    Detail in Vray render
    renderpluginsextensions
    13 Posts 6 Posters 3.1k Views 6 Watching
    • andybotA
      andybot
      You can always export an line drawing from SU, and then overlay (multiply) over the rendering in photoshop (or similar)
      Render apps typically render only geometry.
      Take a look at the manuals for vray and try setting up a displacement or a bump map - you can get depth quite easily that way.
        jrm1
        So how do people get floor tiles to look real?
        • StinkieS
          Stinkie
          They use texture maps, for the most part. And as far as realism is concerned -lines aren't realistic. Look at real-life floor boards, or tiles, for that matter. They aren't separated by lines. So ... one either models the geometry, or uses texture maps.
          • chonC
            chon
            Agreed !
            Floor tiles are composed in the Vray material with grid for example...
            SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win11-64Bits
              jrm1
              Thank you. I'll look into texture map. At the moment I'm having trouble with rendering my scenes. Crash, crash all the time.
              • C
                cmoreink
                If you have time and want quality ----> model your $!@%.
                Image 1) has 2mm space between the planks and it's 2mm deep.
                Image 2) has 1cm space between the planks and it's 1cm deep.
                cheers
                2mm space between planks
                1cm space between planks
                my portfolio
                • V
                  valerostudio
                  Arrowway has excellent materials with reflection and bump maps for all types of wood floors. They have free preview versions which work well in SU. Most you can buy individually at a very reasonable cost.
                    jrm1
                    Model your what?!
                    Great shots btw.
                    Got any hardware setup recommendations?
                    I'm Mac based. 2008 8 core 10Gb RAM. Is that enough for a landscape with loads of plants?
                    • V
                      valerostudio
                      Your hardware will not matter in SketchUp. You are limited by the 32 bit environment that Google has trapped us into. That and the the fact that VRay doesn't run in a separate render program that could take advantage of 64 bit like other renderers. It's a blessing and a curse.
                      • C
                        cmoreink
                        @jrm1 said:
                        Model your what?!
                        Great shots btw.
                        Model your stuff πŸ˜‰
                        In regards to your rig, you are doing much better than me. Have you looked into a thomthom "clean up tool" http://forums.sketchucation.com/viewtopic.php?f=323&t=22920, that might help with some heavy landscaping.
                        GLTY
                        my portfolio
