    Not breaking faces & not making faces
    19 Posts 5 Posters 1.3k Views 5 Watching
    • wind-borneW
      wind-borne
      Recently SU 8 is falling to pieces. πŸ˜’ , M2?
      Tested 6 & 7 and they are working fine.
      Removing all plugins made no difference.
      First vid 8 on left and 7 on right
      not breaking face and clicking on one rectangle highlights other
      Second vid, after making a few rectangles where faces come and go native push pull reveals what?
      ❓ to try
      "To read between the lines was easier than to follow the text."OSX 10.11.6
      %(#BF80BF)[SU 8 pro
        driven
        not just Lion, same on 10.5.8
        I thought something was odd lately.
        I tried it with no plugins, same [lack of] result.
        • jeff hammondJ
          dunno.. i can't get that to happen on my setup (lion with su M2).. everything is working good for me.
          not even sure where to begin troubleshooting this?
          i guess for starters, i'll post my blank template to see if it's still happening on your computers with my trouble-free template??
          blank.skp
          • wind-borneW
            wind-borne
            Thanks for taking a look, fellow Macnuts
            same result, click on far rectangle, highlights close one, also doesn't break face
            %(#BF80BF)[SU 8 pro
              Can you open the Ruby Console and enter this command?
              Sketchup.break_edges?
                Please ensure that any .rb files in the Tools folder are not duplicated in the Plugins folder.
                Remove any from Plugins that are. The Tools ones are installed with Sketchup, some ill-advised 'collections' of scripts misplace old copies of some base-level files in Plugins.
                The Sketchup.break_edges? typed into the Ruby Console tells us if your Sketchup is set to auto-break crossing edges - the default is true.
                You can toggle it on/off using
                Sketchup.break_edges=true
                and
                Sketchup.break_edges=false
                Which exact version of v8 are you using v8M2 does [seemingly] fix some issues for Lion users...
                • wind-borneW
                  wind-borne
                  Thanks thomthom and TIG
                  Read false, will it stay true now that i changed in console?
                  Troubling me since i installed 8 M2.
                  %(#BF80BF)[SU 8 pro
                    Try changing it manually and see what it is next time you startup Sketchup...
                    It just might be fixed !
                    You might have a script that's resetting it to 'false' at start up.
                    Although I don't know of one.
                    If you do a search through the files in Plugins and subfolders for the text Sketchup.break_edges it might reveal a culprit [unless of course it's compiled]...
                    OR you Sketchup is foobar...
                    • wind-borneW
                      wind-borne
                      i did try a restarting SU a couple times after changing and so far so gooooood πŸŽ‰
                      %(#BF80BF)[SU 8 pro
                        driven
                        Hi just got back in and ran the suggestions,
                        I'm on 10.5.8 and V8 Pro M2
                        Sketchup.break_edges? with all plugins turned ON returned false
                        Sketchup.break_edges? with all .rb plugins turned ON and all .rbs plugins OFF returned false
                        Sketchup.break_edges? with ALL plugins turned OFF returned false
                        ran Sketchup.break_edges=true in Ruby Console
                        after restart...
                        with ALL plugins turned OFF Sketchup.break_edges? returns true
                        with ALL plugins turned ON Sketchup.break_edges? returns true
                        ran a few plugins that break or restore edges SU still returns true.
                        I greped my plugins folder and edges.rb [by TT] uses
                        break_edge = Sketchup.break_edges? Sketchup.break_edges = false and then
                        # Restore the break_edges setting Sketchup.break_edges = break_edge return temp_edges.size
                        is that the same as saying
                        Sketchup.break_edges = true???
                        I was using EdgeTools recently, but didn't notice a change afterwards, it was the OP that made me think about a few oddities, very recently...
                        Everything seems to be OK, I'll keep an eye out for it failing again.
                        cheers TIG and Thomas.
                          TT's tool does temporarily reset the edge-splitting to 'false'... BUT it is failsafe-trapped to 'ensure' it's set back as it was when the tool started off [even on a crash]... so it should never mess with your settings...
                          This is weird ?
                            driven
                            It is possible I had a hang , caused by another operation, the last time I used EdgeTools.
                            Could that effect the reset?
                              It might do... πŸ˜•
                              You [we] need to ask TT... as I can see no reason to reset it at all, because API-made-edges never break whatever the main Sketchup setting ? So changing it back and forth seems to do nothing anyway πŸ˜•
                                hmm... thought the fail catching should be safe. But I might have to look into this. If TIG is right and the setting only affect the native tools and not Ruby API made edges then is is redundant...
                                  driven
                                  cheer TT,
                                  since I did the reset I've had a couple of crashes and it's still returning 'true' at the moment.
                                  so it maybe something else...
                                  • wind-borneW
                                    wind-borne
                                    Close Gaps of Edge Tools breaks SU setting on my Mac if tolerance setting doesn't allow ends to meet.
                                    Thanks for the help all, good learning experience now that I know the way out.
                                    %(#BF80BF)[SU 8 pro
                                      driven
                                      hi wind-borne,
                                      I was doing something similar then running other scripts that caused hangs... I need try those scripts now... they might work after all
                                      a question, does it stay false after a restart when induced?
                                      • wind-borneW
                                        wind-borne
                                        @driven said:
                                        hi wind-borne,
                                        yes, restarting SU or computer has no effect but =true works like a charm πŸ’­
                                        %(#BF80BF)[SU 8 pro
                                          hm... I cannot see why this should be happening at all. But I'm inclined to just remove the break_edges references all together.
