    $500 for inference engine plugin
    33 Posts 12 Posters 2.8k Views 12 Watching
      I was thinking of maybe making the Gizmo I'm working on for Bezier Surface and Vertex Tools into a standalone plugin. One could then define custom axis for the gizmo - pick from model entities (lines, planes etc) So for basic operations like move, rotate and scale it'd be something that would work without inference.
        I like the thought of a gizmo. πŸ‘
        • arail1A
          arail1
          I can't imagine working in AutoCAD LT without Osnaps. The F3 key turns snapping on or off universally and the Osnaps panel lets you choose the particular snaps that are 'on'. My work flow all day long is a continual dialogue with the software as to what I want to snap to: INT (intersection) / MID (midpoint) / NEA (nearest), QUA (quadrant), etc.
          It's one of the reasons why AutoCAD LT is my main application with SketchUp used for 3D work.
          • fredo6F
            @andybot said:
            yes, tools on surface is great, but doesn't address the snapping issue, nor trying to draw a line in space. I was thinking construction plane would be helpful, but again you run into inferencing for something just off-axis.
            FreeHand is a polyline tool where you can enable or disable inference and snapping. It works without a surface too. It has a pick & click mode and a freehand mode.
            The only thing is that whenever it encounters a surface it follows it.
            But I can make a special version that behaves more like the line tool if this is useful.
            • andybotA
              andybot
              Wow! What a blessed day in sketchucation world!! (sarcastic aside to solo, cornel, et al... πŸ˜’ )
              If you can make a line tool like that in your Fredo world of plugins, I just may call this program FredoUp... Your tools are so amazingly good and useful. I can't imagine my workflow in sketchup without them. Many thanks to you! Not to mention someone may be shelling out $500. I may wish to add to that amount...
              • hellnbakH
                hellnbak
                NEWSFLASH....NEWSFLASH....NEWSFLASH
                This just in...according to informed sources, famed SU modeler Hellnbak has formally announced his intention to declare bankruptcy. More details as they become available.
                • andybotA
                  andybot
                  moral of the story: a new plugin for (fill in the blank) is always closer than you thought... πŸ˜„
                    Can I have NURBS?
                    • irwanwrI
                      irwanwr
                      πŸ˜†
                      now that some ruby jedi masters came along, the famed modeler announced his bankruptcy πŸ˜›
                      • hellnbakH
                        hellnbak
                        mere coincidence πŸ˜‰
                        • irwanwrI
                          irwanwr
                          • 2 / 2
