    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 106.1k Views 23 Watching
    • guanjinG
      guanjin
      @sdmitch said:
      Yet another final update with the option to add tiles to the grid.
      Same face of the front are generally below, upside down is a problem
      • sdmitchS
        sdmitch
        Whether the face you select is face up or down doesn't matter because I check that and turn it face down if needed.
        http://sdmitch.blogspot.com/
          Mra
          The ceiling doesn't really need to be made of individual components, it could just copy the original shape of the ceiling, but move it up a fraction so it sits on the grid properly. Not only woudl this be easier to code, it wouldn't require tonnes of custom components on awkward shaped ceilings.
          One would just apply a ceiling texture and it would give a nice illusion of tiles. Also, there would be less texture tiling.
          • sdmitchS
            sdmitch
            mra, you are right. Don't know why I thought that actual tiles were necessary.
            massimo, It seems you were right also. It seems that the pushpull operation "flips" the face and apparently moves the texture to the back. How weird is that.
            • Z
              ZFRPS
              Hi:
              Dear sdmitch,your plugin nice,maybe have little need to change:
              sketchup is bim
                SUFractal
                Sdmitch ... I was getting an odd result when I tried your latest update. Some of the tiles were positioned low, and some were high ... and faces were flipped too?
                • T
                  tomot
                  Hi:
                  Please lets not get carried away here! whats ... next a request for the actual supporting hanger holes and hanger wires? πŸ‘Ž
                  my plugins
                  tomot
                    SUFractal
                    @tomot said:
                    Hi:
                    πŸ˜„
                    • T
                      tomot
                      It should be noted that not all ceiling tiles are designed to simply drop into the metal grid, some manufacturers also provide Ceiling tiles that do indeed project below the metal grid hence providing a nice rebated look to the entire ceiling.
                      Regardless its great to see the option of adding real tiles or using a texture map. πŸŽ‰
                      my plugins
                      tomot
                        SUFractal
                        Good point tomot ... I agree with you.
                        One benefit of the individual tiles being created is the ability to switch them out with a lighting fixture.
                        • gullfoG
                          gullfo
                          @tomot said:
                          Hi:
                          next thing people will want an algorithm to place light and vent openings πŸ‘Ώ πŸ‘Š
                          Glenn
                          http://www.runnel.com
                          • sdmitchS
                            sdmitch
                            Was this a one time thing or have you had this result on other occasions. I have never seen this.
                            Anyone else having this problem?
                              SUFractal
                              I tried a handful of times and kept getting the same result unfortunately. And it was a simple rectangular ceiling shape.
                              • T
                                tomot
                                FYI: In several previous version I was able to add tiles sizes, see attached pic, when I do the same with the current version I get a ruby console error Ceiling Grid.rb:95:in `max'
                                my plugins
                                tomot
                                • sdmitchS
                                  sdmitch
                                  tomat, check the case of the "x" in the options. It looks like lower case which will not match the "X" in the case statement.
                                  • gullfoG
                                    gullfo
                                    seems to work perfect. including complex ceilings. but... if you have the face @ zero on the z-axis, you do see the inverted faces which are flush with the grid and not dropping through. so just make sure your ceiling face is above the zero plane... then again i may have spoke too soon... a complex ceiling definitely exhibits some strange results even when sitting above the 0 on z-axis...
                                    ceiling tile example
                                    result from face @ zero on z-axis
                                    complex ceiling.skp
                                    Glenn
                                      SUFractal
                                      Each time I've tried (and just did again), my ceiling plane was 'elevated'. The plugin worked perfectly until this last tweak ... I'm no programmer or ruby person, but it would appear something occurred w/in the last effort?
                                      I've also tried both 2 x 2 and 2 x 4 grids.
                                      • T
                                        tomot
                                        YES! YES!...... I forgot to read my own Sticky note "Watch the use of case" 😳
                                        (if the SU API Ruby Console was more inclusive by incorporating the entire Ruby reference perhaps this error would have been properly flagged when a script is run)
                                        my plugins
                                        tomot
                                        • sdmitchS
                                          sdmitch
                                          Apparently all my test shapes have been at Z=0. Elevation does matter. Sorry about that.
                                          Well at least I thought elevation mattered. I did a move/copy on a shape and elevated it. When I ran the plugin, I got the pulled down faces without texture, but when I created a elevated shape, it didn't have the problem. I then tried to duplicate the create at Z=0 and move/copy to an elevation and results were normal! What a lovely thing an intermittent problem is!!!
                                          • Z
                                            ZFRPS
                                            first,I need to speak sorry,and i get carried away for this plugin,because i believe this plugin is one of "BIM" plugins,BIM need details ,if this can done , I hope !
                                            However,i must thanks sdmitch and everyone again,this plugin is great.
                                            sketchup is bim
                                            • 3 / 5
