    [Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
    134 Posts 43 Posters 86.3k Views 43 Watching
      tak2hata
      @mitcorb said:
      Thanks, ThomThom:
      Yes, I realize that, now. The confusion came from noting the author's profile and subsequent responders profiles have not been updated, so I assumed that this plugin was available for SU v7 also.
      I do have Sketchup V8 but I have not yet installed it there.
      Hi, Mitcorb and ThomThom.
      I improve this plugin.
      This will work on Sketchup v7(perhaps v6).
      I abort using "volume" property.
      Thanks.
      by TAK2HATA
      • mitcorbM Offline
        mitcorb
        Hi, Tak2hata:
        Thank you for your dedication and amazing talent. I will update my files accordingly. It is the generosity and spirit of folks like you that make this Forum what it is. I salute you.
          j_forrester
          First of all great plugin!
          I was wondering if would be possible to first select your solid as currently, but then select a group of many faces and it create a whole for all in one go or is it limited to only a single face at a time?
          Keep up the good work!
          • MALAISEM Offline
            MALAISE
            Hi tak2hata,
            This "tool" is awsome ! You hardly imagine time saved by using it in complex
            shapes. Thanks for sharing 😄
            MALAISE
              tak2hata
              I correct bug.
              Fix to correct the hole shifting.
              Perhaps OK. 😉
              Thanks.
              by TAK2HATA
                jorge2011
                Hi, tak2hata:
                Thank you very much for this wonderful plugins.
                I send a file to test the plugin. I think the plugin does not work well with these geometries.
                thank you very much
                Sin título.skp
                • mitcorbM Offline
                  mitcorb
                  Hi, tak2hata:
                  I am glad to report that the tool works in both v7 and v8. I made the observation (probably obvious, but not demonstrated) that the hole punching path is always normal to the face doing the punch. So, if your cutting face is slightly off angle, then the hole may not occur exactly where you expect it.
                  EDIT: All that is required is that the object to receive the hole be a grouped closed volume.
                  The tool will ignore all other intervening geometry that might be in the cutting path.
                  EDIT: Oh, and thank you once again, tak2hata san!
                    tak2hata
                    @jorge2011 said:
                    Hi, tak2hata:
                    thank you very much
                    Hi,jorge2011.
                    I saw your model.
                    It does not be occluded with very small faces being disconnected.
                    It must correct to be judged as solid in sketchup v8.
                    solid model I want is all each edges has connecntion to 2 faces or 4 faces.In this case,the faces are occluded.
                    Thanks.
                    by TAK2HATA
                    • sumasterS Offline
                      sumaster
                      Hello tak2hata,
                      It's very useful tool .......
                      GooD ....... Thank you ........
                      Very nice .......
                      Thank you,
                      SUmaster
                      • simon le bonS Offline
                        simon le bon
                        Hi tak2hata ☀
                        This is a very smart tool where Su is lacking. Thanks a lot. 👍 👍 😎
                        (not very far from TIG's "Hole Punching Tool" complementary and maybe more easy to use "on the fly".
                        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_01.jpg
                        Do you think It will be possible to overpass some limitations ?
                        -> use it on a shape which is not necessarily : - a closed shape, - a group or a component.
                        -> select a bunch of faces to be hole punched rather than to be one by one ?
                        My respect and my friendship for what you gracefully share into this place,
                        http://i274.photobucket.com/albums/jj245/Spendauballet/iSimon/applause.gif
                        ++simon
                          tak2hata
                          I update this to v1.6.in Dec 14, 2011.
                          New function and small improves.
                          Enjoy. 😉
                          by TAK2HATA
                            RichardCherry
                            Absolutely superb!
                            The update is excellent, thank you 😄
                            • bmikeB Offline
                              bmike
                              will try it out after the update!
                                simon le bon
                                Dear tak2hata,
                                veryyy nice upgrade indeed!! 👍 👍 😄
                                (model Fancy arched window by loverevolutionary on 3D Warehouse)
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_002.jpg
                                Would you please tak2hata not give up in such a good path: It remains a major limitation.
                                It would be very interesting to drill holes by lot in case of large number of windows for exemple...
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_003.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/thHoleonSolidtool_tak2hata_004.jpg
                                A little reminder on how make a Component with a cutting option:
                                (I have myself to revisit the process each time 😕 )
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_005.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_006.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_007.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_008.jpg
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_HoleonSolidtool_tak2hata_009.jpg
                                Cheers,
                                simon
                                  tak2hata
                                  Hi,Simon.
                                  Thanks your opinion.
                                  I will add function multi hole.
                                  You give me nice idea and description picture.
                                  And the funcy window is very nice.
                                  Thanks.
                                  by TAK2HATA
                                    sicd_steve
                                    It won't work on Snow Leopard 10.6.8 I can't get it to work on a Mac?
                                    I have done everything ?
                                      jorge2011
                                      tak2hata hello. Thank you very much for this excellent plugin.
                                      Just a suggestion,
                                      Is possible to add an option (for example by pressing the alt key) for projecting the selected faces over the group or component?
                                        It does something on my Mac with 10.6.8. It's not what I expected. Hmmm
                                          tak2hata
                                          Hi,sicd_steve ,Dave.
                                          I will test the problem on mac later in few days.
                                          Please wait.
                                          by TAK2HATA
                                            driven
                                            Hi it's working, with and without other plugins enabled on 10.5.8.
                                            I do get
                                            WARNING: make_unique is a deprecated methodof Sketchup:Group nil WARNING: make_unique is a deprecated methodof Sketchup:Group
                                            but it functions.
                                            so any one on Lion who is up for a simple test can.
                                            in 'Ruby Console' enter
                                            Sketchup.plugins_disabled = **true**
                                            then quit and restart, you will now not have a plugins menu,
                                            so open Ruby Console again and type or copy/paste
                                            load '/Library/Application Support/Google SketchUp 8/SketchUp/plugins/create_hole_on_solid.rb'
                                            modify if your path is different
                                            Retest the plugin... then into RC again
                                            Sketchup.plugins_disabled = **false**
                                            to turn back on all your plugins next startup.
                                            • 5 / 7
