    [Plugin] 2D Tools
    791 Posts 178 Posters 520.6k Views 177 Watching
      d12dozr
      @3ddetailer said:
      ...When I fillet a set of lines, a "tic" mark appears at the center of the chosen radius. I can erase each one, but it's time consuming. Is there a way of either hide them, or erase all at the same time...
      I have the "Delete Guides" shortcut command set to "D" on my keyboard...takes a split sec to delete all of 'em when you're done
      http://goo.gl/f7ooYh
        And if you don't want to set a keyboard shortcut, go to Edit>Delete Guides. I have a keyboard shortcut set, too and use it frequently.
          There are even specialist script-tools to erase cpoints, but not clines, and vice versa..
          You can also hide [all] guide-geometry too using appropriate settings...
          The reason the cpoint appears at the fillet-arc's center is that often you want a reference to it later on....
          • O Offline
            osage
            😲 good grief. I guess I should spend more time exploring the default tools in Sketchup. Never saw that. 😳 AND setting up some shortcuts too.
            Thanks a mill!
            Hmmmm, "cpoints". So that's what you call them huh. Cool. I searched for "tic" marks. Should have known they'd be called something related to Cartesian space ...or something to that effect. Ok, thanks for the info guys. I know all these solutions are probably in the thread, and I hate asking you to spend more of your time to explain something that you've already explained somewhere. So, I mucho appreciate it!
              In the 'early days' they were always called 'cpoints' and 'clines' [they still are in the API code!] but some Google genius a few versions ago decided to rename then 'guide-points' and 'guide-lines'... so watch for oldies/codies using the old names... πŸ˜‰
              • O Offline
                osage
                Ok, now I get it. And thanks for sharing your knowledge Tig.
                fitZ
                oh, btw, here's the reason I was looking for a solution. There were so many filets in this group all the cpoints were distracting. And this is only one of many sets of cables.
                http://httpics.com/is.php?i=1755&img=8874Studio_Wiring_D.jpg
                What's odd..is the cpoints disappear sometimes. Can't figure that one out either.
                And btw, I would never done this had it not been for your filet tool, and the "Line into Tube" plugin. They work great together. πŸ‘ Thanks again for the info. Every little bit helps.
                ooops. I completely forgot. Your 2d text works sublime. The only thing I was wondering is editing a copy of a 2d text. They act like components. If I change one..it changes the original. Can you "make unique" them somehow? That would be phenomenal. Then I could drag a copy along an axis..and edit it. Sure would save a bunch of time. Anyway, thanks a million for this one too!!
                  You should be able to copy any 2dText Component Instance and then Select it and right-click context-menu > 'Make-Unique'... Thereafter it should '2dText Edit' as a separate thing...
                  It can also be useful to have several Instances, because you can Edit one to affect all; it depends on what you want.
                  The 'Entity Info' window will show the number of Instances of a Selected Component - useful in case you are unsure about its 'uniqueness'...
                  • O Offline
                    osage
                    😲 OMG! I could have sworn I tried that. Ok cool, I'll check that out immediately!
                    I LIKE IT!
                    Dang I wish there was a "facepalm" smiley. πŸ’š (note to self: file under.. "more reasons to spend some time looking at default Sketchup tools) πŸ˜†
                    Ok Tig, you made my day. No more questions for at least a week. πŸ˜„
                    oh, btw
                    er...isn't that an oxymoron? πŸ’š
                    • EdsonE Offline
                      Edson
                      hi TIG,
                      forgive me if this question has been asked before but the only problem I have with 2D Tools is the win/mac equivalence (or lack of it) between some keystrokes. to be more precise, what keys should i press on my mac to get the same result as when pressing control and alt in windows?
                      best regards.
                      http://www.mahfuz.arq.br
                        @edson said:
                        hi TIG,
                        best regards.
                        There IS a MAC compliant set of tools posted by Michaelv- http://forums.sketchucation.com/viewtopic.php?p=377902#p377902
                        It's NOT PC friendly... one day I will combine them both, but meanwhile his set is the best for you MAC users... It's currently identical to the PC version, BUT with different key-bindings...
                        • EdsonE Offline
                          Edson
                          @tig said:
                          @edson said:
                          hi TIG,
                          best regards.
                          tig,
                          many thanks to you for the tool and michaelv for the mac fix. it works beautifully now! 😍
                            I must around to merging them... one day πŸ˜’
                            • Y Offline
                              ygcl
                              THANKS TIG,DOWNLOAD IT.
                                jowers125
                                Great plugin! I am having trouble with the fillet tool though. Every time I click on the second line, it deletes the 2 lines and any objects connected to them. Can anybody help??
                                  Every time ??? πŸ˜•
                                  Can you try it with the Ruby Console open and report any errors.
                                  What have you set the fillet radius to ?
                                  Do the lines meet at a corner as an L or a T or have a gap?
                                  Are the lines Coplanar?
                                  Are the lines forming a Face?
                                  etc
                                  Without details it's difficult to say what's up.
                                  Can you post a simple SKP where you are having this issue, and explain exactly the steps you take to get this disastrous result...
                                  It works fine for me - see this rectangular 'donut' - the only extra step I needed to sort this were on the 'hole' - erasing the inner face that was made automatically as those corners were filleted...Capture.PNG
                                  • O Offline
                                    osage
                                    I'm not sure, but it seems to me the first time I tried using the plugin, I didn't realize the "radius" input was defaulted to ZERO, and if memory serves me, my lines disappeared too. Might check it out.
                                      With a zero radius the lines should trim or extend Γ  la ACAD...
                                      Nothing should disappear [except the unwanted lines parts] !
                                      • H Offline
                                        huckrorick
                                        Wow! This is really a great set of tools. Just now testing them out. I'm trying to think of some way to tell you how neat these are.
                                        Thanks. Congratulations.
                                        Huck
                                        • guanjinG Offline
                                          guanjin
                                          Hello!2D tool V5.1 is not continuous picture fill! You can not select another picture!
                                            When the 2dHatching tool is active right mouse-click in open space [away from any objects] and the dialog should pop-up to let you change the PATTern...
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 39
                                            • 40
                                            • 17 / 40
