    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      @supercylon
      Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
        I use
        tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
        πŸ˜•
          This is what I use to detect temp path:
          TEMP_PATH = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] ).freeze
          • fredo6F Offline
            @tig said:
            I use
            πŸ˜•
            TIG,
            Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
            @supercylon
            Can you type ENV["TMPDIR"] in the Ruby console
            Fred
              supercylon
              @supercylon
              Hello Fredo,
              Thanks for your assistance. I did what you asked and here is a screenshot of the result.
              ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
              Thanks Supercylon
                supercylon
                @tig said:
                I use
                πŸ˜•
                TIG,
                @supercylon
                Fred
                I didn't notice this message, here is the screen shot of the result of your second request.
                Thanks,
                Supercylon
                  And ENV['TMP'] ?
                    supercylon
                    @supercylon
                    Can you try withe attached file to see if your error disappear and SU starts OK.
                    [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
                    Fredo,
                    Thank you!Thank you! It works!
                    Supercylon
                    • fredo6F Offline
                      Supercylon
                      I will release the change tomorrow as v4.3c
                      It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
                      @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
                      • fredo6F Offline
                        @supercylon
                        EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                          baranya
                          Under Ubuntu makes SU to crach on startup
                          • fredo6F Offline
                            It's difficult for me to diagnose on this platform which I don't have.
                            I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.
                            • Y Offline
                              yogaseeker
                              I ran into some trouble when I placed this plugin in the SU plugin folder. I thought this solution might help others.
                              "LibFredo6 4.3c - 31 Jan 12" is the name of the folder that I unzipped and I placed in my plugins folder. But that didn't work. You have to drag the contents of the "LibFredo6 4.3c - 31 Jan 12" folder (LIBFREDO6_Dir_43 and LibFredo6) out of that folder and put it in the plugins folder.
                              THanks so much for this wonderful plugin!!!
                                mingjae
                                Hello Mr.LibFredo..
                                I have a diifficulty to install curviloft using libfredo in my SU8,
                                it wont load and something wrong with the fredo, this is the picture :
                                http://img594.imageshack.us/img594/7065/99471562.jpg
                                I dont have lib tranductor.rb in Libfredo6 package neither on curviloft,
                                how to solve this Mr?
                                I also trying to copy the lib_tranductor.rb in my SU7 to SU8 plugins folder but it always crash after copying it... 😒
                                • fredo6F Offline
                                  I would suggest you redo a clean installation and make sure you overwrite all existing files.
                                  Just in case, can you type in the Ruby Console and report what you get:
                                  Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                    mingjae
                                    Hi, thank for your reply
                                    my SU8 in plugin folder have not installed by LibFredo and curviloft before,
                                    so I just put all unzipped libfredo and curviloft in my plugins folder,
                                    after I redo to overwrite it, it result the same, it not load "lib traductor.rb
                                    and here is I copy paste after I enter it on ruby console:
                                    "Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                                    C:/Program Files/Google/Plugins/LibTraductor.rb"
                                    edit: perhaps the lib traductor.rb crashes in the Google/Plugins folder?
                                    I copy the "Plugins" folder from my friend notebooks and place it there.
                                    I cut the lib traductor there and place it in SU8 plugins folder and the curviloft success to load...
                                    but, where can I get "lib traductor.rb", there's no in lib fredo zip and curviloft zipped file installer right?
                                    • fredo6F Offline
                                      Actually you do not need LibTraductor.rb for Curviloft (it's only for backward compatibility that it is checked).
                                        mingjae
                                        really?? 😳
                                        lol..i'm sorry, but thanks my SU8 now loading without any error notification..
                                        • fredo6F Offline
                                          By the way, you seem to have a non-standard installation of SU8.
                                          Normally, Sketchup folders are located in C:/Program Files/Google/**Google SketchUp 8**.
                                          • ElibjrE Offline
                                            Elibjr
                                            Wow, Thank you very much. All of these plugins are truly a life saver. They bring Sketchup to a completely different level. I love them. And the more I use them the more I appreciate what they do. This had made Sketchup more than just a modeling toy to play with, these plugins (and others listed on the forum) allow the software to truly and indisputably become more of a productive too hands down! Thank you (and all of the other people who write rubies for this Software) again! WE should NEVER take ANY plugin listed here for granted! πŸ˜„
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 108
                                            • 109
                                            • 23 / 109
