    Modeling space frame
    20 Posts 15 Posters 6.1k Views 15 Watching
    • H Offline
      hanthu250688
      I want to modeling space frame like under picture,but i don't know use what plugin,so i need your help.if you have the video tutorial for this is best,thank everyone so much
        mac1
        Maybe this would be a good place for info also. https://groups.google.com/forum/?fromgroups#!forum/geodesichelp
        • Alan FraserA Offline
          Alan Fraser
          I doubt very much that you will find a plugin that simply creates that structure for you. It will require quite a lot of hand editing. Here is an earlier topic on modelling the roof of the British Museum that might be of some help. I think you may have to begin by constructing arcs with the correct number of segments, then proceed from there.
          3D Figures
          • charly2008C Offline
            charly2008
            Hi Kelvin,
            this would be the first step. Build the first individual element of the truss structure. Then you group them and copy them. Then you make a group from the copies. Then you can use "Shape bender" to create the arc shape. Then you can use the pipe plugin (as shown below). Is perhaps not so easy, but practice makes perfect.
            Charly
            • boofredlayB Offline
              boofredlay
              Hey Kelvin, I did this in about 10 min. If I get a chance at lunch I will recreate in a video. Plugins I used were Joint Push Pull for a volume, Sphere for the nodes and Lines2Tubes, same as Charly.
                charly2008
                Well done Eric! I'm interested in your technique as well. I'm still learning from you professionals.
                Charly
                  boofredlay
                  Here you go Kelvin.
                  Edit: Updated video, cleaner and shorter.
                  [flash=853,505:14xhith0]http://www.youtube.com/v/8197whwxM2Y&fs=1[/flash:14xhith0]
                  • irwanwrI Offline
                    irwanwr
                    thank you for the nice tutorial Eric. 👍
                    it takes quite long time to load though.
                    might revisiting at night when net traffic are lower with this slow connection.
                      mwm5053
                      WOW master at work Bravo 👍
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                      • mitcorbM Offline
                        mitcorb
                        @Boofredlay: That is an amazing sequence of operations. I keep coming back to review. Good work.
                          boofredlay
                          Thank you Tim, that means a lot to me.
                          • peter_shawP Offline
                            peter_shaw
                            wow boofredlay, thats amazing, so much to learn from that short video! 🤓 🤓
                            • EdsonE Offline
                              Edson
                              thanks, eric. this is brilliant!!! 😍 😍 you have quite a knowledge of basic geometry. you make quite a complex construction look simple. congratulations.
                              I only wish I could understand the future use of all those geometry classes when I was at school...
                              http://www.mahfuz.arq.br
                                Ditto!
                                Regret saying "I'll never have any use of this what so ever!" ... 😳 😢
                                  boofredlay
                                  Thanks again guys.
                                    Roger
                                    Eric, what I learned from the video was not so much the geometry, but the value of stopping and thinking about your workflow before starting. That was very useful.
                                    http://www.azcreative.com
                                    • oganocaliO Offline
                                      oganocali
                                      Impressive modelling under 6 minutes in the tutorial. I had a couple of d'oh's watching.
                                      Ogan
                                      • H Offline
                                        hanthu250688
                                        thanks boofredlay so much and everyone
                                        • hellnbakH Offline
                                          hellnbak
                                            Cyberdactyl
                                            By the way hanthu, HERE is a wonderful, and quite remarkable series of videos exploring the 4th dimension and related dimensional tensors.
                                            Not sure if they still offer the 720P versions for download anymore, but they are still beautiful to watch.
