    Web dialogs stopped working
    16 Posts 7 Posters 1.5k Views 7 Watching
    • P
      Plex
      Hi there Wyatt
      You could try this, but of course I don't have to remind anyone of the "excitement" of changing the registry. 😲
      Here goes:
      Navigate to this location:
      HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones
      If there are any strange folders in the registry, it causes problem for the web dialog.
      Everything works fine if there are folders from 0 to 4 (5 total).
      Hope this helps,
      Sig
      • W
        wyatt
        Thanks, Sig. I'll check that out and let you know if I find anything different.
          Does native SU use them for things like File-Import, Preferences, or Save?
          No. That is native windows. Nothing to do with WebDialogs.
            What are web dialogs then? Are they built around Internet Explorer in some way and why would SU fail to display them?
            I had terrible trouble with Maxwell and it's use of SilverLight. Some obscure setting in Windows 7 stopped Maxwell from working.
              WebDialog are embedded web browser controls. Under windows the IE engine is used, under OSX the webkit engine is used. WebDialogs are used by Ruby scripts to create UI.
              File Import, Preferences and Save windows are not WebDialogs - so it sounds to me the problem is not related to WebDialogs.
                EDIT: I'm not able to repair the installation because Windows wants an msi file. SU installs from an exe. I hate to totally reinstall, but that might be my option...
                Download the installation file again, that should let you do a Repair or Reinstallation.
                • W
                  wyatt
                  I did, but the repair option would only recognize msi files. On Monday I guess I'll have to reinstall.
                  Thanks for the explanation, Thom. When the problem first occurred, one of your script's UIs went blank too. I thought you had used a webdialog and thus, assumed incorrectly, that others were the same. Then when Cleanup started working again, I got really confused. I'll see what happens after the reinstall.
                  • W
                    wyatt
                    Well a full reinstall seemed to fix the problem. I have no idea what caused it, but I have all my plugins loaded and there are no menu errors. Must have been a Friday fluke. Thanks to those who offered ideas and solutions.
                      Roger
                      Wyatt, I am running SU8 and as of now, all attempts to go to the 3D warehouse are crashing my machine. Brand new computer with fresh installs.
                      http://www.azcreative.com
                        The 3dWarehouse's download/access-ability had been broken for the last several hours... BUT it seems to be fixed now...
                        • W
                          wyatt
                          I had read on the Shaderlight forum that some things with the warehouse weren't working right. I don't think that was related to the problem I was having.
                          • GaieusG
                            There must be something wrong. Also Martin reported some bugs...
                            http://forums.sketchucation.com/viewtopic.php?p=382229#p382229
