    Not breaking faces & not making faces
    19 Posts 5 Posters 1.3k Views 5 Watching
      driven
      Hi just got back in and ran the suggestions,
      I'm on 10.5.8 and V8 Pro M2
      Sketchup.break_edges? with all plugins turned ON returned false
      Sketchup.break_edges? with all .rb plugins turned ON and all .rbs plugins OFF returned false
      Sketchup.break_edges? with ALL plugins turned OFF returned false
      ran Sketchup.break_edges=true in Ruby Console
      after restart...
      with ALL plugins turned OFF Sketchup.break_edges? returns true
      with ALL plugins turned ON Sketchup.break_edges? returns true
      ran a few plugins that break or restore edges SU still returns true.
      I greped my plugins folder and edges.rb [by TT] uses
      break_edge = Sketchup.break_edges? Sketchup.break_edges = false and then
      # Restore the break_edges setting Sketchup.break_edges = break_edge return temp_edges.size
      is that the same as saying
      Sketchup.break_edges = true???
      I was using EdgeTools recently, but didn't notice a change afterwards, it was the OP that made me think about a few oddities, very recently...
      Everything seems to be OK, I'll keep an eye out for it failing again.
      cheers TIG and Thomas.
        TT's tool does temporarily reset the edge-splitting to 'false'... BUT it is failsafe-trapped to 'ensure' it's set back as it was when the tool started off [even on a crash]... so it should never mess with your settings...
        This is weird ?
          driven
          It is possible I had a hang , caused by another operation, the last time I used EdgeTools.
          Could that effect the reset?
            It might do... πŸ˜•
            You [we] need to ask TT... as I can see no reason to reset it at all, because API-made-edges never break whatever the main Sketchup setting ? So changing it back and forth seems to do nothing anyway πŸ˜•
              hmm... thought the fail catching should be safe. But I might have to look into this. If TIG is right and the setting only affect the native tools and not Ruby API made edges then is is redundant...
                driven
                cheer TT,
                since I did the reset I've had a couple of crashes and it's still returning 'true' at the moment.
                so it maybe something else...
                • wind-borneW
                  wind-borne
                  Close Gaps of Edge Tools breaks SU setting on my Mac if tolerance setting doesn't allow ends to meet.
                  Thanks for the help all, good learning experience now that I know the way out.
                  "To read between the lines was easier than to follow the text."OSX 10.11.6
                  %(#BF80BF)[SU 8 pro
                    driven
                    hi wind-borne,
                    I was doing something similar then running other scripts that caused hangs... I need try those scripts now... they might work after all
                    a question, does it stay false after a restart when induced?
                    • wind-borneW
                      wind-borne
                      @driven said:
                      hi wind-borne,
                      yes, restarting SU or computer has no effect but =true works like a charm πŸ’­
                      %(#BF80BF)[SU 8 pro
                        hm... I cannot see why this should be happening at all. But I'm inclined to just remove the break_edges references all together.
