    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • B
      beeo
      I installed this plugin as per directions, but when I start SU, I get the following error msg:
      Error Loading File bootstrap_Curviloft.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
      uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
      When I run this plugin, the first two features work fine (loft junction between spline surfaces and a given path.
      When I try Skinning of shapes, I select the two edges. But when I click to validate contours, nothing happens. Click for transition also doesn't work.
      All the files in my Plugin Folder appear to be as prescribed. Any thoughts?
      • fredo6F
        beeo
        Strange that you can run the plugin with the loading erros you mentioned.
        For skinning, you need to have at least 3 edges to form a contour.
          julio78
          Fredo,
          Greetings!
          How do we install the plugin you've made for as who are new to plugin installation like curviloft and others ruby script. I keep on following the installation guide but I there must be something wrong on how I install it and until now its not working.
          Please help!
            @julio78 said:
            Fredo,
            Greetings!
            Please help!
            Read this: http://forums.sketchucation.com/viewtopic.php?f=323&t=35746 The topic has been covered repeatedly. And since you appear to using Windows 7, make sure you have admin rights to the Plugins folder.
              @julio78 said:
              Fredo,
              Greetings!
              Please help!
              Here's an overview of installing plugins for SketchUp: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
              You might want use this utility to help you install plugins: http://forums.sketchucation.com/viewtopic.php?f=323&t=42315#p375454 (Requires SketchUp8 M2)
              • O
                octavalent
                This is just so awesome Fredo, I work with architectural students who are always testing my SketchUp skills, whilst I try to lead them down a path of good modelling practice. Often the modelling moves away from Sketchup because it sometimes is not up to the task where something like AutoCAD or 3dsMax takes. This plugin puts SU right back into the frame. Thank you again for helping the new designers of this world realise thier potential.
                Very best regards to you and all the generous plugin scripters.
                Paul
                • G
                  greattuger
                  Thank you thats incredible man!
                    dugketterman
                    **I have been trying to install the Curviloft Ruby and have been receiving the error messages below:
                    I run Sketchup 8 Pro on a Mac platform....and this script does exactly what I am looking for.
                    Does anyone have any ideas on how I can get this resolved?
                    -Dug-**
                    Message from 000_AdditionalPluginFolders
                    6 ERROR(S): The following plugins had errors and may not be fully loaded:
                    PLUGIN: __loader.rb
                    FOLDER: /Library/Application Support/Google SketchUp 8/SketchUp/Plugins
                    ERROR: undefined method `effective_load' for nil:NilClass
                    PLUGIN: bootstrap_Curviloft.rb
                    ERROR: uninitialized constant Curviloft::T6
                    PLUGIN: CurviloftAlgo.rb
                    PLUGIN: CurviloftCurveMover.rb
                    PLUGIN: CurviloftPalette.rb
                    PLUGIN: CurviloftTool.rb
                    • fredo6F
                      -Dug-**
                      It is simply a bad unzip operation or you did not install LibFredo6
                      Please redo and respect the footprint indicated in the first post of this thread
                        You can use this utility to install plugins: http://forums.sketchucation.com/viewtopic.php?t=42315
                        • G
                          goodguygreg
                          Looks great, BUT WHY WONT IT WORK ON MY PC!!??
                            Like most folks who have problems getting plugins to work on their computers, YOU'VE PROBABLY INSTALLED IT WRONG!
                            If you want it to work you have to give us some useful information so we have something to go on. Tell us what it does. Does it throw up any error messages in the Ruby Console? Show us screen shot of your Plugins directory showing how the plugin is installed. Do you have administrator privileges to add files to the Plugins folder. You need them on Windows 7.
                            • McGyverM
                              McGyver
                              I just dropped by to say- THANKS AGAIN FREDO!!!
                              A long time ago I had tried this plugin and could not get it to work... Because- as it turned out, I did not install it correctly... I forgot all about Curviloft and after seeing this post again, I decided to try it again (installed correctly this time).
                              BEAUTIFUL! Truly a tool to empower the imagination!... At the moment I did not have a specific project to try this on so I just started playing around with various shapes and paths... WOW, so cool... So quick too... and I love the way it shows you what it will look like before you commit to it... nice. So many ideas... now where to start!!??
                              Thanks!!
                              Visit My ShareCG Freebie Gallery
                              • E
                                egraves
                                Hey Fredo6,
                                I have just begun using some of your plugins and I am LOVING them!!! πŸ’š
                                I downloaded Curviloft and the LibFredo6 4.2 and dropped them into the plugins folder on my mac, but when I open SketchUp 8 I receive this message;
                                Error Loading File __loader.rb
                                uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                                Any clue on what is going on? Thanks for your help and the great plugins!
                                • E
                                  Exactly where did you place the files? The full path please? OR even a screenshot of your plugins folder?
                                  Just about every time someone has problem installing it is because then installed them incorrectly. Either in the wrong location or they didn't maintain folder structure of the zip package.
                                  • fredo6F
                                    NEW RELEASE: Curviloft 1.2d - 13 Apr 12
                                    This release marks diagonals in the mesh in ALL generation modes, not just with the PseudoQuad option on. This will better guide mesh reconstruction for usage by the QuadFaceTools by Thomthom and also for Texturing in Mesh UV mode in Thrupaint.
                                    Marking of diagonals is simply to set their edge property with Casts Shadows = false
                                    To summarize
                                    • With option Pseudo-Quads on, you force a complete triangulation of the Mesh. Diagonals are marked
                                    • In other modes, the mesh is triangulated only where needed. When there is triangulation, the diagonals are also marked.
                                    See main post for download
                                      Thanks Fredo πŸ‘
                                      • EarthMoverE
                                        EarthMover
                                        Thanks Fred! Great update to further SU Quad capabilities. Hoping other authors continue with this trend. (hinting Artisan)
                                        Content Creator at Skapeup
                                        • guanjinG
                                          guanjin
                                          To summarize
                                          Thank Fredo again update this iconic tool, thank you
                                          • P
                                            Pherim
                                            I know this is still beta but I think the included features are supposed to work in the current version (sorry if I am wrong). However, the option to generate the junction edges of the skinning tool does not work for me. It only generates the first one and then does nothing any more, although the cursor still shows the hourglass symbol. Generating intermediate edges works fine, however. Can you confirm this problem? And if yes, when will this be fixed?
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 65
                                            • 66
                                            • 34 / 66
