    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 105.6k Views 23 Watching
    • sdmitchS Offline
      sdmitch
      Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
      http://sdmitch.blogspot.com/
        Mra
        The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
        One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
        • sdmitchS Offline
          sdmitch
          mra, you are right. Don't know why I thought that actual tiles were necessary.
          massimo, It seems you were right also. It seems that the pushpull operation "flips" the face and apparently moves the texture to the back. How weird is that.
          • Z Offline
            ZFRPS
            Hi:
            Dear sdmitch,your plugin nice,maybe have little need to change:
            sketchup is bim
              SUFractal
              Sdmitch ... I was getting an odd result when I tried your latest update. Some of the tiles were positioned low, and some were high ... and faces were flipped too?
                tomot
                Hi:
                Please lets not get carried away here! whats ... next a request for the actual supporting hanger holes and hanger wires? πŸ‘Ž
                my plugins
                tomot
                  SUFractal
                  @tomot said:
                  Hi:
                  πŸ˜„
                    tomot
                    It should be noted that not all ceiling tiles are designed to simply drop into the metal grid, some manufacturers also provide Ceiling tiles that do indeed project below the metal grid hence providing a nice rebated look to the entire ceiling.
                    Regardless its great to see the option of adding real tiles or using a texture map. πŸŽ‰
                    my plugins
                    tomot
                      SUFractal
                      Good point tomot ... I agree with you.
                      One benefit of the individual tiles being created is the ability to switch them out with a lighting fixture.
                      • gullfoG Offline
                        gullfo
                        @tomot said:
                        Hi:
                        next thing people will want an algorithm to place light and vent openings πŸ‘Ώ πŸ‘Š
                        Glenn
                        http://www.runnel.com
                        • sdmitchS Offline
                          sdmitch
                          Was this a one time thing or have you had this result on other occasions. I have never seen this.
                          Anyone else having this problem?
                            SUFractal
                            I tried a handful of times and kept getting the same result unfortunately. And it was a simple rectangular ceiling shape.
                              tomot
                              FYI: In several previous version I was able to add tiles sizes, see attached pic, when I do the same with the current version I get a ruby console error Ceiling Grid.rb:95:in `max'
                              my plugins
                              tomot
                              • sdmitchS Offline
                                sdmitch
                                tomat, check the case of the "x" in the options. It looks like lower case which will not match the "X" in the case statement.
                                • gullfoG Offline
                                  gullfo
                                  seems to work perfect. including complex ceilings. but... if you have the face @ zero on the z-axis, you do see the inverted faces which are flush with the grid and not dropping through. so just make sure your ceiling face is above the zero plane... then again i may have spoke too soon... a complex ceiling definitely exhibits some strange results even when sitting above the 0 on z-axis...
                                  ceiling tile example
                                  result from face @ zero on z-axis
                                  complex ceiling.skp
                                  Glenn
                                    SUFractal
                                    Each time I've tried (and just did again), my ceiling plane was 'elevated'. The plugin worked perfectly until this last tweak ... I'm no programmer or ruby person, but it would appear something occurred w/in the last effort?
                                    I've also tried both 2 x 2 and 2 x 4 grids.
                                      tomot
                                      YES! YES!...... I forgot to read my own Sticky note "Watch the use of case" 😳
                                      (if the SU API Ruby Console was more inclusive by incorporating the entire Ruby reference perhaps this error would have been properly flagged when a script is run)
                                      my plugins
                                      tomot
                                      • sdmitchS Offline
                                        sdmitch
                                        Apparently all my test shapes have been at Z=0. Elevation does matter. Sorry about that.
                                        Well at least I thought elevation mattered. I did a move/copy on a shape and elevated it. When I ran the plugin, I got the pulled down faces without texture, but when I created a elevated shape, it didn't have the problem. I then tried to duplicate the create at Z=0 and move/copy to an elevation and results were normal! What a lovely thing an intermittent problem is!!!
                                        • Z Offline
                                          ZFRPS
                                          first,I need to speak sorry,and i get carried away for this plugin,because i believe this plugin is one of "BIM" plugins,BIM need details ,if this can done , I hope !
                                          However,i must thanks sdmitch and everyone again,this plugin is great.
                                          sketchup is bim
                                          • gullfoG Offline
                                            gullfo
                                            yea, being its occurring over several runs, it may be a variable scope issue where something is persisting which causes the subsequent run to make incorrect assumptions...
                                            Glenn
                                            • 3 / 5
