    [Plugin] UVTools v0.1
    180 Posts 71 Posters 122.4k Views 71 Watching
    • sadyoS Offline
      sadyo
      @sadyo said:
      Can not using this plugin on SU Pro 8.0.4811, everytime i try to using it, it's make SU Bugsplat
      It's happening too with UVTools v0.2 ❓ ❓ ❓ ,
      Oops...Sorry 😳 It's working pretty well on SU8 now, when i try to using it with Jeff Hammond Tips
        Sketchy Master
        Where Is the URL for download
          It's in the first post.
            pdwyer
            Does this still work with SU8 on windows?
            The plugin doesn't start, no menu is created. 😞
            • Rich O BrienR Online
              It works perfectly you must have installed it incorrectly.
              I use it everyday on v7, v7.1 and v8
              • massimoM Offline
                massimo Moderator
                Hi pdwyer, I don't have SU 8 so I cannot test it. Anyway the plugin only appears in the context menu so right click on a texture-->UV tools.
                  pdwyer
                  Ignore me, it is working, just not the UI I was expecting 😄
                  all good
                    burningman
                    I'm using Sk 8-0-11751 on a mac book pro. Can you point me to the download for the uv tools plugin? Thanks so much.
                      It's attached to the first post with a
                      http://forums.sketchucation.com/images/upload_icons/ruby.gif
                      icon.
                      Generally this is the way authors publish and keep their plugins updated here so always look in the first post.
                        burningman
                        BIGthanks mate!
                        • E Offline
                          Eric5150
                          I have a problem using UVTools. I am new to UV texturing. My current project is a sketchup version of Spaceship Earth from EPCOT. The link to the sketchup file is below. I need to know how to get the texture located in front of the sphere to wrap around the sphere.
                          Please give me a tutorial as I would like to know how to do this in the future. Any help would be appreciated as I tried looking through this post but Sketchup kept crashing everytime I tried to do it.
                          Eric
                          http://www.ejlmusic.com/sketchup/Spaceship Earth Final 12C.skp
                          Thanks in advance
                          (would love a youtube video tutorial if anyone has time...it would help us noobs out immensely)
                            jumpjack
                            I don't understand how to use the plugin.
                            I installed it,I get the new context menu.
                            I create a cylynder/sphere, then... what? I create a wall close to it, apply a texture to the wall and use the UV right menu on it?
                            Nothing happens.
                            • FrederikF Offline
                              Frederik
                              Why would you install a plugin if you don't know what it is...?
                              Take a look at some of the posts on page 1 and 2... There's a good tutorial by Alan Fraser...
                              Try applying a bitmap texture to a sphere or a cylinder...
                              It's important that it's not just a color but a bitmap texture...
                              You'll see that the texture looks odd on such shapes...
                              Now click the sphere to select it...
                              Right-click it an from the submenu select UV tools and then select i.e. spherical...
                              You'll see that the texture looks correct now...
                              Cheers
                              Kim Frederik
                                demigamer
                                Thanks A lot !
                                Downloading. . . . 😉
                                • HornOxxH Offline
                                  HornOxx
                                  Hi All,
                                  Since I use Artisan, I have the need to improve my uv-texturing skills ❗
                                  I want to use the UV-Tools plugin but I don´t get it to run on SketchUp 2013 - I´m certainly
                                  doing anything wrong. The only footprint is the "UVtools.rb"-file (?) but inside SketchUp
                                  I dont´t get any icons or any context menu
                                  I appreciate any help
                                  never trust a skinny cook
                                  • N Offline
                                    numerobis
                                    you could try ThruPaint
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=44552
                                    or SketchUV
                                    http://extensions.sketchup.com/en/content/sketchuv
                                      thegoodguy
                                      Thanks for this awesome plugin Whaat!
                                      • N Offline
                                        nlipovac
                                        I use SketchUV and Roadkill, and it works great. 😄
                                        WrapR is in development and it will make unwraping inside SU.
                                        • 2 / 9
