    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 106.1k Views 23 Watching
    • gullfoG
      gullfo
      yes, please.
      Glenn
      http://www.runnel.com
      • sdmitchS
        sdmitch
        Yet another final update with the option to add tiles to the grid.
        http://sdmitch.blogspot.com/
        • massimoM
          massimo Moderator
          Thanks Sam. πŸ‘
          Two little things after a very quick test:
          -the faces of the tiles pointing inside the room are back-faces. This could be a problem if you want to do a render;
          -would be possible that the tiles were components? I mean in that way you could easily change the texture for example and the model would be lighter.
          • sdmitchS
            sdmitch
            I beg to differ. The faces pointing into the room are front faces. I only apply material to the front face so, if they were back faces, you would not be able to see it.
            Making the tiles components is impractical. Yes, all the full tiles could be a single component, but any and all partials would have to be unique components. You could not edit one and affect them all.
            • massimoM
              massimo Moderator
              Then I'm probably doing something wrong. It's the same starting with a back or a front face.
              That's why it would be really useful. πŸ˜‰
              • guanjinG
                guanjin
                Same face of the front are generally below, upside down is a problem
                • sdmitchS
                  sdmitch
                  Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
                    Mra
                    The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
                    One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
                    • sdmitchS
                      sdmitch
                      mra, you are right. Don't know why I thought that actual tiles were necessary.
                      massimo, It seems you were right also. It seems that the pushpull operation "flips" the face and apparently moves the texture to the back. How weird is that.
                      • Z
                        ZFRPS
                        Hi:
                        Dear sdmitch,your plugin nice,maybe have little need to change:
                        sketchup is bim
                          SUFractal
                          Sdmitch ... I was getting an odd result when I tried your latest update. Some of the tiles were positioned low, and some were high ... and faces were flipped too?
                          • T
                            tomot
                            Hi:
                            Please lets not get carried away here! whats ... next a request for the actual supporting hanger holes and hanger wires? πŸ‘Ž
                            my plugins
                            tomot
                              SUFractal
                              @tomot said:
                              Hi:
                              πŸ˜„
                              • T
                                tomot
                                It should be noted that not all ceiling tiles are designed to simply drop into the metal grid, some manufacturers also provide Ceiling tiles that do indeed project below the metal grid hence providing a nice rebated look to the entire ceiling.
                                Regardless its great to see the option of adding real tiles or using a texture map. πŸŽ‰
                                my plugins
                                tomot
                                  SUFractal
                                  Good point tomot ... I agree with you.
                                  One benefit of the individual tiles being created is the ability to switch them out with a lighting fixture.
                                  • gullfoG
                                    gullfo
                                    @tomot said:
                                    Hi:
                                    next thing people will want an algorithm to place light and vent openings πŸ‘Ώ πŸ‘Š
                                    Glenn
                                    • sdmitchS
                                      sdmitch
                                      Was this a one time thing or have you had this result on other occasions. I have never seen this.
                                      Anyone else having this problem?
                                        SUFractal
                                        I tried a handful of times and kept getting the same result unfortunately. And it was a simple rectangular ceiling shape.
                                        • T
                                          tomot
                                          FYI: In several previous version I was able to add tiles sizes, see attached pic, when I do the same with the current version I get a ruby console error Ceiling Grid.rb:95:in `max'
                                          my plugins
                                          tomot
                                          • sdmitchS
                                            sdmitch
                                            tomat, check the case of the "x" in the options. It looks like lower case which will not match the "X" in the case statement.
                                            • 3 / 5
