    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Detail in Vray render
    renderpluginsextensions
    13 Posts 6 Posters 2.6k Views 6 Watching
      jrm1
      I'm playing with the Vray demo on an outdoor scene. The floor is decking and in Sketchup you can see the lines of the individual deckboards. When I render, the deckboards turn to one uniform flat surface, which is obviously undesirable. Is there a setting I can play with so that the deckboards render realistically?
      • andybotA Offline
        andybot
        vray doesn't render lines. You need to actually cut grooves in the decking, or use a displacement map.
          jrm1
          Oh, that's a blow. Is an edge not a line (clearly not)?
          What would you do if you were me? Cutting grooves instead of lines might be possible but fiddly. Do other render apps render lines?
          • andybotA Offline
            andybot
            You can always export an line drawing from SU, and then overlay (multiply) over the rendering in photoshop (or similar)
            Render apps typically render only geometry.
            Take a look at the manuals for vray and try setting up a displacement or a bump map - you can get depth quite easily that way.
              jrm1
              So how do people get floor tiles to look real?
              • StinkieS Offline
                Stinkie
                They use texture maps, for the most part. And as far as realism is concerned -lines aren't realistic. Look at real-life floor boards, or tiles, for that matter. They aren't separated by lines. So ... one either models the geometry, or uses texture maps.
                • chonC Offline
                  chon
                  Agreed !
                  Floor tiles are composed in the Vray material with grid for example...
                    jrm1
                    Thank you. I'll look into texture map. At the moment I'm having trouble with rendering my scenes. Crash, crash all the time.
                      cmoreink
                      If you have time and want quality ----> model your $!@%.
                      Image 1) has 2mm space between the planks and it's 2mm deep.
                      Image 2) has 1cm space between the planks and it's 1cm deep.
                      cheers
                      2mm space between planks
                      1cm space between planks
                      my portfolio
                      • V Offline
                        valerostudio
                        Arrowway has excellent materials with reflection and bump maps for all types of wood floors. They have free preview versions which work well in SU. Most you can buy individually at a very reasonable cost.
                          jrm1
                          Model your what?!
                          Great shots btw.
                          Got any hardware setup recommendations?
                          I'm Mac based. 2008 8 core 10Gb RAM. Is that enough for a landscape with loads of plants?
                          • V Offline
                            valerostudio
                            Your hardware will not matter in SketchUp. You are limited by the 32 bit environment that Google has trapped us into. That and the the fact that VRay doesn't run in a separate render program that could take advantage of 64 bit like other renderers. It's a blessing and a curse.
                              cmoreink
                              @jrm1 said:
                              Model your what?!
                              Great shots btw.
                              Model your stuff ๐Ÿ˜‰
                              In regards to your rig, you are doing much better than me. Have you looked into a thomthom "clean up tool" http://forums.sketchucation.com/viewtopic.php?f=323&t=22920, that might help with some heavy landscaping.
                              GLTY
                              my portfolio
