2012/05/15 (Version 1.2a = 100% Translate)
Last Update 2012/07/15 (Version 1.0c = 100% Translate)
Last Update 2012/07/15 (Version 4.6c = 100% Translate)
I am really new to the plugins for Google sketchup. Can anyone tell me how to update my plugins?
